Question about John Deere Garden
Own a 2000 BP50 John Deere leaf blower with kawasaki engine.cant find what sparkplug to replace old one
Need type of plug and number
  • 571 Answers
SOURCE: Atwater Strong Lit-r-blo leaf blower parts
Find model no. then go to following site
partstree.com/parts/?lc=kohler_engines&mn+Atwater+Strong+1971+-+60179D
Posted on Apr 13, 2009
  • 2712 Answers
SOURCE: Leaf Blowers types
* Handheld units are the most popular. Available in gas- or electric-powered versions, they're portable and convenient, yet powerful. These models can get heavy while using. Larger models can also vibrate a bit at full throttle. Consider the weight and balance of the unit when shopping. * Backpack leaf blowers are gas-powered. The blower fits in a harness that's worn on the operator's back. The hose reaches to the front where the user operates the throttle and blow or vacuum tube. Backpack blowers are normally used in larger areas. * Walk Behind leaf blowers cover the most acreage. Mounted on wheels, these gas-powered machines are normally the tool of choice for commercial users, but for regular homeowners, they can make short work of a home lawn. Vacuum units use a hose for picking up debris.
Posted on Aug 27, 2008
  • 4 Answers
SOURCE: PoulonPro Leaf Blower will not run properly
the carb has a screen in it it needs to be cleaned out the fuel gets crystalized in the carb when it sits for a while. and if the carb has a high and low on the carb meaning 2 screws on the side of the carb .one is for air and the other is for fuel try this first start it up and give it full throttle and turn the high adjustment till it does something screw it in slowley and or out till it is at full rpm sometimes the adjustment screws do vibrate there way out of adjustment .if it dont work then take the carb apart to clean out the screen
Posted on Nov 14, 2008
  • 148 Answers
SOURCE: Need to know specifications of spark plug for Ryobi Leaf Blower
You can download the manual at www.managemyhome.com. I have the Ryobi 720r and the sparkplug is a champion RDJ7Y.
Posted on Jul 13, 2009
bulldogchief
  • 388 Answers
SOURCE: what type spark plug for the Poulan Pro PBV 200 LE
RCJ6Y is the plug number, you can get them at any home improvement store for about $3
Posted on Sep 11, 2009
What kind of fuel does a john Deere BH 25 gas leaf blower use that is a 2 stroke. And what kind of spark plug is used?
Spark plug is NGK BMR7A gap is .025 Fuel is any gasoline mixed 40 to 1 with 2 cycle oil.
Aug 26, 2016 | John Deere Garden
How do I replace the primer bulb in my JOhn Deere leaf blower?
well model number would help here but if its carb mounted its usually help on by 2 or 4 srews
Oct 11, 2013 | John Deere Garden
What is the spark plug gap for a john deere BH30 leaf blower
if you have the manual it will tell you the type and gap for it
Jan 28, 2011 | John Deere Garden
I have a John Deere 2E leaf blower. Lately it has been hard to start but runs fine once it is up and running. Would it help to adjust the H or L screws on the carb?
The H (High Speed) and L (low Speed) should not typically need adjustment. What happens is the diaphragms get stiff and do not operate efficiently. If the unit is over 5 years old and/or the fuel is not completely drained with the unit run dry at the end of the fall, then I would suggest replacing the diaphragms within the carburetor. This along with spark plug change, air filter cleaning and a check of the muffler to insure it is not clogged is considered a basic tune-up.
Sep 27, 2010 | John Deere Garden
What Engine Model Number is in a John Deere LT166
http://www.deere.com/en_US/govsales/purchaseguide/PDFs/124_125.pdf
Will give you all the info you could need about the LT 166.
The LT166 uses a 303777 Briggs & Stratton Engine
The LT180 uses a FH500V-AS32 Kawasaki Engine, 4 Cycle
The LT190 uses a FH580V Kawasaki Engine.
The LX289 uses a FD501V-DS04 Kawasaki V-Twin Engine.
The X354 uses a FH721V Kawasaki with 4 wheel steer.
Hope this helps.
Apr 13, 2010 | Garden
I have a John Deere hand held blower. I can't get
Your adjustments to the carburetor may make it worse.
Plus if the fuel mixture is over 30 old, I would replace it.
Manufacturers have told us this year any gas over 30 days old is considered bad gas and needs to be replaced. I would try some fresh gas(from the station) and some new 2 cycle oil at 40:1 Ratio(3.2 ozs 2 cycle oil to 1 gal of gas).
Good day.
Nov 07, 2009 | Garden
Manual for john deere leaf blower
you have to order the Manuel from john deer or a john deer dealer
Oct 12, 2009 | John Deere Garden
John deere 17hp kohler
Make sure your electronic ignition (modular, coil, or whatever you want to call it) is not the problem. Check this by replacing old plug with new (I'm sure you already did this), but before putting the new plug in connect it at the top to the ele ign wire, then lay it on the machine or any piece of metal, (screw driver will do) then try to start the engine. Watch to see if you have fire between the spark plug and the metal. If not it is the ele ign that isn't any good and must be replaced.
Jun 14, 2009 | John Deere 42 in. EZ Trak Bagger
John deere js60 lawnmower
Hello:
It Sounds like the Carburetor Requires Soaking and Cleaning.
You can View a Breakdown of this Unit at the Following Site Addy.
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
Enter the Model Numbers JS60 and then Select the Sectional Index. Now Select the Section of the Mower or Engine you Wish to View.
Hope this Helps.
Good Luck
Respectfully
John
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
484 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
