Question about Nokia E5 Cell Phone
HOW password can be set in message ?????
I am unable to set password in message. kindly provide the steps to set password
    Master:
  • 368 Answers
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Posted on Dec 04, 2012
Help yahoo com
Symptoms You can try these basic steps to troubleshoot Mail on your iPhone, iPad, or iPod touch. If you see a specific error message, follow the basic steps, then the steps for that error message. For example, you might see one of these messages:
  • Cannot get mail
  • Unable to move message
  • Username or password is incorrect
  • Relaying denied
  • Email address rejected by the server
Resolution First, try these basic troubleshooting steps:
  1. Tap Safari and load a webpage. If you can load a webpage, then your device has Internet access. If you can't load a webpage, check your Wi-Fi connection or try a different Internet connection:
    • Try a different Wi-Fi connection.
    • If your iOS device has an active cellular data plan, tap Settings > Wi-Fi and turn off Wi-Fi.
    • If the affected email account is provided by your Internet provider, see if your issue is resolved while connected to your home Wi-Fi network.*
  2. Log in to your email provider's website to make sure that the account is active and the password is correct.
  3. Make sure your settings are correct using Mail Settings Lookup.
  4. Restart your iOS device.
  5. Delete the affected email account from your device.
    1. Tap Settings > Mail, Contacts, Calendars.
    2. Tap the affected email account.
    3. Tap Delete Account.
    4. Add your account again.
* If you can only use your email account while connected to your home network, this might be a limitation put in place by your email service provider. For help, please contact your email service provider.
Follow the steps below for specific alerts.
"Cannot get mail" Make sure you entered the correct password. If you enabled two-step verification through your email service provider, contact them to see if you need a special password for your iOS device.
"Unable to move message"
  1. Tap Settings > Mail, Contacts, Calendar, then tap your email.
  2. Tap Account.
  3. Tap Advanced.
  4. Tap Deleted Mailbox and make sure it's set to Trash.
  5. Tap Advanced > Account, then tap Done.
    Note: If you see the issue again, repeat steps 1 through 3, tap IMAP Path Prefix, then Inbox. After you make your changes, tap Account, then Done.
"Username or password is incorrect" with POP3 account Before you check your email on your iOS device, close it on your computer and other devices.
To see if your account is a POP3 account use the Mail Settings Lookup tool or:
  1. Go to Settings > Mail, Contacts, Calendars and tap the account.
  2. Look for the label POP ACCOUNT INFORMATION.
If your email provider offers IMAP, remove the POP3 account, then add the account with your provider's IMAP settings. POP3 communicates with one mail client at a time. If more than one mail client tries to connect, you might see a username or password error.
"Relaying denied" or "Email address rejected by the server" when you try to send email This error indicates that either an email address is incorrect or your settings aren't correct for your current connection. Make sure the email address is correct for messages in the Outbox or try a different port:
  • If you're on a Wi-Fi network connected to the same network as your email domain, such as your Cable or DSL provider, try port 25:
    2. Tap your email account, then tap Account.
    3. Scroll down and tap Outgoing Mail Server.
    4. Tap Primary Server, then tap Server Port.
    5. Delete the current port and enter 25.
    6. Tap Done.
  • When you connect to a cellular data or a different Wi-Fi network, you need to use an alternate port and authentication, if your email provider supports it. The most common alternate ports are 465 and 587. Check with your email provider for specific settings.
If you still can't send email, you can set up an alternate SMTP server.
Get help troubleshooting iCloud Mail.
Aug 29, 2014 | Yahoo Mail
I have received a MMS. i have user name and password.please tel me where do i type this.i can not see any screen asking for username and password.please advise
Configure using settings wizard MMS for Nokia
1.Press the Menu key on your phone.
2.Scroll to and select Applications.
3.Scroll to and select Sett. wizard to launch the Nokia settings wizard.
4.Scroll to and select Operator.
5.Select Start > Multimedia message and follow the wizard's on-screen steps to automatically configure the phone with the required operator service settings.
Configure MMS settings
To configure MMS settings, select Menu > Messaging > Options > Settings > Multimedia message
Additional MMS settings include:
1.Image size - Define the size of the image in a multimedia message.
2.MMS creation mode - If you select Guided, the device notifies you when you try to send a message that may not be supported by the recipient device. If you select Restricted, the device prevents you from sending messages that may not be supported. To include content in your messages without notifications, select Free.
3.Access point in use - Select which access point is used as the preferred connection.
4.Allow anonymous messages - Reject messages from anonymous senders.
Download the device user guide for a comprehensive list of MMS settings
Send MMS Multimedia messages can be sent in a number of ways. An example of the steps required to send an image is listed below:
1.Select Menu > Photos.
2.Select the image you want to send.
3.Select
4.Select Via message.
5.Add the recipient name or contact number.
6.Select
Tips If you are unable to send and receive MMS, try these simple steps.
1.Check if the MMS settings (for example, MMS access point) are correct in your device. These settings are sent by the operator or service provider. See Operator or service provider settings.
2.Operators usually set a limit for the size of a picture message. If you need to send a picture that is large in size, you can resize it before it is sent. See Image size.
3.Contact your operator or service provider to confirm whether:
•Data plan is activated on your SIM card.
•Roaming is activated when you are not in your home network.
IF you want to see your MMS through go to your service provide site.and click the MMS and fill the username and password, and hit enter. you see your MMS in inbox double click to view the MMS.
Jun 23, 2011 | Nokia Cell Phones
Hi, I am unable to send or receive the multimedia messages. as well on trying to install internet setting am unable to do. Kindly help me
Try and contact your service provide and ask to send the setting for MMS and internet again, before doing this pls delete or remove the earlier saved data.
Jun 08, 2011 | Cell Phones
Gmail id - manzsherif@gmail.com I was able to login to Google/gtalk/orkut with valid username/password. However all of sudden I am unable to login with valid username or gmail id with valid password. i...
TRY THIS SIMPLE STEP... CLICK "FORGOT PASSWORD" TO GAIN PASSWORD... PROVIDE THE RIGHT INFO. THEN GO TO THE E-MAIL ADD. YOU HAD PROVIDED.. SIMPLE
Sep 21, 2010 | Google Talk
Unable 2 send message in my nokia 3230....
Hi
You can not send messages because the message centre number stored in your mobile may be wrong.
Please enter the correct message centre number.To get the correct message centre number please call your service provider and they will provide you the number.
To entre the message centre number please follow the steps below
Menu > Messaging >Options >Settings > Text message >Message centres
Thank you
Aug 09, 2010 | Nokia 3230 Cellular Phone
I cant access web
It seems that your mobile requires a firmware upgrade. In order to do that contact your service provider and ask them what type of upgrade their gprs settings require. If they are unable to help you out then kindly ask them to tell you the manual steps through which you can configure your mobile for gprs settings manually.
May 22, 2010 | Motorola Mobility L6 Cellular Phone
Message bank
If youre referring to the SMS message settings ask your provider for these settings and how to install them on your phone. Most providers have this kind of information available for free and their respective websites.
Sep 25, 2007 | Nokia N70 Cellular Phone
Wont send messages
You need to configure the mms and sms settings of your provider. Check with your service provider for guides.
Sep 20, 2006 | Motorola Mobility RAZR V3
Nokia E5 Cell Phone Logo
27 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
