Question about Toshiba 36A43 36" TV
I have an older model Toshia 36" Standard TV 36A43 TV recently, I had my cable company Time Warner, change out my box to a newer model....he was unable to get my Toshiba remote working , it was on t
  • Roseanne McIlvane Dec 04, 2012
    Fix it posted "SOLVED" so NOT case!!
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
Glad you got it going.
Posted on Dec 04, 2012
techman
  • 3130 Answers
SOURCE: TV will suddenly change channels, change volume, or go to set up screen by itself
yes and this is a common problem! First lets check out the obvious/ when theis fault starts to happen take out the batteries out of the remote control. If the problem stops then you need a new remote. If the proplem persist the remote sensor assy is bad in the tv set. Ive never heard a cable box causeing a motherboard to act up?? Wait arent mother boards in computers?? lol. believe me you need to tell the tv msn to replace the rmote sensor. Now in an extremly rare cases the microprocessor was causing the problem BUT highly unlikly. Good Luck
Posted on Jun 04, 2006
techman
  • 3130 Answers
SOURCE: Remote signals
If you tryed a universal remote , that remote should have at least worked the volume and the channels selector. It could be whats called a remote sensor assy thats mounted up toward the front of the set on the inside between the buttons. Its not really a user changeable part as there is soldering involved to replace the sensor. Realisticly, the correct way to trouble-shoot this set is to look at the data or logic line coming out of the remote sensor with an osilliscope to see the data and if it goes all the way to the microprocessor IC. If it does and no remote operation happens then the Micro's bad. Theres way to much Hi-voltage in these sets for a handi-person to tinker with, and its advised that a tech take a look at this set for you . Sorry I couldnbt be of more assistance. Good Luck
Posted on Jun 12, 2006
snakehead
  • 1074 Answers
SOURCE: Set Randomly Turns off (Power LED Blinks) and Comes Back On ~1-2 minutes Later
if you have not gotten this fixed get it to a repair shop your problem is intermittent there might be lose solders or component in the power supply is failing and needs to be replaced.good luck blessing from belize
Posted on Mar 23, 2007
SOURCE: Toshibe 36AFX61 36" TV
I uncovered the problem. The "analog tuner" seems to have gone bad. The part is $25 -$36. The set can still be used however. I just removed the coaxial cable from ANT 1 in the back of the TV (this is what I believe has become defective)which was going to a VCR. I then just used composite cables(red,white,yellow)to bring the signal directly to the TV from the cable box, rather than the VCR. All works however, will replace the defective part.
Posted on Sep 20, 2007
maatmartin7
  • 1210 Answers
SOURCE: I have a 36 in Toshiba 2003 TV, model # 36A43. The
There is really no easy fix...but patience is on your side if you have some. You will need to buy an RF connector at a electronics store..Please visit a commercial dealer, Radio Shack is to limited! Pull the tuner out of the tv board, open the cover that contains the solders. Lets hope the board is not cracked. and be sure one of those small coils are not pulled out..Donot even think about touching or moving these coils if you open the wrong side ot the tuner shield. Reconnect the tail of the RF connector through the board. You sometimes will have to cut the tail length wise for a fit. [You better buy two RF conectors just incase you make a goof. Then solder the a ring around the RF connector to the tuner box. Reinstall into the tv board! Hope this works!
Posted on Nov 29, 2009
Is it expensive to replace the remote sensor for my Standard Toshiba 36A43 Tv
Remote sensors are very cheap to buy and easy to get device. It is a three solder terminal device. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or make a search by typing in the brand name of the device in the "Search Box", at the top right of the display window
Dec 04, 2012 | Toshiba 36A43 36" TV
Repair manual
If you are saying the cable fitting on the set broke off a cable box with standard audio and video output jacks on the rear can be connected to the same jacks on the rear of the set-----then you select that input (they are numbered) and watch tv using the box for channels.
You then have bypassed the tuner connection for the set.
Dec 03, 2012 | Toshiba 36A43 36" TV
Need a manual for a TV model 36A43 serial # 14884246
Retrevo has the manual for the 36A43 here: http://www.retrevo.com/support/Toshiba-36A43-TVs-manual/id/311ag723/t/2/ . You will need to enter a code to download the PDF.
I hope this helps.
Oct 09, 2011 | Toshiba 36A43 36" TV
I have a 36 in Toshiba 2003 TV, model # 36A43. The cable connector on the back of the TV snapped off, Is there an easy fix? Can I buy another part? Any suggestions?
Nov 29, 2009 | Toshiba 36A43 36" TV
Time warner code for Fujitsu 42" tv
I have the 55 inch. try using 246. That works on mine. if not try 028,164,208,066
let me know if that works for ya
ric
another note, are you using the flash on the back of your cable box or do you have a sensor in front of the DVR box?
Nov 10, 2008 | Toshiba 36A50 36" TV
Can't program the DVR remote to cut my broksonic tv on or off.
what is the code for broksonic universal remote code
Jun 20, 2008 | Broksonic CTGV-5463TCT TV
Codes to make my Time warner remote control the tv
Here's the list from Time Warner
http://www.timewarnercable.com/Carolinas/site.faqs/Equipmenta/Remotes/Digital-Remote-TV-Codes
Oct 26, 2007 | Toshiba 36A50 36" TV
Toshiba 36A43 36" TV Logo
53 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
