Question about Canon PIXMA Office Equipment & Supplies
Canon PIXMA MX410 is stuck on PC standby and I cannot scan.
I get an erroor code 5,156,61 if I try and scan
5 Suggested Answers
solofixya
  • 34 Answers
SOURCE: Canon PIXMA MP145 Scanner Problem
Take it to a Canon Repair company, It has a 1 year warranty and needs to be replaced or call 1-800-ok canon.
Posted on Nov 10, 2008
  • 214 Answers
SOURCE: Canon Pixma 210 series has an error code 6000, won't print or scan
Hope this helps
With thanks to a canon tech
Ok Well again I will repeat this answer with a titch more detail.
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
Procedure to reset Printer canon MP145 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Posted on May 22, 2009
SOURCE: Canon Pixma MX850 won't scan - says 'set the pc to start scan'
Do you have more than one PC connected to the scanner? I have both a PC and a Mac connected to it, and I think my scanner is trying to connect to the Mac, which requires image capture software to be installed, rather than the PC. Don't know how to tell it to go to the PC, though...
Posted on Apr 10, 2010
SOURCE: mx canon mx320 wont scan,
You go on your computer open the start menu and go to devices and printers. Click on it. Click on your Canon Mx320 icon. Then it will say scanner management and you click on Scan Photos or Documents. The printer is just waiting for you to do it from the computer. From there you can preview the scanned photo or documented.<br /> <br /> Press "OK" in the printer as well.
Posted on Aug 20, 2010
Why has PIXMA MX410 printer stopped working? Re-installed Canon PIXMA MX410 All-In-One Printer on hp pavilion 23 widow 8 x 64, system would only print but menu solutions would not. Then printer stoppe
Driver issue. Uninstall and reinstall driver for win 8 64 bit - should work if same worked before. Did you try a system restore to time when printer was working properly?
Sep 11, 2017 | Canon Office Equipment & Supplies
My mx410 is leaving lines on everything I scan copy or print
clean the flat glass as well as the scan glass
Oct 22, 2013 | Canon PIXMA MX410
Scan slide negatives film
I have had that problem with the MX310.
depending on what IOS you are running
you can get software free that will scan
Transparencies "opposite"
Oct 12, 2013 | Canon Pixma MX410 All-In-One Printer
Whenever I scan a picture, It's blurry. Canon Mx410
I had the same problem.
My DPI setting was at 25.
I upped it to 600 and the document scanned perfectly.
Jun 04, 2013 | Canon Pixma MX410 All-In-One Printer
I have a brand new Canon PIXMA MX410 and don't know how to scan into my computer!
You will have a utility on your PC Named "Windows Fax and Scan" this is in my opinion the easiest and most accessible utility to use.
Nov 18, 2012 | Canon Pixma MX410 All-In-One Printer
Scan and email with mx410 cannon printer?
Scanned document is saved with a file name and in a directory such as desktop. Then attache the file name to an email you send to someone.
Jun 30, 2012 | Canon Pixma MX410 All-In-One Printer
Canon MX410 won't scan from the adf
Thank you, old marine! That fixed my problem!
Feb 12, 2012 | Canon Pixma MX410 All-In-One Printer
205 people viewed this question
old marine
old marine
