Switched computers moved pci adapter have good signal strenght but still can't get on the internet
  • Peter Conway May 11, 2010
    Please clarify details:-
    Windows or Mac?
    Whjat Version?
    Make and model of Wireless Router?
    Broaband Supplier?
  • 26 Answers
There is a problem with the modem or router, connect your computer directly with the modem and if the problem persist, change the modem
Posted on Sep 21, 2009
Signal strength went from Good to Low
Either move the computer closer to the router or the router closer to the computer. You could also try connecting the usb adapter to a usb hub to remove any interference from the computer.
Mar 19, 2014 | Belkin Basic Wireless N150 USB Adapter
I have a Dell XPS400 and can not connect to the internet because the machine does not have any installed network adapters. I have always had internet access...where do I find this adapter if I can't get...
This is onr example of a Network adapter, or also know as an Ethernet Adapter Card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=686143&CatId=200
This is Dell Support >XPS 400 desktop computer > Service Manual,
http://support.dell.com/support/edocs/systems/xps400/sm/index.htm
1) Work on a table. Computer off, and unplugged from power, open the computer case.
(Removing the Computer Cover, in the list)
2) Follow Anti-Static precautions.
[Anti-Static Precautions:
Your body carries Static electricity.
Static will fry out (Short Circuit) the delicate hardware components, inside a computer.
To relieve your body of Static, TOUCH the metal frame of the open computer case.
Should you leave your computer in the middle of working on it, upon your return be sure to Touch the metal frame again ]
3) View the motherboard inside your computer.
(The motherboard is also referred to as the Mainboard, {Proper speak}, and System Board)
Technical Overview > System Board Components,
http://support.dell.com/support/edocs/systems/xps400/sm/techov.htm#wp1053398
Viewing the illustration of the motherboard, the Ethernet Adapter Card example I gave above, would go in either one of the PCI expansion slots.
These are white in color, and in the illustration are labeled - PCI Card Connectors.
If there is already an adapter card installed in both PCI expansion slots, then see if the PCI Express x1 expansion slot is open.
In reality, PCI Express is a better technology than PCI.
Shown on the motherboard as PCI Express x1 Card Connector.
This is an example of an Ethernet Card, (Ethernet Adapter Card), that uses the PCI Express x1 expansion slot,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4675156&CatId=200
The reason I have suggested buying, and installing an Ethernet Adapter Card is threefold.
1) You may have your Ethernet cable plugged into the Ethernet port of the computer,
http://support.dell.com/support/edocs/systems/xps400/sm/about.htm#wp1053567
[Number 3 - Network Connector],
and the built-in Ethernet is no good.
Reinstalling drivers May help, but the above is a sure thing.
2) You have an Ethernet Adapter Card plugged into one of the PCI slots, or the PCI Express x1 slot, and the Ethernet adapter card is no good.
They do go bad, and are economical to replace.
3) There was an Ethernet Adapter Card installed previously, but taken out before you received the computer.
Jul 02, 2010 | Dell XPS 400 PC Desktop
Do Desktops pick up internet connection like laptops do? Im planning on purchasing a desktop pc however im not sure if i can pick up internet like my current laptop does, U see i just moved in and dont...
Hi there.
You hit the nail right on the head!! desktops don't come wireless enabled so you will need a wireless card installed into it.
I recommend a wireless PCI card as a Dongle are not that good and can be easily broken.
Good luck and thanks for using FixYa!!
Apr 21, 2009 | HP Computers & Internet
No internet access with new Linksys wireless PCI Adapter
Don .bin is a firmware that can upload to the linksys router or any router.
So it seems that your unable to connect wirelessly using the linksys adapter? The Internet connection before is working properly?
*I might advise you to reinstall the driver of your wireless adapter using the latest driver that you can download in there support site.
- Check the Internet connection hardwired to the router if connection works it seems that problem is on the adapter.
Mar 07, 2009 | Linksys Rangeplus Wireless Pc Adapter
Signal strenght just gone!
Are you using the same security as the others?
Make sure the the security key is exactly the same as the others.
Also check the firewall settings
Dec 29, 2007 | 2wire (1000-000005-002) 802.11g/b Wireless...
I cannot connect my laptop computor to my main computor
Bluetooth is not WiFi,   they are two seperate technologies.
you need a Wireless adapter 802.11b/g for your laptop,
you would connect the two to each other using an adhoc connection,
If you had a wireless router for your internet you could connect directly to the router, (and then you would not have to have your main computer on for you to access the internet.
BTW if your Main machine is near your phone point (for internet connection) you would not need a wireless card for your pc, as you could connect via LAN cable to the wireless router (make sure you get one with lan ports)
Oct 15, 2007 | NetGear - WG311 - 54Mbps 802.11g/b...
Problem connecting to the internet using wireless usb adapter
Run this programme, then if necassary clear temp files in tools in your explorer. Start> Run then type ipconfig /flushdns then press enter.(note the gap between ipconfig and the /).
Mar 05, 2007 | GigaFast Ethernet WF748-UI (WF748UI)...
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
