Question about Toshiba 36A43 36" TV
Is it expensive to replace the remote sensor for my Standard Toshiba 36A43 Tv
    Top Expert:
  • Toshiba Master
  • 75,320 Answers
Remote sensors are very cheap to buy and easy to get device. It is a three solder terminal device. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or make a search by typing in the brand name of the device in the "Search Box", at the top right of the display window
Posted on Dec 04, 2012
likha
  • 790 Answers
SOURCE: Help me. i have a Toshiba 36a43. I turn tv on it
Hi
maybe you have weak filter capacitor! at the regulated power supply in cold area..
Thanks!
Posted on Feb 25, 2009
SOURCE: My remote will not work
1# First unplug tv,unhook ant.let set overnight.2# Reconect ant.Plug back in.turn tv on with button on tv.let tv run trew all its modes for 5 to 6 hrs.Don`t push any buttons!!!!! It has to reset everything.then try remote,when it starts to work,set new pin code.use your instruction book,to set all blocks to N,,Clear all favorite channels + erase channels in tv 's memory if there in there yet,takes a lot of time.it will keep resetting,remote won't work.let it run awhile. then push exit, hold 5 to 10 seconds remote will eventually come back,check your settings reset them, be sure menu is set to STOP, it may start running threw all its modes again,let run couple hrs, then push exit 5 to 10 seconds to get your remote back.keep trying this. when you think the tv is working right,turn it off for 10 seconds then back on. If it starts resetting, let it run an hr,then push exit again to get your remote back,it has to reset everything,keep trying, took me 3DAYS to get it right!!!!!!!!! the only thing I don't have working is the pic size button,Don't need that anyway. GOOD LUCK.
Posted on Mar 19, 2009
  • 3 Answers
SOURCE: Toshiba 36a43 tv has the demonstration screen
The problem is most likely the switches on the front panel. If the manual buttons are constantly shorting out, then the TV will try to respond to those buttons, and not the remote. Manual buttons almost always override a remote. Check the front panel for shorts, or if the buttons are constantly depressed.
Posted on Dec 24, 2009
muntejaya
  • 10421 Answers
SOURCE: toshiba 36a43 will not power on by power button or
Check the fuse for blown
Posted on Jan 29, 2011
pgh_pa_guy
  • 2992 Answers
SOURCE: Toshiba model 36a43 The tv
What you're describing sounds to me like "Windex syndrome". People sometimes clean the front of their TV by spraying it with glass cleaner like it's a window (which it basically is) and wiping it off. Unfortunately the cleaner can run down onto the circuit board where it damages the switches and wiring. This might be what's happening in your TV, although the same trouble can be caused by other things as well.
The way the front panel controls are wired, a bad switch can cause all of them to act up. The remote sensor is part of the chain too, and if it goes bad odd things can happen. If the set is in an area of high humidity the same trouble can develop because of moisture. One of the switches might not be operating correctly, or another part in the button chain may have gone bad. The microcomputer in the TV may be bad. If you've had a recent severe thunderstorm with nearby lightning, this may have affected the chip.
Try unplugging the TV from the AC outlet, not just turning it off. Let it sit for 5 minutes to make sure that capacitors have had a chance to discharge. Press a couple of the front panel buttons before plugging the set back in. Then plug the TV back in and see if you still have the same trouble. This process makes sure the microcomputer inside is fully reset and often gets the set going again.
If the trouble continues, someone will need to check the front panel switches and the circuit board. That's the area where the cause will be found.
Posted on Mar 01, 2011
Hello, I have a TOSHIBA 36" Model # 36A43 and it will not turn on.. the past few weeks i have been experiencing problems with the remote.. like not turning off the TV or the volume. Once in a while it
The manual power button ought to still turn the set on and off even if the remote is bad or not working.
I suspect you have two problems but there is a tiny chance only one as the front buttons and the remote both go to the same place in the set but here the front buttons have priority.
Dec 04, 2012 | Toshiba 36A43 36" TV
Need a manual for a TV model 36A43 serial # 14884246
Retrevo has the manual for the 36A43 here: http://www.retrevo.com/support/Toshiba-36A43-TVs-manual/id/311ag723/t/2/ . You will need to enter a code to download the PDF.
I hope this helps.
Oct 09, 2011 | Toshiba 36A43 36" TV
I want to program this universal remote to my toshiba tv how do I do that
try pressing 001,002,003,004 from the remote commander
Jul 17, 2011 | Toshiba 36A43 36" TV
We got a toshiba tv from a friend but it did not come with a remote, how do we get to the input function to play a dvd
Check the tv manual controls buttons on the front of the tv.Should have a button that said INPUT or VIDEO.IF not tv must require a original remote to used it.Try website like Remotes.com to buy a tv original remote.
Jun 13, 2011 | Toshiba 36A43 36" TV
Toshiba 36a43 tv has the demonstration screen running constantly over regular programming. Can't get it to shut off, remote will not respond & there is no reset button. Help please?
Dec 13, 2009 | Toshiba 36A43 36" TV
Hi
Thanks!
Feb 24, 2009 | Toshiba 32DF46 32" TV
Remote will not function with TV
If two remotes do not work. I would say the IR sensor on the front panel of the TV might be defective.
Can you provide an exact TV model number to try to locate an IR sensor part suppier?
Mar 10, 2008 | Toshiba 36A43 36" TV
Toshiba 36A43 36" TV Logo
42 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
