Question about Whirlpool Dryers
Dryer LFE5700WD I removed the thermostat to replace and I didn't note which wire goes to which terminal. I am replacing it with a single pole double throw thermostat.
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
What is the part number?
Posted on Dec 04, 2012
  • 4 more comments
  • Harold Smith Dec 04, 2012
    The replacement part number is: Whirlpool part #279054. I need to know which terminal, either #1 or #3 gets the red wire. Or, doesn't it matter?
  • Richard Roth
    Richard Roth Dec 04, 2012
    It doesn't matter which way it goes Harold.
    It doesn't matter for the high-limit thermostat? That's great . The installation instructions for the thermostat kit says to connect them in the same order that they were removed.
  • Richard Roth
    No, it doesn't matter at all.
    Thanks so much for your help. It means a lot.
  • Richard Roth
    Richard Roth Dec 05, 2012
    No problem Harold. Thanks for using FixYa and have a great holiday!
3 Suggested Answers
Jahn27
  • 1554 Answers
SOURCE: I'm intalling Maytag part number LA1053...
The thermostat and the thermal fuse do not have polarity so it does not matter which wire goes to which terminal.
Posted on May 23, 2010
  • 472 Answers
SOURCE: fridigaire dryer GLEQ642AS2 running but not
sounds like you started checking the right areas first... make sure you actually have correct voltage coming to rear of dryer should be between 220-245 volts at power supply across the 2 outside power wires... check both at same time to make sure electrical circuit is correct.. some people only check 1 leg at a time to ground and thats great but you actually need to check both hot leads and see if your getting the above voltage i stated... if so then is anything working the light on inside or does it tumble at all just no heat... if nothing at all works i would test the thermal cutoff switch located near the heating element but normally closer to the blower assembly... it will usually be a white round /flat disk with 2 wires coming out of it. remove 2 wires and test contuinity should beep at you or give closed circuit. if not replace and then check for obstructions in the heating vent or blower assembly also make sure the termination exhaust point is clear no birds nest etc... if that is not the problem and the unit works just no heat check the heating thermostat located close to the heating element remove the wires and test the same ways as i mentioned above it should beep or give closed circuit indication... if that good move to heating element and check it same way... hopefully one of these are your culprit...if all that looks good possible the timer is bad.... repost with anymore questions and a little more info.... wish you luck
Posted on Feb 10, 2011
Separate 1 switch 3 lights
You need separate wire going to each light.
Here are diagrams:
2 single pole switches, before you started to replace
http://waterheatertimer.org/images/2-single-pole-switches.jpg
Single pole and 3 pole to control each light separately: must identify black wire to each light. If each light does not have separate black wire inside the switch box, then it is not possible.
http://waterheatertimer.org/images/single-pole-and-3-pole.jpg
Add a comment
Jul 05, 2013 | Electrical Supplies
The timer isn't working the dryer isn't heating up. Ran for two hours and didn't lose anytime off the timer and didn't get warm at all?
Hi cdroby1
Replace your timer...its faulty...
Also here are a few things to check for the heat problem
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Please take time to rate me thumbs up
Sep 21, 2011 | Kenmore 64602 Electric Dryer
The timer didn't lose ant time off of it and the dryer didn't get warm at all? What is the problem do you think?
Dryer will not run
1. No power--check fuse & power supply
2. Loose wiring--check terminals & wiring
3. Door switch--make certain door closed properly to actuate switch
4. Defective motor---check motor.
5. Defective timer---replace timer
Runs but will not heat
1.loose wiring--check terminals & wiring
2. Defective thermostat--replace thermostat
3.defective centrifugal switch in motor--replace switch (check linkage to motor)
4. Defective timer--replace timer
5. Open heater element---replace heater element
6. Heat switch set to off----set switch for desired heat
Sep 21, 2011 | Kenmore Dryers
My dryer won't heat and the timer won't advance. I already replaced the thermostat but that didn't fix the problem
Hi christarn1
Here are a few things to check:
Check your Wiring
Sep 14, 2011 | Whirlpool Dryers
13 year old Whirlpool dryer blew thermal fuse. Bypassed to test and found that when door is wide open, dryer heats up to normal temperature. When I close the door, the heat automatically goes way down to...
Hi JWillett06...
My thoughts are to change the door switch...
Check out some of the solutions below...
Check your Wiring
Sep 14, 2011 | Dryers
What is the most common component to go out on a lec5000 model dryer, when no heat is being produced
Hi zandova1...Normally it it is the heating element that goes bad, but there are many other possibilities.
I will send you some things to check and how to check them
Check your Wiring
Sep 12, 2011 | Whirlpool Dryers
Is there a way to check the thermostat on the heating coil of a Bosch 500 series dryer with a meter? I've got no heat but I have 240 to the unit and the heating coil has contiunity. The thermal...
Hi mk3327...
Try these solutions to your problem:
Check your Wiring
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse, by removing the wires from each of the two terminals and checking each terminal on the thermal fuse,thermostat,thermistor, ect once you have the wires removed.
Then you do not have to tape the wires together as described above.
Sep 08, 2011 | Bosch Dryers
I've got an electric dryer (GE Model #DWSR463EG7WW) purchased Apr. 2010. It is tumbling but is not heating up. Any ideas for what could be wrong? We've turned the circuit on/off and that didn't...
Hi Zippy478...
Check your Wiring
Sep 01, 2011 | Dryers
The dryer can take an entire day to dry a single load of laundry.
Hi ted wilby...
Check your Wiring
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
To test your thermostat/thermistor/thermal fuseremove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it.
This is a FREE answer, Please take time to rate me
Jul 17, 2011 | Samsung Dryers
No heat from the dryer. I replaced the thermal fuse but that didn't do it
Hi vferrante...
Check your Wiring
Jul 09, 2011 | Kenmore Dryers
Dryers Logo
267 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
