Question about Clarke Power Products Clarke 130EN Wirefeed Welder - 110 Volts, 130 Amps, Model# WE6523
I need to find adoptor WE6550 to hook up the gas.
It hooks to the small plastic line on the inside of the welder so you can put another hose from that connector to the pressure regulater.The manuel says to get it where i got the welder, but they don't have it.
2 Suggested Answers
luis_david
  • 407 Answers
SOURCE: i need adaper clarke we6550
Hi:
You can standardize your gun consumables by using tweco products which you can find availability at any welding store (like Praxair).
First get rid of current gas nozzle (tip holder) and install a tweco 35-50 gas nozzle.
Second: Contact tip tweco 11-35 (or 30 depending on your wire size)
Last: the nozzle; a tweco 21-50 that includes the insulator if you are using gas, for innershield (no gas) wire, use LINCOLN nozzle KP1939-1.
All items are cheap, you won't spend more than 20 bucks.
That's all.
Posted on Feb 26, 2011
How to get a piece of headphones out of the headphone jack
Try a vacuum cleaner, if the unit is small enough, place it inside a plastic bag, put the hose in one end and tape the bag securely to the hose. Turn it on and once the bag collapses it may pull it free.. Or use a safety pin, bend the tip into a small hook and try snagging it.
Feb 07, 2015 | Audio Players & Recorders
As im fueling up gas comes out fueling tube have to fuel up slow on my 2004 kia sodona
take a wire coathanger and make a small hook out of it with a pair of pliers..make the hook small enough to go in past the nozzle door in the fill pipe..using the entire length of the wire run it in and out of the filler and look for any obstructions inside(like a wadded up plastic bag or similar item) this is a prank thing with kids..if it continues..contact a salvage yard about another filpipe..it may have a collapsed hose under the car..you can also blow air into the tank and see if the vent hose is plugged up..
Dec 16, 2013 | 2004 Kia Sedona
2004 Suzuki Forenza is the 2.0 engine an valve interference motor
does anyone know where the small water hose goes on the back of the engine. there is a small hose hooked to a heater hose running behind the engine.one end hooks to heater core. the small one is about the size of a gas line.
Aug 17, 2011 | Suzuki Forenza Cars & Trucks
The person who fix my car stated there was a hose that he did not hook back up because he didn't know where it went after he dropped my gas tank two weeks later my tank light is on and my car has...
You need to take it to another mechanic-the fact that this person dropped your gas tank and did not know what hoses went where says all there is to say about his skill at repairing cars...you issue is probably either a fuel line that is not hooked up properly or a evaporation line that is causing your stalling, regardless no one is going to be able to answer this question, it has to be looked by a competent mechanic.
May 31, 2011 | 2001 Ford Taurus
I have a 1996 oldsmobile aurora and my problem is one of my gas lines has a small drip, so how do i change it out myself
have a 1996 Aurora. under the hood the plastic gas lines 2 are hooked up to the carb but one is broke off,does this have to be hooked up?
Aug 03, 2010 | 1996 Oldsmobile Aurora
How to replace a craftsman weedeater gasline?
you hook one line to it the return line inside the tank
The line you used as a return line pull it back thru the gas cap hole and put that piece on one end of that line and pull it back in the tank until it stops and then hook the return line back where it belongs
May 14, 2010 | Craftsman Garden
On weedeater blower and vac gas line is broke from carb into tank does it just connect to fuel filter in tank model 1925
Yes if your asking about the fuel line yes it hooks to the filter out thru the wall of the gas tank straight into the carb. if it broke out side the tank you can try a smaller plastic hose to stick inside to reconnect the two parts. if it broke inside the tank try to replace as one hose.
Jul 12, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Convert flux to mig
need to buy a gauge set up , these usually come with the hose and gauge,just attach in the back and hook up your bottle..
Mar 16, 2009 | Welding Tools
Mcculloch 3216 starts few seconds and dies, choke must be closed.
after jerkin fingers bloody today same problem i took carb apart,,the old hoses deteorated an clogged screen on in take side/// inside of carb plate //of carb,,blew out with choke cleaner,, reassembled now runs well make sure to run same size hoses large an small,,as original other wise floods out,,,
Mar 03, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan #2550 farmhand saw, Put a new carburetor on saw still not getting gas to carb?
Try emptying the fuel tank, and with small flashlight inspect the fuel line and the sump pick-up screen inside the tank. You may be able to gently retrieve it with a stiff wire hook. See if the hose is cracked/broken of if the screen is clogged. If all is well, be sure there are no kinks in the entire fuel line.
Hope this helps
Feb 23, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Clarke Power Products Clarke 130EN Wirefeed Welder - 110 Volts, 130 Amps, Model# WE6523 Logo
88 people viewed this question
Top Clarke Power Products Welding Tools Experts
 Kenneth
Kenneth
Are you a Clarke Power Products Welding Tool Expert? Answer questions, earn points and help others
