Rc steering 26 cc hydroplane
Turns very wide, have adjusted servo etc, needs some adjustment?
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Not a TV question
Posted on Dec 04, 2012
How do i adjust the steering box on a john deere jd1950
Pretty much every steering sector has a way to remove excessive play (backlash) in the worm gear. Look on the sector for a locknut encompassing a large threaded bolt with no head, usually a wide slot for a "flat bit" used in a 3/8 or 1/2" ratchet. Some DO have a square headed end on the adjustment screw. Back off the lock nut 3/4 turn and tighten the adjustment, turn the steering wheel back and forth, tighten the adjustment screw again, tighten the lock nut and go for a spin. Hopefully adjustment improved it a bit. If not, try it again. Do not tighten it ridiculously tight though.
Nov 11, 2014 | Garden
RC servo turns left
Hi have tried centralising the servo?
Jun 01, 2013 | Toys
What are setings on controler
one adjusts steering from neutral (best) to a bit left or right, the other adjusts where trigger throttle will start breaking/reverse (keep in mind one does not need alot of speed in reverse so adjusting this so it acts more like a brake, and not throw you right into reverse is best)
Mar 23, 2013 | Exceed-RC Exceed RC Brushless Pro SunFire
Steering is realy touchy need to slow it down on dodge dakota 1997 rack pinion was wondering how to adjust it or if can it acts like it is getting to much pressure to the rack
This could be a couple of things, most like none of them to do with the steering gear itself. If you are used to older types of steering systems that use connecting rods/idler arms/pitman arms, you will need to adjust to the faster response of a rack and pinion steering system. If the problem is that the vehicle seems to "jump" when you give the least bit of pressure to the steering wheel, it could be one of a few things. Tire pressure or belt separation can cause handing issues. Improper alignment, even if the vehicle seems to have no issues with left-or-right pull, can cause erratic steering performance and can amplify issues with hydroplaning in wet conditions. If you have had steering parts replaced, or changed and/or rotated tires recently, I would check those areas first. Lastly, I would ensure that you are using the correct power steering fluid in your rack. Many people use DEXRON ATF, but that is not the recommended fluid for the Dakota rack.
Sep 14, 2011 | 1997 Dodge Dakota
Frequent high pitched squealing when turning
The drive belt that runs the power steering and maybe brake servo - is it loose and slipping, it has more force put on it when steering and braking so thats probably whats happening...
The belt is either worn out, or the adjuster has loosened or the belt is contaminated and needs washing,
Also you should clean up the pulleys when you replace or adjust the belt - you can clean with basic solvent (paraffin/alcohol etc) to remove oil and grease and give the best gripping surface for the drive belt. If the pulleys are particularly smooth and shiny you can haze them over with fine emery paper for extra "bite"
Jan 25, 2010 | 2002 Chevrolet Impala
My trx 3.3 idles fine but when you turn the remote on it takes off
you either need to adjust your servo or your idle screw on your controller. when you turn your remote on, it's opening up the throttle causing it to take off. turn on your remote without starting it and if you cant get it to the idle position with the trim screw on the controller, adjust your servo linkage so that it does.
Jan 15, 2010 | Traxxas Rc Revo Nitro Monster Truck
It appears the steering locked up. What do I do?
Make sure that no debris (stones, sticks, etc.) have gotten jammed in tie rods or steering servo. Check to see if servo is trying to move, you should be able to hear it when you turn the wheel on the transmitter. If the servo is not working at all, it could be faulty, came disconnected at the receiver, or receiver pack has too low of voltage. If the servo is trying to turn, check the servo saver to make sure it has not loosened or has been damaged.
Jan 05, 2010 | Traxxas Rc Revo Nitro Monster Truck
My nitro rc traxxas truck is not turning what do i do?
Check servo saver to make sure it has not loosened up. If the servo is not trying to turn at all check the connection at the receiver. If it is okay, you can always switch the steering and throttle servos at the receiver to rule out the possibility of a faulty servo. They can fail if they get too wet or get hit hard enough.
Dec 27, 2009 | Traxxas T Maxx 3.3 Monster Truck
Hello, Is there a manual in english for the Walkera 2.4 GHz HM5#10RC that shows assembly and adjustments for the servos. Thanks
i have a 1996 chev blazer and when i turn it on the fuel pump keeps going and fills the base with gas,and thevehicle won't start
Sep 09, 2009 | Walkera HM5#10 RC Helicopter
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
