How to restore shortcut excel file into real file
    Scholar:
  • 155 Answers
Open the file from the shortcut, then do a "Save As". Another alternative is to right click your mouse on the shortcut, look at properties - it will tell you where the file resides.
Posted on Dec 04, 2012
How to repair damage excel file
Use Excel Repair Toolbox designed to restore data from corrupted .XLS files. MS Office .XLS file repair software can fix many error.
For more: https://www.xlsrepairtoolbox.com/
Jul 14, 2015 | Microsoft Excel for PC
Tip
Run shortcuts
Type the following commands in your Run Box (Windows Key + R) or Start Run
devmgmt.msc = Device Manager
msinfo32 = System Information
cleanmgr = Disk Cleanup
ntbackup = Backup or Restore Wizard (Windows Backup Utility)
mmc = Microsoft Management Console
excel = Microsoft Excel (If Installed)
msaccess = Microsoft Access (If Installed)
powerpnt = Microsoft PowerPoint (If Installed)
winword = Microsoft Word (If Installed)
frontpg = Microsoft FrontPage (If Installed)
on Apr 04, 2011 | Computers & Internet
Tip
Keyboard shortcuts for Microsoft Windows XP, Vista, 7 and Microsoft Office
Windows
Windows Key+E
This shortcut allows you to open Windows Explorer with one quick keystroke.
Alt+Tab
This allows you to easily toggle back and forth between all the windows you have open. You can also use this to switch between windows in the same program, making multitasking real easy.
Windows key+Tab
This lets you scroll the items on the taskbar, and in Vista, it starts Flip 3D for a fun graphical spin on the same idea.
Alt+F4
This shortcut is a quick way to close a window in any program without using your mouse to hit the X in the upper-right corner.
Windows Key+M
This allows you to minimize all of your open windows, leaving just the desktop left exposed. To restore the windows, hit Windows key+Shift+M. Another quick way to do this is Windows key+D, which shows your desktop; to restore, just repeat the same keystroke.
Ctrl+Drag
There are many ways to copy a file, but this just might be the easiest. All you have to do is click on the file, hold, and drag it into its desired location. This works the same as another handy shortcut, Ctrl+C.
Windows Key+U+U
This is the shortcut for quickly shutting down Windows by hitting the Windows key (don't hold it down), hitting U to reach the shutdown menu, and then hitting U again to shut down.
Windows Key+Pause
This is a quick way to get to the Systems Properties menu.
Shift+Delete
If you want to delete a file-and you don't want to deal with it later in the Recycle Bin-this is the way to go. Just be absolutely sure that this is a file you won't want back!
To bypass the Autorun when inserting a CD
Hold Shift While Inserting the CD.
Microsoft Office
Ctrl+U, Ctrl+B, Ctrl+I
Used to snap to underline, bold, and italicize without the mouse if you press Ctrl+U (underlining), Ctrl+B (bolding), or Ctrl+I (italicizing).
Shift + Arrow Keys
Holding shift and pressing one of the arrow keys will highlight text in Word (or a group of Excel cells) without the mouse, selecting in the direction the arrow points.
Ctrl+Z, Ctrl+Y
Undo an action by hitting Ctrl+Z; if you change your mind, Ctrl+Y will redo the undo.
Microsoft Office - Excel
F1
Opens a help task pane
F1 + Ctrl
Opens or closes the help window
F2
To edit the text in the active cell
F2 + Shift
To write a comment in the active cell
F2 + Alt
Opens the save as dialog box
F3 + Shift
Opens the insert dialog box
F3 + Ctrl
Opens the define name dialog box
F3 + Shift + Ctrl
Opens the create name dialog box
F4
To redo the last command
F4 + Ctrl
To close the workbook window
F4 + Alt
To close the excel program
F5
Opens the Goto dialog box
F5 + Ctrl
brings back to the first level of workbook
F6
To shift between help taskbar and the excel window
F6 + Shift
To goto the previous square in the open worksheet
F6 + Ctrl
If more than one workbook is open to switch between them
F7
To open spelling correction window
F7 + Ctrl
When workbook window is not maximised it will move the window
F8
To activate / deactivate extended mode
F9
Will calculate all the worksheets in all open workbooks
F9 + Shift
Will calculate the active worksheet
F9 + Ctrl
To Minimise the workbook window
F10
Will select the menu bar
F10 + Ctrl
To open minimised window
F11
Will create a chart using the current range
F11 + Shift
To select a new worksheet
F11 + Alt
To switch between visual basic editor and the worksheet
F11 + Alt + Shift
Opens microsoft script editor
F12
Opens save as dialog box
F12 + Shift
Saves the active workbook
F12 + Ctrl
To open the Open dialog box
F12 + Ctrl + Shift
Opens the print dialog box
on Jan 01, 2011 | Computers & Internet
How to recover Excel lost file
How to solve some troubles with excel files you may learn from- http://www.filerepairforum.com/forum/microsoft/microsoft-aa/excel/481-%E2%80%8Bexcel-files-corrupted
How to Recover an Excel File for Free
1.Check the Recycle Bin--if you've accidentally deleted the file, it should still be there unless you've emptied the bin, and you can click on the file and recover it.
2.Use the Auto Recovery Pane when you open Excel. Review the document recovery pane. If Excel has managed to recover your file, it will show in a separate pane on the left-hand side. Identify your document in the pane, then click on it and choose "Open" to open the recovered file.
3.Try manually repairing the file. Click on "File" in Excel 2003 or the "Office" button in
Excel 2007, then select "Open" and click on the arrow next to the "Open" button. Click on
"Open and Repair" and choose from two options: click on "Repair" if you want to try to completely recover the file, or click on "Extract Data" if you previously tried Step 1 and it did not work.
4.Search for the file manually on your computer. When performing a system search (click "Start" and select "Search" in Windows XP and Windows 2000, or press the "Windows" button and "F" key in Windows 7 and Vista), make sure you choose "Advanced Search Options" and then check the "System and hidden files" check box. You may be able to find your missing or corrupted file using this search: double-click on the file name in the search results to open it.
If nothing can help you, look at Excel Repair Toolbox
As a solution, it costs money, but effective- http://www.excelrepairtoolbox.com/
Nov 11, 2014 | Microsoft OFFICE 2013 PROFESSIONAL 1 PC...
Excel sheet has been lost how to recover
Lost Excel file can be recovered from:
  1. Recycle Bin - If you have deleted the file with normal delete.
  2. Backup - If have maintained the backup of file.
  3. Email - It may possible that you have mailed the file to someone.
  4. 3rd Party Recovery Software - Recuva, Stellar Data Recovery ...
Oct 29, 2012 | Microsoft Office Excel (License Only)...
I have a problem with excel attachment when Problem with the Microsoft Excel 2007 Home and Student Edition Full Version for PC (5534075) I have a problem with excel attachment when received on email, the...
Try to Restore Microsoft Excel to Its Default Spreadsheet ,
Open Microsoft Excel.
Navigate to the Help menu and open the "Detect and Repair" function. The Detect and Repair dialog will appear. If you want to restore your shortcuts at this time, check the appropriate icon
Click "Start." Wait for a short period while Office deletes all of the settings on all of the programs in the suite and restores it to its original installed state. This will apply the settings to Word, PowerPoint and Excel, and any other Office programs you have installed
Feb 22, 2011 | Microsoft Excel 2007 Home and Student...
My word 2003 shortcut keys are not responding ?
Try restoring shortcut keys to their original (default)settings.
Open Winword.
1.On the Tools menu, click Customize.
2.Click Keyboard.
3.In the Save changes in box, click the current document name or template (template: A file or files that contain the structure and tools for shaping such elements as the style and page layout of finished files. For example, Word templates can shape a single document, and FrontPage templates can shape an entire Web site.) that contains the shortcut key (shortcut key: A function key or key combination, such as F5 or CTRL+A, that you use to carry out a menu command. In contrast, an access key is a key combination, such as ALT+F, that moves the focus to a menu, command, or control.) assignments you want to restore.
4.Click Reset All.
Note:- Reset All removes your customized shortcut key assignments and restores the original Microsoft Word shortcut key assignments in the selected template or document.
Hope it will help.
Oct 29, 2010 | Microsoft Windows XP Professional
Memorex U3 traveldrive,USB 2.0 won't open Word '03 file in Vista,says, ''shortcut path does not exist.'' But shows it in there at 450 KB? Help. Thanks, Charles
try to copy the file on the hard drive and then open it and make sure the file u are mentioning is not a shortcut sometimes we even send a shortcut into the usb drive instead of the real file by mistake so check it
Jul 09, 2009 | Electronics - Others
Word & Excel won't open files when doubleclicked in Windows Explorer
Excel may have "Ignore other applications" selected. See THIS Microsoft Knowledgebase Article.
Try going to Excel Options; Advanced tab; and under the 'General' heading: uncheck the box that says: Ignore other Applications that use Dynamic Data Exchange (DDE).
Dec 02, 2008 | Microsoft Office Home and Student 2007...
reinstall - there must be administrator issues on your computer.
Oct 29, 2008 | Microsoft Office 2003 Basic Edition...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
