Planet wnap-1120PE slow connection
I'm having a trouble with my access point, when i changed the security settings on the access point the dl speed got mutch slower, the only settings i changed from default settings was the WPA settings
    Novelist:
  • 250 Answers
If you are unable to fix this problem manually then consult the manufacturer website on simply use an Internet Optimizer tool. I would suggest to use Intel Software Partner Reginout - this tool ahs the feature of Internet Optimizer. It will fix this issue. WebRepOverall ratingThis site has no rating(not enough votes)
Posted on Dec 05, 2012
rahul26485
  • 611 Answers
SOURCE: SMC EZ Connect Access Point apparently not connecting to wired router
you doing something wrong there.
give the mac address of smc to the access point that's all you get it
Posted on Jun 20, 2008
Bubbabear64
  • 2794 Answers
SOURCE: (Work this one out) My access point works but I have never been able to set security settings on interrogate it.
First of all the disk isn't needed. Go into internet explorer and type in the ip address of the gateway. A user id screen will appear. By default the user id is admin, the password it linksys. Select Wireless for the links at the top of the router screen. Select security. You will see a screen for generating pass phrases. Once that is enabled a WEP key or whatever security key you decide to use will be enabled.
Posted on Oct 22, 2008
ziraffa
  • 827 Answers
SOURCE: cannot secure my access point
192.168.0.50 is the default for your router. If you are sure that your wireless settings are okay on your PC and that you can see the network in your wireless networks list, then it's possible that your settings have been remotely changed. You can do a hard reset of the router by pressing a paper clip or something sharp into the little reset hole in the back and holding for 15 seconds. This will reset all settings and, once all the lights have stopped flashing and are remaining on, try 192.168.0.50 again, and enter admin for username and leave the password blank.
now you can enable WEP or WPA and choose a password.
Write this down! :)
Also change the router's login passphrase if you wish.
Here's the user manual:
http://209.85.229.132/search?q=cache:YlsOXdTN2H8J:www.dlink-me.com/ftp/wireless/DWL-2100AP/dwl2100AP_manual_100.pdf+D-Link+AirPlus+Xtreme+G+DWL+192.168+ip&hl=en&ct=clnk&cd=4&gl=uk&client=firefox-a
Hope this helps
Chris (ziraffa)
Posted on Jan 08, 2009
  • 52 Answers
SOURCE: Does the Symbol AP 3021 Access Point accept WPA encryption?
on the info i could find it only supports WEP.
but if your issue is to be more secure look up if it supports a sort of mac filter.
this will only keep everybody out of your router but your signal will only be WEP encrypted.
Posted on Feb 09, 2009
toac990
  • 838 Answers
SOURCE: Router working as Access Point, unable to access via we browser
Please try first plug out the router and plug in again then press & hold the reset button till the power led become red and release. If that doesn't work, plug out the router, pressing and holding the reset button plug in the router.
Let me know the result please.
Thanks for joining Fixya.
Have a good day.
Posted on Feb 22, 2010
Testimonial: "Thanks for your answer. It worked"
WIFI router loses security settings after reboot & continual restart AP required
As far as I know, access points support Wi-Fi wireless communication standards through i have encountered such kind of problems like you. Maybe you can reset the Access Point from the very beginning, hope it will be done... And if you think it's necessary to know WIFI and Access Point better, there is an article for you" http://goodrouterswitch.blogspot.com/2012/08/what-is-access-point-and-how-to.html"
Aug 02, 2012 | NetComm NB5PLUS4W Wireless Router
Reset Belkin F8T030?
manual is here: http://cache-www.belkin.com/support/dl/f8t030_manual.pdf
but it seems like you can't reset it with a button or some other procedure
try to connect it to your network and search for it in command prompt by typing arp -a -> will show you list of all IP's on your network
Mar 12, 2012 | Belkin (F8T030) (BKNF8T030) Wireless...
Cannot change transmission rate of Linksys WRT160N
1.With an online-capable game inserted into your Nintendo DS, turn on your system and access the game's main menu.
2.Access the Nintendo Wi-Fi Connection settings.
-These settings are typically found by selecting "Nintendo WFC" from the game's main menu. For detailed directions, consult the manual for the game.
3.At the Setup screen, tap "Nintendo Wi-Fi Connection Settings."
entryscreen3-cwz5mha2srvvin44vycqgk0s-3-2.jpg 4.Tap a connection file labeled "None."
emptyconnections4-cwz5mha2srvvin44vycqgk0s-3-5.jpg -If no empty connection files are available, select "Erase Settings" followed by "OK" to create an empty connection file.
5.Tap on "Search for an Access Point."
connection1settings-cwz5mha2srvvin44vycqgk0s-3-9.jpg 6.The Nintendo DS will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
oIf you receive the error message "No Compatible Access Points Within Range," click here.
7.Tap on the name of your wireless router or access point.
oIf there is a gray padlock next to the name of the wireless access point you wish to connect with, this indicates your router is using a security type incompatible with the Nintendo DS.
If prompted, use the keyboard on the bottom screen to enter the password for your wireless router or access point.
enter_wep1-cwz5mha2srvvin44vycqgk0s-3-14.png 8.Select "OK," "Save Settings," and then "Yes." The Nintendo DS will run a connection test.
9.The connection test was successful - Your Nintendo DS is now connected online.
Situation Not Resolved:
If the connection test was not successful, you will receive an error code:
·Error Code 51300: This means the security code or network name entered into the Nintendo DS is not the same one the router is set to. To reach your connection settings, click "back" on the error code screen. Make sure to pay extra attention to the security key you find in your router's settings and enter it exactly as it appears (the key is case sensitive).
Apr 21, 2017 | Linksys WRT160N Wireless Router
I how can i connect to the internet by uesing my nigbor internet
First of all,you should have your neighbour permision. Then you'll need the security key for his/her
wifi/router. Go to the DS menu, choose system settings and then Internet. Select advanced set up, choose a connection and search for an access point. You should be able to find your neighbours wifi in the list. If you don't know which one it is, ask your neighbour. Enter the security key and you should be connected. However, if your connecting from your house, the connection may be slow or the signal may too weak to connect at all, which means you'll have to get closer.
Aug 23, 2011 | Nintendo DSi Matte Blue Console
If i have wireless internect, how do i link my wii with it?
Wireless Connection
1. On the Wii console's main menu, click on the 'Wii button' in the lower left corner.
2. This will take you to the settings screen. On this screen, click on 'Wii Settings'.
3. In the 'Wii System Settings', click on the blue arrow on the right to reach the second screen of options. On this screen, click the 'Internet' button.
4. Select 'Connection Settings'.
5. Select an open connection, indicated by 'None'.
6. Select 'Wireless Connection'.
7. Select 'Search for an Access Point'.
8. At this point, the Wii console will search for any identifiable Access Points nearby. Once this search has completed, you will be directed to choose the Access Point that you wish to connect to. Click 'OK' to display the list of available Access Points.
9. Select your Access Point from the list of available Access Points.
If your connection appears as a closed padlock, then the Access Point requires a security code or passphrase. The security code or passphrase can usually be found on the security tab of your wireless router settings.
If your connection signal appears yellow or red, the stability or strength of the connection is not optimal. If possible, remove any obstacles between the Wii console and the Access Point. I've also found that changing the channel on your router to channel 1 or channel 11 can sometimes help with singal stability and strength.
10. Click 'Save' followed by 'OK' to save your connection settings...
11. ...and select OK again to start an automatic connection test.
If the test succeeds, Internet Setup is complete and your Wii conosle is wirelessly connected!
Jul 13, 2011 | Nintendo Wii Console
The access point's security settings are not supported by the nintendo DS
This means you've got a WPA/2 security connection on your router/access point, whereas the Nintendo DS only supports WEP or open encryption.
You can:
1) change your security from WPA to WEP on your router
2) Purchase a used nintendo wifi stick
3) Set up a second router or access point with WEP security specifically for your DS
May 16, 2011 | Nintendo DS Lite
All of a sudden, I can't connect to the internet. My network connection is asking for a security key. I have never had to do that before & I have no idea what it is. Please help.
Someone nearby may have created a new wifi network, and your computer is trying to gain access to it. The first thing to do is to verify that you are indeed trying to connect to your own wifi network by checking the SSID of the network. Or, you can physically move closer to your wifi router and see if you can then connect as expected.
If you're still having trouble after that - you'll need to access your router's setup pages via a computer that has a network cable connected between it and one of the LAN ports on the router. Login as usual with your username & password credentials and then change the SSID, encryption and the username & password information. If you are unable to login, then it is very possible that the person(s) that took over your wifi have also attempted to lock you out of it. You'll have to consult your router's manual to learn how to perform a hardware based factory reset. Once this has been done, you'll need to set up your variables for your network again. Make sure you secure the wifi to prevent unauthorized access again. This mean using WPA instead of the comparably very weak WEP security AND then locking down access to the setup page with a new username and password.
I hope this helps and good luck. Please rate my reply. Thanks.
Apr 15, 2011 | Computers & Internet
Cannot get my wii to connect to my charter wireless
To connect a Nintendo Wii to the Internet using a wireless connection, please follow the steps below:
  1. On the Wii console's main menu, click on the Wii button in the lower left corner.
  2. This will take you to the settings screen. Click 'Wii Settings'.
  3. In the 'Wii System Settings', click on the blue arrow on the right to reach the second screen of options. On this screen, click the Internet button.
  5. Select an open connection, indicated by None.
  8. At this point, the Wii console will search for any identifiable Access Points nearby. Once this search is completed, you will be directed to choose the Access Point that you wish to connect to, as shown. Click OK to display the list of available Access Points.
  9. Select your Access Point from the list of available Access Points. If your Access Point is not displayed, contact your wireless router manufacturer for support.
  10. Click Save followed by OK to save your connection settings.
If your connection appears as a closed padlock, then the Access Point requires a security code or pass phrase. The security code or pass phrase can usually be found on the security tab of your wireless router settings. If you do not know the security code or pass phrase and do not know how to login to your router to get it, contact your wireless router manufacturer for support.
If your connection signal appears yellow or red, the stability or strength of the connection is not optimal, contact your wireless router manufacturer for support.
If you still have problems, call them at: 1-888-438-2427.
Mar 28, 2011 | Video Game Consoles & Games
WIFI PHONE NOT RECOGNISING BELKIN WIRELSS ROUTER
the router is not configured by default as an access point.
to use the phone the router must be configured as an access point, which is more than disabling security, nat and dhcp must be removed..
page 53 of the user manual describes the proceedure.
online the manual is here
http://belkin.httpsvc.vitalstreamcdn.com/belkin_vitalstream_com/support/dl/p75170-d_f5d8231-4_man.pdf
Jun 13, 2008 | Belkin (F5D5231-4) Router
Computers & Internet Logo
306 people viewed this question
David Payne
David Payne
