Question about Acer Aspire 7520-5185 Laptop
Laptop screen I bumped my laptop screen the other day and now my screen on the right hand side of it, is blank and the other side is normal. When I get on the internet the screen is normal and what ever I pull up has a great picture but when in just I guess u call it stanby mode it is half and half. I know I probably did not explain this like I should, but I would apreciate your help. Thanks, Tim
  • 1 more comment
  • savinlives Jan 26, 2009
    I know it has been a few days since u wrote my solution, but I did not get it to the shop until last week. Thanks again, I hope if I need u again u will help me. Thanks, Tim
  • Louie  Role
    Louie Role May 11, 2010
    Hi and welcome to FixYa,
    Offhand I would venture that your concern could possible be a backlight assuming your have a 17 inch monitor with 2 CCF lamps or the LCD display screen interface. Initially, if at all possible take a snapshot of the display with the half blank. The picture would have to be 150kb max though.
    Pls post back as requested. Good luck and Thank you for using FixYa.
    Brigadier General:
  • 6,966 Answers
Posted on Jan 13, 2009
Blank white stripes right hand side prits
Possible screen failure. Test with an external screen to rule out GPU issues.
Jan 25, 2014 | Computers & Internet
Edge to edge screen bumping to get more space on 5100 dell
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
Jul 17, 2012 | Dell Inspiron 5100 Laptop
My 7570 has a blank screen when I turn it on it is lit up nnothing comes up.
There is a small wheel below the buttons on the right hand side that can be turned "up" or "down" to see the electronic letters properly. Sometimes that gets bumped accidentally and the screen appears to go blank - it's still there, just needs to have the letters darkened - they are just washed out. Turn the little wheel and it should return. If that doesn't work, quite possibly there is something else going on. If you can stitch even without seeing the screen - that most likely is the answer. Good luck! S
Apr 19, 2011 | PfaFF Creative 7570
Put in password 3 times then laptop locked up. All I get is a blank screen with the cursor in the top left hand side.
try starting it in safe mode, right after you turn it on you will se option like esc, f1 and f10 at the bottom of the screen, press the f8 key and a menu will display, use arrow keys to go down to safe mode option then press enter, do it quick, you only have 25 seconds to do it before computer starts normally, you wont see the f8 option but you have to press it, if it doesn't work, try keeping it pressed till menu shows...
Oct 05, 2010 | Computers & Internet
I have an hp laser printer 2550. all os a sudden
What has wrong is the toner cartridge holder has jumped a tooth and thats what is causing it. It is a easy fix but very hard to tell you over fixya. Steven 818-888-0006
Mar 12, 2010 | HP Color LaserJet 2550n printer + HP Color...
Hello, i have an asus laptop, model X58L. i was on the laptop when suddenly on the right hand side of the screen there is quiet a chunky bit of a green streak coming down, turning some of the screen green?...
You will have to replace the screen they are usually around £70 to £80 however if you search around you can get it cheaper. If its under warranty get it replaced free. The reason it has happened is usually one of the connections gets damaged or overheats and it kills that side of the screen.
Feb 22, 2010 | Computers & Internet
The screen on my dell 2200 has flipped 90 degrees after my cat stepped on the keypad, how do i rectify this, back to normal.?
I have an Nvidia card on my laptop and I right click on a blank area of the screen and scroll down to Nvidia control center. Once that window comes up, there is a setting in the left pane that refers to display orientation. Ati has similar options for their cards.
Nov 03, 2009 | Dell Inspiron 2200 Notebook
42" samsung plasma screen cracking on
i would say take it to your local tv repair shop the screen will have to be replaced or if you told your insurance i happened because of a lighting storm they might have replaced it
Aug 08, 2009 | Vision HDV-42P2 Television
Gateway monitor problem
Does this monitor has a reset to factory specs on the menu? If so then select it.
Jan 05, 2009 | Gateway FPD1760 17" LCD Monitor
Acer Aspire 7520-5185 Laptop Logo
340 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
