Question about Motorola Mobility RAZR V3
My Motorola Razr won't ring or vibrate when receiving an incoming call except when plugged in to the charger
  • 1 more comment
  • Anonymous Jan 21, 2009
    I have the same problem tried the obvious things (like put on maximum volume and all that) nothing seames to work out If I will do a master reseat could it healp and how it will affect my current seting in the phone like my contact list and so on... thanx for your help
  • Anonymous Apr 29, 2009
    My Razr also won't ring; changing ringtones doesn't help. Ring style is set to loud, volume is at 7. I'm not getting previews of any of the ring tones as I scroll through them, and my speakerphone also does not work.
  • Anonymous Apr 30, 2009
    yes that is the ploblem.
    it wont ring vibret or open no other file
Turn off the ringer id function in settings, ring styles, load detail, ringer id's off.
Hope this helps
Posted on Apr 17, 2009
  • 71 Answers
All you have to do is go into settings and go into ring styles you will see Style : loud or soft or vibrate or a few others but do not change the ring style change the detail at the bottom you will see what ring tone is set for your calls and text. (Note only change the ring style if it is on silent or vibrate.
(Sol 2) Flip down your phone press one of the volume botton you will see the ring style menu on the outter screen press the camera botton to change your style.
If you don`t know which style to select just plug in your phone charger and you will see the ring style it is in then you will know the ring style to choose.(please remmber to vote and rate me thank you)
Posted on Jan 11, 2009
  • Travis Foreman Jan 11, 2009
SOURCE:
Dropped it - put battery back in. Works for outgoing calls but only vibrates, does NOT RING for incoming calls. Checked Settings--> Ring Styles and changed to Loud (still doesn't ring) and back to Vibe...
You dont hear tones after you dropped it.
This is because the speaker connection may be disconnected due to sudden ****.
You need to contact your authorized motorola service centre to fix this problem.this is a very small problem so no need to worry.
Thank you
Aug 08, 2010 | Motorola Mobility RAZR V3
Change Ringtone Automatically when charging
The BlackBerry gives few profiles to choose from; e.g. Normal, Loud, Quiet, Vibrate.... my recommendation would be to configure each profile separately and just enable/disable the profile you like when you enter/exit your car...
The phone itself is not capable to switching the profile on its own once it is plugged in to your car charger...
Hope this was helpful...
Nov 10, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blocking calls
menu/setting/security/call barring
Nov 10, 2008 | Motorola Mobility RAZR V3
My new Razor will not ring
do a master reset and clear of the phone
May 13, 2008 | Motorola Mobility RAZR V3
Vibration wont work
All I did was wait for it to come back. I think it might have had something to do with the battery being low. However, that's never happened to me when the battery was low. When I plugged my charger in, I got a text message. I had the ring on high and vibrate. It vibrated for a second, then it just continued to ring. Once my phone was fully charged, the vibration came back. I think it was just a glitch in the phone. Razr's suck.
Mar 02, 2008 | Motorola Mobility RAZR V3m Cellular Phone
RAZR v3xx
go to settings and set a ring or vibrate alert do it by going in profiles and edit them
Nov 27, 2007 | Motorola Mobility RAZR V3xx Cellular Phone
Rings when set to vibrate.
you may need to edit the 'settings' or 'details' for the vibrate profile. hope this helps :)
Oct 28, 2007 | Motorola Mobility RAZR V3c Cellular Phone
No sound when phone rings
Look at the ring volume. Make sure it's not at zero. Let me know if that works.
Jul 28, 2007 | Motorola Mobility RAZR V3
Changes ring style when charging
My phone also does this and its something Motorola have built into the phone. Can't change it I'm afraid!
Jan 13, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
2,661 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
