What is the security string number and where will I find it
I am trying to set up my printer and the printer is askig to enter my security string
  • 32,281 Answers
The security string is the wireless router's Network Key (WEP, WPA, or WPA2 Encryption key)
Posted on Dec 04, 2012
  • michael payne Dec 04, 2012
    Where will I find this on my router
  • Chris Hingee
    Chris Hingee Dec 04, 2012
    This is in the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wi...
I have installed an brand new bizhub c 364 machine, now it gives me security lines either blue or red , can anyone help me in solving the problem ,thankyou
Install was done incorrectly,
CAUSE: Initial settings did not take when programmed.
SOLUTION: Time and date, telephone and ADF serial numbers need to be reentered:
1. Sub-power ON g Utility/Counter g Machine Admin settings g System settings g Date and time setting g (Enter year/month/day/time) g OK g Exit g Power OFF sub-power switch.
2. Enter Service Mode g System settings g Setup date input g (Enter year/month/day) g OK.
CAUTION: DO NOT POWER OFF. Leave machine in Service Mode.
3. In the Service Mode g System settings g Telephone setting g (Enter 16-digit number) g OK. Repeat for the fax number. Set to all 9s if there is no fax number.
4. In the Service Mode g System settings g M/C serial number setting g touch ADF g (Enter ADF serial number) g OK g Power OFF sub-switch.
5. Power ON sub-switch and run copies with no security lines.
May 27, 2015 | Konica Minolta Bizhub C364 Color Copier /...
Printer will not print to the margin
What kind of printer? The print string may need to be manually entered. Try going into the properties section of the print screen dialog. You should find a box there to enter the parameters of your print string.
Dec 22, 2012 | Office Equipment & Supplies
Phone is askig for puk code only 1 try left.
My dear friend. When your phone asks for puk code, it simply means someone has entered a wrong pin code 3 times hereby causing the sim to self lock for security purposes. The puk code is in the sim pack. In it you will see a 8 digit code on the card that you broke the sim card out of. If you do not have the pack anymore, then you use another phone to contact the customer care of the sim cards network operator, then they will give you the puk code, be sure to enter the correct code they give to you so as not to block the sim card permanently.
That should do the job for you.
Jan 12, 2011 | Cell Phones
Security string
It seems that you are trying to connect the printer to wireless network with security.
Check the wireless network security settings. The printer requires the same key your system uses to connect to wireless network.
Thanks
Jul 11, 2010 | Kodak ESP5250 All-In-One InkJet Printer
I forgot my pass word for samsung A736
Hello there. This works on most Samsung phones I work on. Enter *2767*3855# (resets the eprom) enter *7465625*638*00000000*00000000# (unlocks the security setting and sets security code to 8 zeros) enter #7465625*638*00000000# (confirms security code changed to 8 zeros) Your security code is 8 zeros. To change the code, repeat the procedure replacing the string of 8 zeros with your security code. Happy hacking. If this does not work for your phone repost with your results and we can try other ways. Please rate me if this helps. Thanks for allowing me to serve you on Fixya.com
Jul 26, 2009 | Samsung SGH-e315
How can i stop my incoming calls
Enter Menu 4-3-1 (Settings-Security settings-Restrict calls).
The "RESTRICT CALLS" options will be displayed.
Use the arrow keys to select "RESTRICT OUTGOING CALLS" or "RESTRICT INCOMING CALLS" and press the softkey under "SELECT."
A display prompting you to enter your Security Code will appear.
Use the keypad to enter the Security Code and press the softkey under "OK."
The choices "SELECT" and "ADD RESTRICTION" appear on the display.
Select "ADD RESTRICTION" using the arrow keys and press the softkey under "OK."
A display prompting you to enter the number string you wish to restrict will appear.
Enter the number string or name you want to restrict and press the softkey under "OK."
Example: 1905 will restrict all calls beginning with 1905.
262 will restrict all calls by the name of Bob. B(2)o(6)b(2).
The message "Saved" appears and he desired numbers will be restricted.
Dec 28, 2008 | Nokia 1600 Cellular Phone
Changing to a secure setting
Go into your router's configuration page (see your router's manual for how to do this, it is an address that looks something like http://192.168.1.1). In there you want to find the wireless security section and change it to WEP security.
You will then need to enter a 64 or 128 bit WEP "key". This is your password to access the wireless network and the way you enter it is you enter a 10-character string (for 64 bit) or a 26-character string (for 128 bit) that contains only the numbers 0-9 and the letters A to F.
An example of 64 bit wep key is: 5145466d52
example of a 128 bit wep key: 3c2f2339483f2537373c57775f
Once you save your settings, your router should appear as a "secured" wireless network. When you try to connect, it will ask you for the key. Enter the same key you entered into the router.
That's it! The hardest part is finding the WEP section in the router's settings.
Jan 24, 2008 | Belkin (F5D5231V4-SN-PD) Router...
Samsung D900i pin number
Bro original code inside samsung phone default is 00000000. But it is possible somebody had change it. After full charge battery without simcard enter string *#2767*3855# and your phone will show reseting E2P and other instruction. Follow that and your code will change to 000000000(default company code). It works don't forget to vote reply...
Jan 05, 2008 | Cell Phones
Slow web page loading
To setup and improve your wireless network’s signal, you can change your Wireless Network Name (SSID) and/or try using a different channel.
Changing your Router’s SSID and Channel
Step 1:
Access the router’s web-based setup page.
Accessing the Router’s Web-Based Setup Page
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router’s IP Address ("192.168.1.1" is the default IP of most Links-ys routers) then press [Enter].
Step 3:
A new window will prompt for a User name and Password. Leave the User name space blank, type in your router’s password ("admin" is the default password), then click OK.
Step 2:
When the router’s web-based setup page appears, click the Wireless tab.
Step 3:
Look for Wireless Network Name (SSID) and if it’s still set to ‘linksys’ change it to something unique then click Save Settings.
click the Wireless tab and select the Wireless Security tab.
Step 3:
Select WEP under Security Mode.
Step 4:
Select any number on the Default Transmit Key field to determine which key you’ll be using. In this example, we selected number one.
Step 5:
Select 64 bits on WEP Encryption
Step 6:
Type a wireless network password of your choice such as “MySecretKey,” then click Generate.
NOTE: You should come up with a password that is unique for your network and is a combination of numbers and letters up to 10 characters.
Step 7:
The result will be a string of random characters. Copy the resulting string since this will be the key to your wireless network.
NOTE: Do not give this key to anyone. This will be your wireless network’s key.
And click save settings..
Nov 28, 2007 | Linksys Wireless-G WRT54GX Router...
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
