Question about Sansui DTV3200 32" TV
Can't get one local channel when hooked up to T.V. antenna
Have a 32'' Sansui LCD HDTV, when I hook-up the T.V. antenna I can not get the local FOX channel, I get all the other local channels. Unhook it and hook it up to the old T.V. local Fox channel comes in perfect along with all the other local channels. What do you think the problem could be?
  • Anonymous Feb 02, 2009
    I have the same problem I am hookin up an antenna but I still can't get any local channels. I need help!
Take a gun and shoot your self.
Posted on Feb 19, 2009
  • 2 more comments
  • fafd adsg Feb 19, 2009
    Or make your own ****.
    I did your mom.
    Take a cable wire and **** on it all day long or shove it up your @$$.
  • Linda Feb 10, 2013
    Why did you bother to answer
Hooked up to antenna did channel scan in air mode not getting any channels. Hooked up a Vizio tv to same antenna line and got all the locals. Maybe something wrong with the Sharp?
Make sure that Sharpe is set to over the air/antenna and not cable. There are more than one scan modes. http://files.sharpusa.com/Downloads/ForHome/HomeEntertainment/LCDTVs/Manuals/tel_man_LC42_46_52D65U.pdf
See page 14 in the link. It is easy to mis-configure the setup to not receive the over the air digital channels. The input must be set to digital and air in setup. The VHF are no longer available.
Hope this helps?
Jan 15, 2016 | Sharp LC-32DA5U 32 in. HDTV-Ready LCD...
How do i hook up a 32 inch Sansui TV to an antenna
After you connect the antenna cable to the TV go into the setup mode and on the tuner line change it from cable to air. Then do an automatic channel search and you're done.
Oct 22, 2015 | Sansui Televison & Video
I cant pick up any channels on my 32'' Emerson hdtv with my channell scan
Did you select antenna in the setup menu?
If you did and still can't receive anything you may not be receiving signals strong enough. Read the setup instructions in the manual. link below.
LC320EM9 EMERSON LCD TELEVISION Manual
Sep 09, 2014 | Emerson LC320EM9 32 in. LCD HDTV
Had my channelmaster 4046 HD hooked up to a vizio tv and got all major channels. Now have hooked up my antenna to an RCA tv and can't get NBC and local FOX station is jumpy
The tuner in the RCA has poor sensitivity. Radio Shack sells a inline amplifier that may help, make sure you can return it if it doesn't. Move the antenna outside if possible and as high as possible, that may help. Good Luck!
Feb 14, 2014 | Channel Master CM-4046HD MODERNtenna...
Antenna channels
use digital antenna via radioshack
Jan 24, 2014 | Sony BRAVIA KDL-40XBR2 40 in. LCD HDTV
I just purchased an indoor antenna for to view local stations. Can i use an indoor antenna for my olevia 232-t11 lcd-hdtv? If I can, what steps do I need to follow?
Yes you can use an indoor antenna. Just make sure it is an HD antenna to get the digital channels clearly. You will have to do a scan to pick up local channels. In the TV menu, it will ask you if you want to scan for "cable" channels or "antenna" channels. You want to choose antenna.
Feb 11, 2013 | Olevia LT42HVi 42 in. LCD Television
Just got it out of box,wedding gift,a year ago.no owner manual.no sound.hooked up to cable,it keep saying...unusable signal.At the bottom it says CMP1..
You may need to change the settings in your channel settings menu from "Antenna: Air" to Antenna: Cable" if you have a coax cable hooked into the back.
Jun 06, 2011 | RCA L32WD250 32 in. LCD HDTV
New HDTV...using RCA Anttena hooked it up
Buy digital antana,get stronger signal,will work for any wheather.
Feb 02, 2010 | Olevia LT32HVE 32 in. LCD Television
Setup 32 inch sansui for digital reception
1) Connect your signal source - either CABLE or ANTENNA.
2) Go into your menu and select your signal source to match.
3) SCAN in the channels. This will give you all channels available.
Your User Manual will give you all information.
If you are on cable, you may have to check with your supplier to see if they carry local stations.
Feb 23, 2009 | Sansui HDLCD3210 32 in. LCD TV
Sansui DTV3200 32" TV Logo
804 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
