Question about HP Televison & Video
HP G72. Powers up but acts as if it is running off the battery. Power supply has been checked at the wall. When the battery gets low, it will shut down. But after turning off, it will recharge and power back up.
    Master:
  • 879 Answers
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or make a search by typing in the brand name of the device in the "Search Box", at the top right of the display window.
Posted on Dec 04, 2012
SOURCE: Audiovox FPE3000 turned off sponataneously and will not turn back on
Power supply failure- I found the filter caps were all cooked dry and the yellow glue they use in this power supply turns conductive where it turns dark brown. Unsolder the devices and feet on the heatsinks and remove them along with the stand-up driver board. Change all caps-1000u/16V, 470u/16V, 47u/50V, 10u/50V. Scrape and pick off the brown glue from all devices. Re-assemble. Mine would then fire briefly and I noticed only one fan was turning. Removed the fan and found the bearing was seized in it. Power supply will now run properly with the defect fan unplugged. I won't service one of these again-the picture sucks!
Posted on Feb 16, 2008
skotkolr
  • 558 Answers
SOURCE: Symphonic WF20L6
I think the transformers in these units are the problem not the "power board" I have a symphonic that had a bad transformer in it two legs were not putting out any voltage so I replaced the whole main board for about 50 usd. I may put a small fan inside to move some air around that transformer so that it stays cool
Posted on May 04, 2008
  • 4234 Answers
SOURCE: NEC PX-42VP4G Power supply
Check to be sure that there is no voltage on the input line. You don't indicate what input you are using. Since the set appears to work without an input connected, try looking at the input cable. Also, if the problem is internal to the set, shorting the input jack would cause the same behavior. Please update this with what you find.
Dan
Posted on May 13, 2008
  • 534 Answers
SOURCE: fujitsu power supply shutdown goes to standby mode. no picture. If I turn it off for a while I get great picture and after a while it shuts down and goes into standby mode. Is this a power supply that
This is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem in the P42HHA10 model. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A similar Service Bulletin is probably available to suit your model. A competent service technician should be able to implement the service bulletin.
Posted on Jun 05, 2009
  • 44 Answers
SOURCE: Bad power supply and regulator circuit
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
My HP G72 17'' shuts down about once a day
Is it overheating? Does it shut down when left unattended? Clean fan and vents. Improve air flow through laptop. Change power settings/Advanced Power Settings to High Performance and change Hibernate/sleep to never.
Dec 05, 2012 | HEWLETT-PACKARD G72260US Notebook
Hp g72-260us suddenly shuts down on battery power only
your power setting is not work perfectly going to your battery option and click that then you setting power capability.
Feb 17, 2012 | HP Audio Players & Recorders
No power
Try disconnecting the power supply and start it on battery only.
After you see a screen display of some kind, the power supply can be reconnected.
If this does not work, then remove the battery and start the computer using the power supply only.
After the computer start up sequence is complete, the battery can be re-inserted into the computer.
If the computer continues to misbehave on later restarts, then follow the more rigorous BATTERY RECALIBRATION Procedure below.
1. Now, after the system is up and running with both the battery inside and the power supply connected, after taking note of the current settings so that they can be restored later, set the power plan to High Perfomance, set the computer to Never Sleep on Battery and on Power Supply, disconnect the power supply and allow the computer to run until it shuts itself off due to a low battery condition. This will discharge the battery and performs phase one of battery re-calibration.
2. Next, plug in the power supply, while leaving the battery in place and restart the computer. Allow the battery to fully recharge while leaving the power plan at High Performance and the Sleep to Never. This performs phase two of battery re-calibration.
3. Then, disconnect the power supply and allow the computer to run until it shuts itself off due to a low battery condition, again, now that it has a possibly better, fuller charge than in the previous charge/discharge cycle.
4. Again, restart the computer, connect the power supply and allow it to completely charge the battery.
5. Shut down the computer, disconnect the power supply.
6. Restart the computer and allow the computer to run until it shuts itself off due to a low battery condition again.
7. Now the battery has been recalibrated. Connect the power supply, restart/resume the computer and allow the battery to fully charge again. The Power Plan and Sleep Mode can be set back to their original settings at this time.
8. The above procedure should only need to be performed every six to twelve months to recalibrate the battery.
This condition sometimes happens to my HP Presario when I have left the power supply plugged into the computer with the battery in for several days or weeks at a time, without running on the battery alone for a while to discharge and recharge it a little bit.
HP recommends that when running your computer for more than two weeks from the power supply, the battery should be removed to slow the aging of the battery, which can cause the battery to lose capacity or fail prematurely.
May 23, 2011 | HEWLETT-PACKARD Hewlett Packard HP 15.6"...
My power cord seems to not be working with this computer. I have tried all the outlets in my house and nothing is charging my laptot.
I'd call HP and request a new power adapter. I've had a few of them go bad before and it's just a short in the cord. Your plug might be loose also...but a good place to start is by calling HP and getting a new cord.
Mar 12, 2011 | HEWLETT-PACKARD Hewlett Packard HP Black...
Why does my computer shut off by itself? it is a hp pavilion a305 pc desktop. we tried cleaning all the dust out but it didn't help
HP skimps on powers supplies which causes them to run at near-capacity and eventually fail. That case should accept a standard ATX supply but if buying on eBay (suggested-lots cheaper) check with seller for compatibility. Do NOT replace the old supply with the same power rating; choose one with 50% or greater capacity; i.e. replace 250W with 350-400W. It won't cost hardly any premium or use more power, just run under less stress.
Oct 31, 2010 | HP Pavilion a305w (DM181AR) PC Desktop
I have a hp 6735s laptop. Its just out of warranty. When plugged into the mains adapter it is no longer charging the battery. This means it only works when plugged in. Have i inadvertantly set the...
best way is to just try out the battery on another laptop, or try another battery on yours. If the laptop is not very old, and I suppose yours isn't more than 2 years old, your battery shouldn't be dead.
Aug 16, 2010 | HP Compaq 6735s Notebook
My laptop wont start. it tries, goes dead, powers
1. Remove the battery
2. Use only the power supply.
3. After the computer starts, put battery back in.
Power supply can't handle low battery & computer start up at the same time.
Sep 01, 2009 | HP Pavilion dv6000z Notebook
Compaq Presario sr1000(sr1430NX) will not stay powered on
Hi!
Please check for the cables coming into the motherboard from the power supply. Also try and check for any loose cables.
If that doesn't help then please get your power supply changed as its faulty.
Please rate this solution.
Thanks
Rylee
Feb 11, 2009 | HP Compaq Presario SR1430NX (PS566AA) PC...
Power issues on HP DV1000
It is possible you have two dud batteries. Recharageable batteries have a limited life, they have a finite number of charge and discharge cycles.
With the battery removed and only the power supply connected and the laptop powered up, when you touch the connector on the laptop and the laptop does not shut down then the laptop connector is OK.
If you can verify your new battery is OK the the fault could be the power supply adapter, if may not produce enought current to run and charge the battery. Try charging the battery overnight by turning off the laptop and leaving on the mains t charge. Borrow a mains adapter and test it on your computer.
You can also check the BIOS setting for power management, ie. hibernate, low power shut down etc.
Dec 03, 2008 | HP Pavilion dv1000 Notebook
The laptop doesn't boot up always.
I would try the following:
1. Remove the battery completely. If the computer boots properly several times in a row, then the battery may be causing the power supply to do strange things.
2. If you have experience removing laptop components, try removing the hard drive. Because you say the screen goes black (I assume the system powers off) sometimes after the HP logo, I doubt its Windows or a software issue.
3. If HP has a diagnostic CD you can boot to, try that.
4. It may be the power supply acting up. If it charges the battery, and if you can boot to Windows with the battery, try getting a new power supply.
5. Otherwise, it may be the motherboard of the laptop.
Nov 28, 2008 | Computers & Internet
Televison & Video Logo
Top HP Televison & Video Experts
Tony
Computer Links
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
