Question about HP Photosmart C4580 All-in-One InkJet Printer
Unable to see wireless connection
Tried the step by step instalation still cannot get the laptop to see the wireless connector
  • glawrence515 Jan 19, 2009
    I have the same problem. Running Vista - just got the printer/scanner/copier this afternoon. Gets to 94% then stops. "HP Installer setup has stopped working." Troubleshooting test report says, "MAC address filtering may be enabled on your wireless router."
    Tried calling 800 line but got frustrated with the lack of help on the other end.
    President:
  • 623 Answers
I would actually need more information on your problem:
  1. Which OS are you using (WinXP, Vista, Linux, Mac)?
  2. Do you have a wireless network (infrastructure mode) at home or do you try to set up an Ad-hoc network (Computer to printer only)?
  3. If you have a wl network, which router are you using?
You can look for yourself, if you like at the support web page from HP, which gives you different scenarios. Check here.
...and while you're on it...see here, if there are any driver updates available for your printer.
If this suggestion didn't fix your problem, come back here with more information and I'd be happy to help.
Posted on Jan 17, 2009
Wifi connection
use the advance tab settings or go to advance setting in the wireless router
Apr 13, 2012 | Dell Latitude D600 Notebook
I just installed a Motorola SBG6580. I have it connected via Ethernet to my desktop (MS XP) and via wireless to one of my laptops (MS Vista). Both work well. However, I have been unable to connect my...
Try changing the authentication type to WEP/WPA/WPA etc. Might be your XP laptop doesn't support current authentication type. Thanks for joining us. Have a nice day.
Feb 24, 2011 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
Wireless internet connection issue
Try these steps below.
ø Try to use the website IP address in IE.
ø Disable/Configure Norton Personal Firewall from Norton Internet Security.
ø Disable Windows Firewall.
ø Disable/Enable IE proxy settings, if available.
ø Uninstall Norton by downloading & installing the Norton Removal Tool
If you are not able to connect to the internet after performing these steps then it is not any issue with the wireless and then you need to contact your ISP.
Plz try it and get back..
Regards,
Dreamkam
May 25, 2010 | HP Pavilion dv6000z Notebook
I am unable to locate any wireless networks. also
From your message, I understand that your notebook wireless is not working and you need assistance in this regard.
Let me assist you in this regard.
This issue could be due to various causes. to isolate and resolve this issue I request you to perform the below steps :
# Step 1 : BIOS Update
I request you to download and install BIOS update from the below web link :
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38173.exe
Installation Instructions
1. Download the SoftPaq .EXE file to a directory on your hard drive.
2. Execute the downloaded file and follow the on-screen instructions.
# Step 2 : Uninstall and re-install the wireless driver.
The wireless device drivers may be corrupted or the properties are not set correctly. Use the steps below to uninstall and reinstall the wireless device drivers. Manually delete and reinstall the device drivers.
1. Click Start.
2. Type Device Manager in the Start Search box,
3. Then Click Device Manager to invoke Device Manager window. .
4.On the Device Manager panel, click the plus sign (+) next to Network adapters to display the installed adapters.
5.There may be multiple network adapters. Right click on the Intel or Broadcom Wireless Lan adapter and select Uninstall. When prompted, click OK to confirm removal.
6.Shutdown and restart the notebook. The system will reinstall the proper drivers during startup. Follow the instructions on the Startup Wizard.
Now download the appropriate wireless card driver and install it.
Broadcom Wireless LAN Driver
ftp://ftp.hp.com/pub/softpaq/sp39501-40000/sp39911.exe
May 14, 2010 | HP Compaq Presario F730US Notebook
Go to add/remove programs to your computer and remove the uninstall HP wireless assistant and do the installation process again.
Mar 26, 2010 | HP Compaq Presario F730US Notebook
Unable to contact router via laptop
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that yopu have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
Jan 02, 2010 | Cnet CNBR-914W Wireless Router
Unable to connect mouse to acer laptop
Before you connect your wireless mouse USB adapter to your laptop you'll need to install the software first, after the software is installed follow the steps to connect the wireless mouse USB adapter, this will keep the instalation wizard from popping up.
Apr 01, 2009 | Acer Aspire 5500 5570-2609 Laptop
Samsung R60 plus - not connecting to wireless network
Have you tried setting the wireless adapter settings to the default? Have you tried uninstalling the wireless adapter and re-installing it? Do you have a home network setup with an encryption key?
Sep 10, 2008 | Computers & Internet
Wireless connection for toshiba satellite A135-S4527 laptop
Hi, there are few steps to allow the wireless network to get connected to the internet.follow these steps
  1. Verify that the Wireless hardware is working (Right click the My computer icon then goto properties then hardware tab and device manager.see the network adpater is corrctly installed.
  2. Then you can check the ip address in the ethernet properties.
  3. Then check the DNS server is connected
if it is not working , i have one web site here you can see the settings and devices to connect.
http://www1.umn.edu/adcs/network/wirelessxp.html
try it and inform to fixya.com
Apr 19, 2008 | Toshiba Satellite A135-S4527 Notebook
HP Photosmart C4580 All-in-One InkJet Printer Logo
134 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
