Question about Woodcraft Pirate Ship 3d Construction Kit
Need better instructions for Woodcraft 3D Pirate Ship
Yes, it comes with directions, but all they say is "match up the numbers on the pieces to assemble (as in 1 to 1, 2 to 2, etc), but there's only one "#1" and one "#2" and so forth.
It looks like others have written to you with this problem, but I can't access your solutions!
Need instructions for St Petersburg Church woodcraft construction
I have done this model, and the answer above is correct. While it is true that many of the pieces go together without glue, glue is required to keep some from falling apart while working. It is advisable to start without glue to make sure you have things connected properly. The kit comes with a very small tube - I got some carpenters glue when this ran out.
The pieces are labeled (on the back of the box) with letter number combination. The final number for each letter is inconsistent; the letters correspond mostly to construction groups. Be aware that some pieces which are apparently spacers inside others are actually important pieces. They get numbers, but are sometimes hard to see.
Good luck with your puzzle!
Mar 30, 2012 | Woodcraft Toys
There is only one number 20 and i dont know where to connect it to.
After lots of staring and wondering, I figured this out. On the big piece that makes up the bottom center of the boat, there are labels for 19, 23, and 24, but numbers 20, 21, and 22 are missing. If you look closely, that label actually shows 19-23, 24. It means 19 through 23. You are supposed to stack up the parts labeled 20, 21, 22, 23, and 24, and connect them all to the bottom of the boat where the label 19-23, 24 appears. This worked for me - I hope it helps you or someone else who looks here when they get stuck on this same problem!
Jul 14, 2011 | Woodcraft Pirate Ship 3d Construction Kit
Instructions for lego pirate ship brought in 1980s please
Is this it? I tried to find one which best matched your description - If you have the model number, the LEGO website offers a great service to find old manuals
LEGO Imperial Flagship 10210 Manual PDF
Nov 18, 2010 | Lego Pirate Ship Activity Set
Barbarossa Wooden Pirate Ship
I need instructions for the Le Van Toy Barbarossa Pirate ship.
Jan 01, 2010 | Le Toy Van Papo Barbarossa Pirate Ship...
Playmobil pirate ship #5869 assembly instructions
See the PlaymoDB FAQ for direction on ordering paper plans from Playmobil, and why they cannot be put online:
http://playmodb.org/playmodb_faq.html
Dec 28, 2009 | Playmobil Pirate Ship
Need instructions to put together lego pirate ship.
Go to the following Lego Support link to download building instructions
http://us.service.lego.com/en-GB/BuildingInstructions/default.aspx
enter the 4/5 digit product number to get the right model.
If you need to change the country then go to the Change region on the top right of the screen.
Oct 16, 2009 | Lego Pirate Ship Activity Set
No Manual
hello! the best thing you should see the store from where you have purchased your kit. most stores do includes manual which are clear and really handy and accurate..giving all the details on how to do that thing.. thanks! you may fix the other parts if no manual is available through simply doing it with a common sense..you just have to join it by using stick glue.
Apr 11, 2009 | Woodcraft Pirate Ship 3d Construction Kit
Need instructions for Captain Hooks Pirate Ship
go to service.mattel.com and click on instruction manuals and you should be able to print them out
Jan 01, 2009 | Toy Island Captain Hook's Big Pirate Ship
Woodcraft Pirate Ship 3d  Construction Kit Logo
112 people viewed this question
Top Woodcraft Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Woodcraft Toy Expert? Answer questions, earn points and help others
