Toshiba satellite dvd-DOM driver not working - re: your reply
You replied to my problem that if the drive showed up under "my computer", it was a hardware problem and that I could probably get a USB plug-in external drive. But it does not show up under "my computer," so I think my problem is with the software (the driver), which as you said is embedded in my manufacturer-loaded Windows. So that probably means a plug-in drive wouldn't work either, right? So does that mean I need to reload Windows? But how can I do that if I don't have a working disk drive? (And even if I could, does that affect the document/photo/other uploaded software and files on my computer?) Thanks for your Step 2 suggestions!
--Jillian
  • 928 Answers
Try this first. put the Windows CD in the computer then restart your computer. If the selection comes up PRESS ANY KEY TO BOOT FROM CD then that means the CDROM still works. If it does not then that means your DVDROM is indeed defective. A simple option that you can do is order a DVDROM from the manufacturer. Its only held together by 2 screws so its easy to replace. So you dont have to reload windows.
Also check your BIOS. When you turn on the computer an option for SETUP is there go into setup and see if the DVDROM is still detected.
Posted on Jan 11, 2009
  • Thomas Lim
    Thomas Lim Jan 11, 2009
    If it does not show up in My computer then here is another way to check. When you turn on your computer it will show you which button to press to get into setup or the BIOS. When you get into the BIOS check if your DVDROM is still detected. That will tell you if the computer still sees the unit. Take note that the BIOS is not driver based so if its there then good if not then that means its defective.
My startup Screen Says Media Failure Check Cables
Go into your BIOS when computer is first turning on press F2 or DEL to enter your computers BIOS look through the settings to find your HDD see it one shows up in your BIOS, then on the same page look to see if there is a cd/dvd drive listed as well, next if you have any flash drives or external HDD hooked to it remove them. After you have done these if your BIOS shows your hardware anyway. Power on you computer and see what happens. If you need more help, or come up with more information about your problem please reply. I will try to assist you further.
Jul 29, 2011 | Toshiba Satellite M35X-S111 Notebook
My laptop toshiba satellite e105-s1802 i am searching drives not avalable
You can download the drivers for your notebook from the link below
Toshiba Satellite E105-S1802 Drivers
If you require more Assistance feel free to reply to this post
Regards, BA
Jan 13, 2011 | Computers & Internet
Dvd drive is not working properly
When it shows to burn the vcd, it means the vcd is blank or does not contain any data in it or it is a fresh cd so that u can write any data in it. In ur case it seems the problem is not with the drive. pls try with some other cd's with data and reply back if the problem still exists.
Thanks
Mar 02, 2010 | Toshiba Satellite A205-S4607 Notebook PC
My A205-S5855 would not boot. I used RECOVERY disks and got system up and running...BUT now the A205-5855 will not recognize the HL-DT-ST DVDRAM GSA-T20F ATA Device (DVD-CD Drive). I reinstalled drivers...
Sad news when ANY company SELLS SYSTEMS but offers such poor driver support!
TRY this YOUTUBE link:
Solution HL DT ST DVDRAM GSA T20N ATA CD DVD device has disappeared
Also be sure to check the other links offered at that address too... in the TEXT replies.
Hope this helps!
Anthony
Nov 26, 2017 | Toshiba Computers & Internet
The dvd is not reading disks you can open it and explorer shows the D drive but there are no files. I have run a driver scan and says driver is ok Toshiba SA 60
Hello my friend, try to clean your DVD Disk drive . You can use Liquid CD Cleaner to ensure the cleaning of your Disk Drive is properly clean. If you don't have a CD/DVD Disk Cleaner kindly check it in the nearest Computer or Video Shop in your place in order to buy and clean your Disk Drive.
Hoe this solution able to help your problem solved. If you need more assistance just reply to this post.
Thank you
geo_jonas
Jul 09, 2009 | Toshiba Satellite A60 Notebook
DVR K17LF Insert a disc
Hi, according to what I understand the unit works for some situations especially but you cannot visualize the content, in this case the problem that you one presents shows off to be Cd-DVD's unit that this trumping, if the equipment this one even in guarantee, you must come to an CAS or Center of Authorized Service, in order that they diagnose and replace the unit
Dec 27, 2008 | Toshiba Satellite A205-S4617 Notebook
Dvd ,cd worn't work
go to Toshiba and look in Help and Support. Type in or check your notebook model in the search, and look under drivers. Your driver should be listed there for dvd/cd rom drive.
Nov 20, 2008 | Toshiba Satellite A135-S2386 Notebook
Toshiba DVD not showing up
Does the DVD drive show up in Device Manager under "CD/DVD drives"? It's possible that either the drive is bad ...or maybe there is a bent pin on the connector side preventing it from recognizing the drive. However, that's kind of rare.
If the DVD drive is listed, is there any "splats" or exclamation marks next to it? If so, I'd first try uninstalling the drive and rebooting. Windows *might* be able to properly install the drive. If not, try downloading the drivers (if there are any for Toshiba drives) here.
Worst case scenario ...if it turns out to be a bad drive, you can always just get an external USB drive, and not necessarily have to replace the factoy unit, which can get expensive.
Hope this helps (a little) :)
Scott
Oct 05, 2008 | Toshiba Satellite A135 Notebook
Computers & Internet Logo
David Payne
David Payne
