Question about Kenmore Washing Machines
How do i check the lid switch to see if its faulty on my kenmore washer
Model number 110.24632300
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
Below is a video to show you how to bypass the switch.
Here is the new switch if you should need to order it.
Posted on Dec 04, 2012
catriver
  • 878 Answers
SOURCE: replacing lid switch
someone, Im not finding that model number. Going by the first six digits Im assuming that this is a regular top loader and not an Oasis washer. If so, remove the end caps on the consol by pulling them off. Remove the screws under each end cap and flip the consol up. Unplug the lid switch connector and snap springs holding the cabinet on. The whole cabinet will pull forward and you can get at the lid switch. Check out the pics and post back...Catriver.
Posted on Apr 15, 2007
huuum
  • 750 Answers
SOURCE: need a diagram for a lid switch
Hello jafarrell
What is the exact model # ?
This was the part number!!
You said, you need a diagram of the Kenmore top loading washer, model 20432 lid switch.
This is a Kenmore part # you supplied, so here is where you can get it from Kenmore.
Part # 20432 lid switch as you supplied in our communications!.
http://www.searspartsdirect.com/partsdirect/retrievePartActionHome!search.action?productGroup=N%2FA&partNumber=20432&pop=flush
Thank you for using Fixya.
Huuum
Please remember to leave a rating
Posted on Oct 08, 2008
  • 1122 Answers
SOURCE: defective lid switch
you can bypass the lid switch,remove thw 2 screws on the console one on each side,flip the console up,you will see a 3 wire jack in the middle on the washer,disconnect the jack,the wires going to the console clip the 2 outside wires leave the green and wire nut the others together,plup back in and your done,let me know how you do-mike
Posted on Oct 26, 2008
scottowa
  • 87 Answers
SOURCE: how do I get to the lid switch to replace it on my washer
Pull of the end caps #14 & 11 on the diagram. Remove the screws and the front panel will flip up. Then there are 2 clips connecting the bac to the cabimet. Snap those out and the the WHOLE front of the machine comes off if you tilt it forward. Go to sears.com and parts to bring up any model for anything and you can kind of see how things go together. Good luck.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=11022852100&productCategoryId=0153200&brandId=0582&modelName=WASHER&diagramPageId=00002&componentDescription=CONTROL%20PANEL&documentId=P0103381&backToLink=Return%20to%20Sub%20Components%20list
Posted on Jan 23, 2009
danromarris
  • 101 Answers
SOURCE: can't get top off kenmore washer model # 110 22852 100
No problem. What you want to do is this, remove the screws from the back panel first to remove that metal plate protecting the wires. Once off you need to take off the two covers on the sides of the control panel. There is one on each side, just pop them off. Once off you will see there is a screw under there holding the control panel in place. Remove the screws and that will lean back. Next take a flat head screw driver and put it under the lip of the lid on the front of the washer. I mean the lip that is about an inch down from the top on the front. Pry up and the whole lid will pop up. You will see the lid switch there held in by a screw, follow the wire to where it plugs in and unplug it and replace with the new one. Let me know if you have any other questions and if this was helpful to you. Always happy to help and good luck.
Have to slam the lid so that the washer will start.
It is a faulty switch about to go bad that interupts the signal for safety. Repair Clinic.com sells them. Enter the make and model number then order it. Easy to change out ususally.
Apr 23, 2015 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series washer will not drain? It makes an electric click noise which makes me think the lid switch is ok, but i don't know. Won't drain or spin.
There is a good chance the lid switch is bad. The model number is usually under the lid hen you open the lid check at the back of the opening when the water injector is.
May 17, 2014 | Kenmore 24932 Top Load Washer
I have a Kenmore washer, model number 110. It won't drain or spin, just fills up. Can anyone help?
Hello, welcome to FixYa.
The scenario you describe is usually associated with a faulty or broke lid switch, but also will include not agitating I suspect.
The lid switch failure is definitely a common top load washer problem...particularily with the Whirlpool built units like yours. Here`s how you can repair it pretty easily...
( this is based on the most common Whirlpool, Estate, Kitchen-Aid, Roper, Kenmore, Inglis top-loadwasher, not necessarily applicable to ALL...but with a model number I could say if it cover's yours)
Here`s a helpful link for changing it out there are a couple of different types,
http://www.youtube.com/user/RepairClinic#p/u/5/MFsvLiuTniU
The lid switch will look like this...
double check with your model number at "searspartsdirect.com"
Let me know how you make out. If this is something you think is not within' your scope of expertise please call a pro. I think you'll be fine with the tutorial video'
I will try to help in any manner I can of course as well. Good luck. Thank you for choosing FixYa. Please take a moment to rate the info I provided and a short testimony is appreciated.
Regards,
Macmarkus :)
Oct 28, 2011 | Kenmore Washing Machines
My kenmore 90 series washer will not drain i have tried playing with the lid leaver any thing else i can do ,can i replace the leaver switch?
Yes you can replace the lid switch its fairly easy to do...this tip i wrote will help ya to replace the lid switch http://www.fixya.com/support/r9939128-whirlpool_kenmore_estate_kitchen_aid
Series 90 is unfortunitly not a model number please reply with exact model number as found on a label on the rim of the tub inside of the lid and i will give you the part number for the lid switch.
GENE
Sep 12, 2011 | Kenmore 24032\24036 Top Load Washer
My Kenmore Elite Oasis HE model number: 110.27072603 washing machine shows LID error code. It wont work at all.... went half way through cycle... help.
Greetings,
this washer has a lid switch problem...or possible main board failure, but lid does concentrate on the lid safety switch. If you remember when you open the lid it stops..well, its a safety feature and prevents tub from spinning with lid open...this one is more difficult to service if your not use to working on washers...try unplugging machine and leaving off for awhile...does the door lock? check switch for lid fault
Nov 25, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Hello, i have a top load Kenmore Washer that has stopped draining, when you turn it on it will fill the water and sgitate but does not spin or drain. the model details are as follows: Model number 20642 2...
Yep - your lid switch is faulty.
You have to remove the outer shell to access the switch.
This video is not model specific to yours, but is helpful...
CLICK HERE for additional helpful links on bypassing to check - and knowing that the switch is bad - even though it's resistance checks good.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 22, 2009 | Kenmore Washing Machines
Kenmore top load washer- have to bang lid several
This is most certainly caused by a faulty micro switch on the lid. Have the switch checked out and replaced if need be.
Best wishes,
Graemevm
Jun 06, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Need a diagram for a lid switch
Hello jafarrell
Huuum
Sep 18, 2008 | Kenmore 22422 Top Load Washer
Replacing lid switch
Apr 14, 2007 | Kenmore Oasis 27042 Top Load Washer
Washing Machines Logo
26 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
