Question about Siemens Washing Machines
Is my siemens washing machine total /Textile Management S 14.39 a cold water fill
  • 10 Answers
SOURCE: washing machine no cold water
chnge your water valve or your cold water hose. something could be blocking up your hose. also when you ask machine for cold water does the machine hum? if so check to see if cold water is on. if the water is on then replace your water valve.
Posted on Feb 10, 2007
AlmostBob
  • 550 Answers
SOURCE: kenmore heavy duty washing machine 70 series
The most likely cause for water fill temperature problems is the solenoid has burned out, usually cold first, it gets used more. Not a repairable item , easy to replace
Posted on May 25, 2008
SOURCE: washing machine wont stop filling with cold water
Since you removed the screens, the sand probably has entered the valve and damaged the spool. It's apparently sticking open. You need to replace the complete valve and keep the screens in place.
Posted on Jun 09, 2008
jyackle5
  • 8197 Answers
SOURCE: my siemens washer will not pump the water out or spin
Sounds like your pump went out on the machine. They are not ease to replace though. You might want to kall some one out to fix.
Posted on Dec 16, 2008
canbruce75
  • 1776 Answers
SOURCE: my washing machine will fill with hot water only,
Check for a cold water supply problem by taking a look at the water inlet valve. Remove the water supply hoses and check the small metal screens inside the openings on the valve (especially the cold water side). Make sure they are free of rust or debris. Check the solenoids. They can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid and the water inlet valve assy will need replaced. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 12, 2009
Siemens WE61021GB/01 displays error code 03
http://teral.ru/katalog_stiral_nyh_mashin/siemens_simens/?p=6
best i can do is google translate
F03 is
Drain alarm (water in the tank is reduced to one level in the allotted time plot )
you ran out of time for the drum to fill
{too low pressure}
use the hot water valve as the cold
block off the hot water intake
this way you have a low pressure valve for cold
or
    1. There is a poor connection at terminals bilge pumps - seal the clamps, clean the terminals. 2. A malfunction in the bilge pump - clean the filter pump washing machine Siemens (Siemens) to either replace it. 3. There was a problem with the drain hose - hose to clean from pollution, eliminate the excesses, to restore the position of the drain hose specified in the instruction manual. 4. The pressure switch is faulty washing machine - repair of hydraulic water level sensor or replace the pressure switch.
Aug 11, 2014 | Siemens WE61021GB Front Load Washer
F17 coming up on screen what is this fault
use google translate
Malfunction of the water of the Gulf ( the Gulf of spent more time than envisaged by the program ) .
lol
so your water intake is too low a preasure
try too use low pressure valves for cold water
if you have low pressure
then use the hot water valve in the cold water
cold water valves are like 2-3 bar intake
hot water 1 bar or less
so work better for low pressures intakes
or there is a flow filter on the back of valves
you need to remove it with plyers and clean it
moreover check the valve opens
but this is what F17 means... no water in in the right time for it too be in {low pressure}
good luck
Jul 08, 2014 | Siemens Washing Machines
Cold Fill Siemens Does Not Get Hot
yes this could be the heating element or thermostat
May 29, 2013 | Amana ALW880WH Top Load Washer
Cold Fill Washing Machine Does Not Get Hot
Do y7ou have 2 hoses at the back of the machine one for cold water and one connected to the hot water tap of the house. If not then you have a cold water in only. If you have 2 hoses have you connected the hoses into the machine correctly Have you checked to see if your machine has a heating element under the bowl for heating the water. As an appliance shop to verify if you have by the model number of the machine. otherwise you have a cold washing machine and unless you can plumb hot water to it that is all you will have.
May 29, 2013 | Siemens Washing Machines
Maching not taking in water
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 26, 2011 | Siemens WXL132GB Front Load Washer
Washing Machines Logo
47 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
