Question about NetGear MR814 Wireless Router
I am trying to set up my printer to my computer and it keeps asking for my security string
  • NetGear Master
  • 7,733 Answers
If you dont know your router password how you connect to the internet?
Posted on Dec 05, 2012
What is the security string number and where will I find it
The security string is the wireless router's Network Key (WEP, WPA, or WPA2 Encryption key)
Dec 04, 2012 | Computers & Internet
I have a netgear modem from virgin media and i cannot connect it to my wireless printer, the printer asks for a security string, what is this and where do i find it????
That is the wireless security key. You can check it inside the configuration page of your netgear router.
You can access your router by doing the ff steps:
1. Go to 192.168.1.1 using a browser
2. enter UN and Password
default UN: admin
default PW : password
3. once in, look for wireless or wifi configuration then security.
4. you can change the wireless security as you wish
5. save and apply.
6. use the wireless key on your printer and it should work.. :)
Regards.
Sep 23, 2011 | NetGear WGR614 Wireless Router
HOW DO I LOCK MY ROUTER
Locking the router can be done by setting a WEP key. Its a 10 digit alphanumeric key that you can set. Once you set it up, anyone who tries to access your router wirelessly will be prompted for that 10 digit key. Be sure to change your SSID (wireless network name) also so that you can distinguish your own secured wireless network from others.
SSID can be changed on the main setup page.
1. To access it, open Internet explorer while your computer is physically connected to the router.
2. Type http:\\192.168.1.1 (the default IP address of the router.) It will ask you for the username and password.
3. Enter the word "admin" for both username and password. It is the factory default username and password. On the main setup page, you will find the field for SSID or Network name.
4. Type your unique wireless network name and click the Save button on the bottom of the page.
5. On the router's web-based setup page, click the Wireless tab then click the Wireless Security sub-tab
6. Click the drop-down arrow for Security Mode and select WEP.
7. Under WEP Encryption select 64 bits 10 hex digits.
8. Enter a unique word in the Passphrase field, then click Generate.
9. The result will be a string of letters and numbers displayed in the space provided for Key 1.
NOTE: Take note of what is in Key 1. This key will serve as the wireless security password. Keep this key confidential.
10. Click the Save Settings button.
From now on, whenever anyone tries to access your wireless network, they need to enter Key 1 which you only know. There you go. Your wireless network is protected.
Nov 07, 2010 | Linksys (WIFILAPTOP) 802.11b Wireless...
Not able to connect the sons Nitendo DSi to the internet. They are asking for the WEP Key but on my home hub there is only a WPA Key. BT have told me to connect to you to ask for support.
If your using WPA and your Nintendo DS only supports WEP Encryption theres no way you can connect it to the internet. WEP encryption is different from WPA.
WEP key uses hexadecimal - using characters 0-9, A-F or ASCII format. The ASCII format is easier to remember. The ASCII string is converted to HEX over the network.
Example of WEP key encryption are:
*64-bit hexadecimal keys are exactly 10 characters in length. (12345678FA is a valid string of 10 characters for 64-bit encryption.)
*128-bit hexadecimal keys are exactly 26 characters in length. (456FBCDF123400122225271730 is a valid string of 26 characters for 128-bit encryption.)
*64-bit ASCII keys are exactly 5 characters in length (DMODE is a valid string of 5 characters for 64-bit encryption.)
*128-bit ASCII keys are exactly 13 characters in length (2002HALOSWIN1 is a valid string of 13 characters for 128-bit encryption.)
WPA Key is entered as a pass phrase between 8 to 63 alphanumeric characters in the ASCII format at both ends of the wireless connection. Although PSK accepts a minimum of eight characters, for proper security, it is a good idea to use ample length and should not use a commonly known phrase. This phrase is used to generate session keys that are unique for each wireless client.
To resolved the issue you have an option to change the WirelessSettings on your router to WEP instead of WPA since WEP is also a secured netwrok. however you need to keep in mind that if you change the encryption you need to configure all othere device connected to the router via WPA and change the settings to WEP.
Thanks for using Fixya
Aug 02, 2010 | Computers & Internet
Security string
It seems that you are trying to connect the printer to wireless network with security.
Check the wireless network security settings. The printer requires the same key your system uses to connect to wireless network.
Thanks
Jul 11, 2010 | Kodak ESP5250 All-In-One InkJet Printer
Installing HP Officejet 6000 on Wireless Secured Network+ WEP key
I hate it when developers do stupid stuff like that. Its like they work overtime to make it harder for people.
Mar 11, 2010 | HP Officejet 6000 All-In-One InkJet...
Can't get printer software to install
Sir,
U must disable antivirus to install. Keep checking with the settings. Refer manual for installation with more than 1 computers.
Thanks Good Luck
Appreciate to rate as "Fixya"
Mar 17, 2009 | Panda Internet Security 2009 - 3 User for...
Changing to a secure setting
Go into your router's configuration page (see your router's manual for how to do this, it is an address that looks something like http://192.168.1.1). In there you want to find the wireless security section and change it to WEP security.
You will then need to enter a 64 or 128 bit WEP "key". This is your password to access the wireless network and the way you enter it is you enter a 10-character string (for 64 bit) or a 26-character string (for 128 bit) that contains only the numbers 0-9 and the letters A to F.
An example of 64 bit wep key is: 5145466d52
example of a 128 bit wep key: 3c2f2339483f2537373c57775f
Once you save your settings, your router should appear as a "secured" wireless network. When you try to connect, it will ask you for the key. Enter the same key you entered into the router.
That's it! The hardest part is finding the WEP section in the router's settings.
Jan 24, 2008 | Belkin (F5D5231V4-SN-PD) Router...
NetGear MR814 Wireless Router Logo
35 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
