Question about Hotpoint HSS25GFP Side by Side Refrigerator
Ice despenser water fill will not stop - Hotpoint HSS25GFP Side by Side Refrigerator
    Top Expert:
  • Hotpoint Master
  • 9,472 Answers
Does it overfill and stop or did you need to cut the water supply off to the unit?
Posted on Dec 04, 2012
3 Suggested Answers
  • 5 Answers
SOURCE: water despenser stop working ice work on both setting give crushe
I had the same problem. I found the answer on this forum.
The water line could be frozen in the door. Need to 'thaw' your door.
http://www.fixya.com/support/t1247133-no_water
Copy paste link.
Posted on Dec 10, 2008
BarrettDenCo
  • 1772 Answers
SOURCE: The water stopped flowing from the despenser. So I
gfd
dfg
Hello and sorry to hear about your problem.
90% of the time you will have 2 issues, the water lever switch has failed or the main water inlet valve has failed.
I have tried to help you. So please help me and Vote/Rate this response. Thanks and good luck.
If you live in the Denver Area, I can help you.
Posted on Jan 01, 2011
Testimonial: "COOL!"
Whirlpool mod.ed25pqxfw1 will not despense ice. motor will not run. is there a test procedure?
I found a parts manual through Whirlpool and it says your ice maker is mechanical type. Fill with tap water and let freeze and if ice maker cycles and dumps the ice but does not refill the the water control valve part number 2182106 but that number has now changed to 2188542. Try this test first and I will send the parts manual and user manual. The test will point to what is happening like water control valve or the fill thermostat inside the ice maker, Thanks, Sea Breeze
Mar 17, 2010 | Refrigerators
I have a side by side that has the ice maker in the door, when it makes ice cubes, they come out all connected and this makes it difficult to get ice to despense from the shoot and most of the time it will...
It sounds like you have too large a fill of water in the ice maker. If you remove the ice maker there is a fill adjustment screw under the cover of the ice maker.( the only way to get the cover off is to remove the ice maker)
Very small plastic screw head of about 1/8 inch or less. Ice maker controls water valve by time fill. Believe there is one turn adjustment total available. You might want to put a small hole in the cover before you reinstall it to adjust screw the next time without removing ice maker, believe it will be side facing out. Lastly I think you turn adjustment screw in to decrease and out to increase time of fill.
Suggest leaving a towel on the floor for awhile until you have solved problem.
Next thing to try would be a different ice maker, or if normal sized ice is melting and refreezing in the bin, you have a cooling or thermostat problem .
Good luck
Mar 07, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
It despense water, but does not make ice
Either the water valve is bad or the icemaker is bad, assuming it is turned on.
Check the valve with the wires off with an ohmmeter.
If it shows continuity, the icemaker is bad.
Mar 03, 2010 | KitchenAid Superba Architect KSCS25INSS...
Hi,I have a GE 42" Monogram refrigerator,model # ZISW42DYB,serial #LS037072. The problem that I have is the freezer is leaking water even if I turn the ice maker off.In a day or two the ice tray fills with...
Good day Paul.
Sounds like your diagnosis is right on. In extremely rare cases the ice maker itself could be at fault. But once again is extremely rare.
Dec 12, 2009 | Refrigerators
Whirlpool Ice maker4 issue
Sounds like the optics are bad part # 4389102 this model(if we have the right model#)has two optics boards one receiver one emitter on either side of the door opening which shoot a beam from one to the other through the opening in each side of the bin,as long as nothing blocks that beam and the freezer is cold enough to chill the thermostat to temp in the icemaker,then it should be dumping ice.
Sep 13, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice maker stopped working
Did you ever get a solution? Ours just did the same thing. One day working, then just stopped making ice. Water is on and working fine.
May 07, 2009 | Maytag MFI2568AE Side by Side French Door...
GE LXS18JFBLB-2 MODEL WITH BRITA WATER DESPENSER ON DOOR
sounds like clogged water drain
in a side by side it is located in freezer section at bottom
in top freezer ref it is in freezer too but behind back cover
if either are iced over remove ice and pour sum really hot water down drain until u see it go down
Jul 09, 2008 | Refrigerators
Ice maker not workin
ok as far as the water in your door goes sounds like the micro switch is getting a little gummy and sticking this happens when people dump ice in sweet drinks and some splashes up locate the switch and spray a little wd 40 on it as to you ice it is on a separate valve as the water in the door so the water flow don't mean a lot in this case remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure yuo hold the plastic insulation so you don't get bit if the ice maker starts cycleing remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didnt fill replace the water valves if the icemaker doesnt cycle and yuo may have to kinda twistm the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Jan 18, 2008 | Whirlpool ED2FHEXN Side by Side...
Water despensing all of a sudden very loud
needs to defrosted and the filter needs to be changed
Dec 24, 2007 | LG LSC26905TT Side by Side Refrigerator
Hotpoint HSS25GFP Side by Side Refrigerator Logo
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
