Question about Whirlpool Washing Machines
My machine is saying clean pump but i dont know how and where it is located i have a whirlepool 6th sense A+.. please help!
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 04, 2012
3 Suggested Answers
  • 1028 Answers
SOURCE: clean pump!
remove bottom panel torx or 7 mm nut driver needed.pump has "knob" turn counter clock wise ..have plenty of towels handy to unlock door first reach up to bottom of door lock tear shaped plastic tab pull down door will open
Posted on Apr 28, 2008
  • 6277 Answers
SOURCE: light on machine says clean
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 14, 2011
I have whirlpool aquasteam 6th sense fromtliad washer 9760. It wont drain the water
Probably you have a clogged water pump clean it if not clogged then you have to know how to check if you have voltage to it, do so if you have 120 volts then it's your water pump http://www.appliancepartspros.com/whirlpool-washer-drain-pump-280187-ap3953640.html
Apr 29, 2016 | Whirlpool Washing Machines
Whirlpool 6th sense washing machine manual
can you hear the pump
there may be something in the pump or in the pipes to and from the pump clean out
Dec 30, 2013 | Washing Machines
Whirlpool 6th sense - pump issue
The drain pump probably just needs cleaned. If you've never cleaned it i can direct you to videos that are step by step. Let me know.
Jan 20, 2013 | Whirlpool Washing Machines
Can't open pump
Dear Sir :
See the diagrams and proceed accordign with common sense.
God bless you
May 13, 2012 | Whirlpool AWM8143 Front Load Washer
HOW DO I LOCATE THE HEATING ELEMENT ON THE 6TH SENSE DRYER
take the back panel off it is located in the rear.
Mar 19, 2010 | Whirlpool Dryers
Clean pump!
Apr 26, 2008 | Whirlpool AWM8143 Front Load Washer
Whirlpool 6th sense awm8163 programes never stops now cannot get it to work at all
The pump is at the lower left of the front of the machine covered by a white plate. Use a bowl to catch any remaining water when opening the screw thread inside and then clean and replace. If it is truely beyond repair then a new filter pump can be bought from ebay for £3 or thereabouts.
I have just drained mine manually in this way and am going to run it empty with soda crystals to glean a few more days use whilst the new pump arrives.
Good luck :)
Jan 20, 2008 | Whirlpool AWM8143 Front Load Washer
Washer will not complete a cycle
hi,
i have a whirlpool 6th sense washing machine, it has come up with clean pump, does anyone know where the pump is on the machine, as i have lost my instruction manual.
regards
jackie
Nov 08, 2006 | Whirlpool AWM8143 Front Load Washer
Washing Machines Logo
75 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
