Question about LG Televison & Video
I cant tune in on auto my LG 42LM6410
Out of the box connect and run auto tune it does not pick up radio or tv chanels it reads on the screen no antenna connection
snakehead
  • 1074 Answers
SOURCE: Problem with chanels on Magnavox LCD 20in TV/Monitor
check the tuner or the IF circuit they could be defected.good luck.
Posted on Apr 19, 2007
dvdcdlaser
  • 1285 Answers
SOURCE: my tv wont pick up any channels
have you switch the broadcast to Air from Cable using the remote go to this and also let it scan for channels auto...hopefully this will do the trick
Posted on Jul 26, 2010
  • 11800 Answers
SOURCE: I bought an LG 32LD460.
The tuner inside the tv has failed - which is quite odd since you just bought it. Take it back and recover your money, you got a lemon.
Posted on Aug 09, 2010
  • 23 Answers
SOURCE: My 32LG3000 is flashing 'Not
Try changing the source from the tuner, which is not programmed, to "video 1" or whatever the input for your Sky HD Box is plugged into. I would suppose as soon as you change the input method to not be your tuner, this error will go away.
Posted on May 06, 2011
  • 115 Answers
SOURCE: i need to tune my
I have no idea what an antennae connection is. I assume you are talking about a Coaxial cable converter (large box that connects in line on the cable input). If this is the case, the box is override either channel 3 or 4. It either has a switch to pick which one of these to use or it is written on the box which one it uses.
If you are using a VGA connection (3 pins with 1 yellow, 1 white, and 1 red connector), then you have to find the AV channel. Every TV has one, unless it is like 4 decades old. If the TV is a few decades old, it may not have a channel called "AV" or "AUX". For example my dad's 25 year old TV uses 91 as the AUX channel. It is common for channels in the 90's to be used for this or channel 0. Best to just turn all the manually add/remove channels while the box is on. Then you can spot the right channel and add it to the listings.
Posted on May 09, 2011
I run the auto scan and it is picking up 0 channels and say to please run auto scan
Where is your antenna hooked up? Thru a cable box? Direct to tv? Completely describe setup, maybe post photos
Apr 02, 2015 | RCA Lg 65lm6200 65" 3d Led Flat Panel...
Have to tune in channels when turning tv back on
Talk to LG to see if a KNOWN issue for your model.
Jun 26, 2012 | LG 32LC2D Television
I can't find UHF channle 36
Turn plasma to analoque tv tuner auto search while xbox is connected and turned on. Auto tune will pick up uhf 36 channel .Flick chanelstill xbox chanel is viewable
Apr 19, 2009 | Hitachi 42PD7200 42 in. HD-Ready Plasma...
Unable to tune in and get picture/chanels
try to reset ur tv to factory setting.....should be in ur instruction booklet...when done try to set to automatic channel search and it should find Chanel for ur area
Mar 14, 2009 | Televison & Video
Channel search: skips chanels
If you have a cable box connected, it's synch circuits are bad. If your TV has a selection for HRC/ IRC make sure you know which one cable company is using .
Apr 15, 2017 | Polaroid FLM-1911 19 in. LCD Television
PURCHASED 52" LG LCD HAD A GREAT PICTURE.ALSO HAVE DIRECTV. TOUCHED THE MENU BOTTON SAW THE AUTO TUNING, THOUGHT THAT WOULD BE A GOOD FEATURE. WENT AHEAD AND LET IT RUN THROUGH ALL THE CHANELS. NOW IT...
Because you have DirecTV there is no need to use auto tuning. You simply changed inputs on the TV when you started auto tuning. Just use the input button on the remote to go back to the Direct TV receiver. Most likely it will be under Component (Color Stream) or HDMI input.
Dec 31, 2008 | LG RU-27LZ50C 27 in. HD-Ready LCD...
Tuning TV onto AV chanel
How do I get the TV screen back to an AV chanel?
I cant get a slide show to view on the TV screen.
Apr 01, 2008 | Televison & Video
Panasonic DVD Recorder - Digital tuner stopped working
Is your recorder hooked up to the new convert box for digital antenna reception?
I am currently researching the convert boxes for my dvd recorder. I found that some dvd recorders already have digital converter boxes already installed. This might be the case for you.
Mar 08, 2008 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
Jan 30, 2008 | Televison & Video
Televison & Video Logo
26 people viewed this question
