Question about Samsung SCX 4521F All-In-One Laser Printer
My samsung printer scx 4x21series is printing with black stripe line on the paper,what must i do for it to start printing normal again?
When i cleaned the toner,it stoped,but later started again with a bold black stripe
    New Friend:
The problem is the scanner unit, you can try to verify connections, clean all contacts
Best regards !
Posted on May 01, 2014
    New Friend:
Sir my printer mobel is scx-4521fs ...
how to install drivers in ubuntu 12.04
Posted on Dec 04, 2012
SOURCE: faded stripe down the printed page
I found a solution that worked to eliminate the faded black stripe down the page thanks to a post by slamfix in another forum. The problem is related to ink build up on the blade edge of the black developer assembly in the imaging unit (the imaging unit contains 4 separate developers - yellow, blue, magenta, and black). The solution involves taking out the imaging unit, removing and cleaning the blade edge of the black ink developer until smooth. It took me about 15 minutes to complete and was fairly straightforward.
Detailed instructions with pictures can be found at http://losingambition.com/clp300imagefix/
Posted on May 02, 2009
SOURCE: samsung scx-4200 refilling second time
CAN I RESET MY SAMSUNG SCX4200 TONER CHIP MANUALLY BY SOLDERING
Posted on May 03, 2010
  • 220 Answers
SOURCE: Samsung CLP-300 poor print quality
black developer on drum worned out,need changing.
Posted on Jul 03, 2009
SOURCE: Samsung CLX-2160, keep getting faded
Everyone will tell you that it's the Imaging Unit - happy to say that's not true. If it was the imaging unit the colors would not come out right either. I bet if you print a test page that all the colors come out fine across the page. It's only the black.
Also - if you replace the black toner cartridge, or reinstall your printer and drivers like some people will tell you - still no results.
The problem is in the black toner cartridge PATH inside the printer. Something has jammed it up a bit. Try taking out the black cartridge and blowing firmly into the small hole at the bottom of the spout that looks to have a sponge inside. Use a straw and make sure your air blown is dry. Then lightly tap the cartridge a few times. Then use the straw and once again blow very firmly inside the receiving path (inside the printer) for the spout on the cartridge. Make sure you are blowing into the spout path at the bottom - not the gear drive path in the middle - as that will not do any good.
Replace the cartridge, warm up and print another black and white page. You should see that the faded out section is gone or diminished in size. If it is not gone, simply repeat the above steps until it is gone. You will see that the faded out strip gets smaller and smaller each time until it's gone. I had to repeat five times, but eventually got it corrected. Now prints like brand new so don't get discouraged.
Loki
Posted on Jun 30, 2009
datizgreat
SOURCE: Striped line down right hand side of printout
the drum of the printer may be damaged. check if there's a noticeable line. replace if so
Posted on Jul 27, 2012
Samsung scx-4521f xerox and printout taken a black vertical line appear on the paper
black vertical lines are generally an indication that the imaging drum needs to be replaced
Nov 25, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Black streaks on paper while printing or copying on scx 4725fn
Locate and check the printer drum. You should be able to see the mark that is causing the line on your page. It could be s scratch or a ring of toner that the wiper is not picking up because a nick or something under it. Try cleaning the drum with a very soft dry cloth and inspect it again. If the mark is still there the drum will have to be replaced. Do Not Try To Clean The Drum With Any Type Of Solvent!
Apr 15, 2011 | Samsung SCX-4725FN All-In-One Laser...
The printer prints thick lines in the work
Open the toner and see if there is no trace of ink attached to the drum (green cylinder). Try to clean the surface, if the damage or the results remain striped print, you should replace the toner.
Mar 26, 2011 | Samsung SCX 4521F All-In-One Laser Printer
My Samsung SCX-4200 printer says '[No paper] Add paper,' when it actually has plenty of paper. I've tried switching off both printer and computer at the wall, after which it will print just one thing but...
hello,
please remove your paper cassette.
and there have paper sensor(it's black colour and its like a hook) between paper cassette and machine.
it's broken
you have to replace it.
good
Jan 31, 2011 | Samsung SCX 4200 All-In-One Laser Printer
Hi I have a Samsung scx-4521F I am trying to send and receive Fax over IP now I know that I have to change the Baud rate to the lower one. but How can I do that? other than changing Baud rate what do I...
I have a samsung scx-4521f i am trying to copy some document but i cannot copy clean. my printer was copy in document black line or black paper ground what do i need to clean copy ? please help me.
Sep 18, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Won't Scan
try scanning through your computer printer/scanner programs. This is the only way I could get my Samsung to scan anything
May 20, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
SCX-4200 jam
remove the toner box then clean the black colour roller with a wet smooth cloth.
May 05, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Samsung SCX-4216F feed wheel
Clean the Feed Roller In the middle of the printer. Take the paper tray out- you will see the roller in the middle. Send a print job with paper tray removed. Press the black thing to fool the printer that it has paper. You will see the feed roller move. When it is in the position you want to clean- open the toner door and it will stop moving so you can clean it. Isopropyl alcohol and LINT FREE CLOG.
Nov 07, 2007 | Samsung SCX-4216F All-In-One Laser Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
249 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
