Question about Hoover Washing Machines
Hoover vhw458 show error e16 or e03
Error e16
BIKER T
  • 909 Answers
SOURCE: Hoover oph714d - error code e16. What does it mean
Where in the program is this happening?
Posted on Sep 20, 2009
  • 193 Answers
SOURCE: error code E03 on washing machine
eo3 water not draining,check for kinked drain hose,check that drain filter is clean
Posted on Sep 28, 2009
richroth
  • 9472 Answers
SOURCE: My Hoover VisionHD washing machine
E16 is for an "open circuit" on the heater.
Posted on Jan 03, 2011
  • 6277 Answers
SOURCE: error E03 on Hoover optima
Sorry but I do not know your particular machine and I do not have the cause of the E03 BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. It's worth a try and it needs doing on a regular basis anyway!
Here are my complete, general pre-typed guidance notes for checking both the filter and the motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 14, 2011
FitzOriginal
  • 842 Answers
SOURCE: hoover washing machine Mod OPH 714D Error E16 in
After far more research than I usually have to do, It seems that E16 means "O/C Heater"
Which means that the heating element is open curcuit. Which menas......
Either the heater element has a wire off at the back, or more likely the heater element is burned out.
They are easy to replace. Pull the machine out and remove the rear inspection plate at the bottom of the body (I think this machine has one!, sorry if it doesn't).
At the bottom of the drum, you will see a atainless steel cover, about 4 inches limg and a third of an inch wide, with rounded ends. There will be 2 spade connectors with wires in them (1 either end of the plate) and a 10mm nut in the centre. The nut tightens up a squeeze plate inside that crushes up a rubber seal to hold it in place. Undo the nut fully (you may have to push the little stud bolt that is now exposed in a little to free it off) The element should now withdraw if you grab hold of the spade connectors and tug a little to break the seal before you withdraw it.
Replacement should be the reverse of removal.
Google "Hoover washing machine heating element" to find yourself one on line, or ho to your local Hoover parts stockist
Posted on Jun 30, 2011
Testimonial: "thanks for your help great, having more problems now so it has to go!"
E16 ON DISPLAY FLASHING
The e16 error code indicates that there is a problem with the machines door lock.
Mar 04, 2016 | Bosch Washing Machines
What does e16 mean please?
An E16 error code means there is a heater insulation problem which could cause the tripping of your fuse box and other random cycle errors, but it's hard to prove without the replacement of your heater.
For more information on other error codes , watch this video .
http://www.espares.co.uk/advice/0/2531/how-to-understand-hoover-and-candy-washing-machine-error-codes
May 15, 2015 | Hoover Washing Machines
MY FRIGIDAIRE DRYER STOPS AND THE DISPLAY READS E16
I appreciate your post, Deejanae!
I see that your Frigidaire dryer is displaying an error code of "E16". It appears that "E16" is an invalid code. I would recommend performing a reset on your dryer and you can do that by flipping the household circuit breaker off for at least ten minutes. If you continue to experience an issue with an "E16" error code I would recommend contacting a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
Apr 22, 2015 | Frigidaire Dryers
Canon mp250 error code e16
How to Reset waste ink counter (Error E16)
1. Unplug power and USB cable.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
Hope it helps.
Jun 30, 2011 | Office Equipment & Supplies
Error E16 RISOGRAPH CR1610
E16 indicates a motor lock with the inking motor. Disassemble the ink pump unit and check for proper rotation of the inking motor itself. This error is caused by a current overload.
Also, remember to try powering on the machine while holding down the reset key to clear all error codes first.
Feb 13, 2010 | Sharp AL 1631 Copier
E16 error message for for canon pixma 210
E16 must be "Ink remaining unknown".Press and hold the "resume" button for 5 seconds.
Oct 15, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
E16 error
Hi there.
E16 Error code means (on all canon compacts) that there is something wrong with the lens mechanism and it cannot contract/extract/focus etc. Basically, if the problem is not fixed by removing the batteries for 20 minutes and reinstalling them (make sure they are fully charged) then you'll have to take it into a shop or get a friend who knows a lot about this stuff to take it apart.
Good luck and thanks for using FixYa!!
May 07, 2009 | Canon PowerShot A85 Digital Camera
E16 error , driving me insane !!!
E16 means that the printer does not know the ink levels. I am unaware of a reset for that.
Jul 30, 2008 | Canon Compatible Toner Cartridge Replace...
E16
press stop reset button for few seconds and you can use your black cartridge for printing,but do remember to put use black only setting in ur printer cartridge settings.
Nov 09, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Washing Machines Logo
95 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
