How to chang IP address in konica 7085 - Office Equipment & Supplies
  • 8 Answers
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Posted on Feb 02, 2008
SOURCE: getting the ip address
To print out machine current ip address, go to utilities, user setting, printer setting, print reports, configuration.
Posted on Mar 23, 2008
Kevin Hayes
  • 167 Answers
SOURCE: I need the default ip address for the Konica Minolta C350
Press the Utility/Counter button.
Administrator Settings - password is 12345678
Network settings
TCP/IP settings
Posted on Feb 17, 2009
  • 158 Answers
SOURCE: I have a konica bizhub
1.press the utility/counter button
2.select the administrator setting button
3.enter the password 12345678
4.select network setting
5.select tcpip setting
press forward button until you reach the tcpip addres section then you can change the address
Posted on Nov 25, 2009
xeerie
  • 347 Answers
SOURCE: Konica Minolta 250bizhub is this compatible with bt home hub 2.0
if you changed the hub then you have to re assign the ip. to re assign the ip, go to administrattor mode, then in this mode, go to admin 2, in admin 2, go to basic settings, then in basic settings, change the ip of the machine. consult from user manual to know how to get in "Adminstrator Mode"
Posted on Jun 19, 2010
How to change ip address to konica minolta dialta 470 or connect to printer from computer
work out ip address of computer like for example usually 10.0.0.2 or 198.168.0.2 submask 255.255.255.0 then go to printer and select settings - network settings - ip address and put in xx.xx.xx.253
xx.xx.xx is the network address like 10.0.0 or 198.168.0 and the same subnet mask as computer is using. .
computer run
dos prompt
type in
ipconfig
press enter key
Jan 23, 2017 | Konica Minolta Office Equipment & Supplies
Hi, Our Konica Minolta printer c203 with reserved dynamic ip address in dhcp (windows server 2008 r2) won't print. Should I assign a static ip address? Kevin
it will be easier to set the copier up with a static ip. then the server can find it easier. to do this go into admin mode and change it.
Sep 20, 2011 | Konica Minolta Bizhub c203 Copier
Konica Minolta 250bizhub is this compatible with bt home hub 2.0 - the ip address previously set before home hub is not being allowed. is it quicker to change ip address or to change hub settings.
Apr 07, 2010 | Konica Minolta bizhub C250 All-In-One...
Just installed printer and drivers via a network connection for Vista 32bit. I did this per the instructions Provided by Konica at ftp://ftp.minolta-qms.com/pub/crc/out_going/manuals/misc/km_vista...
I presume that the IP Address in the instruction is just an example IP Address. I don't know if your printer is connected to a router or to a Hub or Switch, but your printer's IP Address should depend on the device that provides the IP Address and the example is router. The first 3 octet of the Printer should be the same as the router's. So the setup should be router->printer then router->computer.
Feb 03, 2010 | Konica Minolta magicolor 2430 DL Laser...
Printer not receiving information from computer
I guess you mean the c350 is not printing while Windows said the job has been sent? If so, it may have changed IP Address from the time you first install the Printer on Windows. Check the Ports setting of the c350 printer! e.g. d53b002.jpg
Network Pritners should have Static IP address or at least a reserved DHCP IP Address. Logon to your Router, check the MAC Address of the c350 and reserve/assign it a IP Address near the end of the DHCP range. Save the Router configuration and power cycle the c350. Confirm IP Address changed to the reserved IP.
Then you have to change all the PC's Printer Configuration of the c350's Port to update the reserved/assigned IP. Or remove the c350 from Printers and Faxes, then run the printer setup software again.
May 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Network settings
TCP/IP settings
Oct 29, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Feb 01, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
jasbo
jasbo
