Question about Cell Phones
Dont work cancel button - Cell Phones
    Master:
  • 368 Answers
My Dear your phone keypad ic default so please change keypad ic
and keypad problem will solved
Posted on Dec 04, 2012
Microwave keypad dont work
The problem is in the keypad control board, cost will run high making a new microwave oven attractive.
Apr 06, 2012 | Hotpoint Microwave Ovens
I have an error code E3 but i dont have any paper in the printer... what to do...reset? but how?
I will advice you reset your canon printer, Follow this steps to reset your canon printer.
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times.
6. turn off printer by button POWER. Power on later to see if that fix the problem.
Jul 09, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Waste ink absorber full
you can reset the ink counter but make sure u find way to replace the pad else it's going to be messy once the ink leak out...below is how you reset your waste ink...
2. Press the button Resume/Cancel(dont release) then press POWER button- if done, you will see the light change to green color.
3. Release the Resume/Cancel button, but dont release the POWER button.
4. Press Resume/Cancel button of 2 times, while still pressing the POWER button, after that, release both.
5. When the light change to GREEN - press the button Resume/Cancel 4 times.. then press POWER button once.
6. Turn off printer
7. Turn on and try print.
May 26, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Ink absorber full
Hi there
If this not do the trick then you need to download off the net IP Tools. And dont forget you will need to clean out the waste ink pads as soon as you get the chance to do so or it will gave you a big mess.
Resetting Ink-Waste Overflow Counter Canon Pixma
1. With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button. (DO NOT release the buttons. The LED light should be green to indicate that a function is selectable.).
2. While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.).
3. While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
4. When the LED light is green, press the Resume/Cancel button 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
5. Press the Power button. The LED lights in green, and the reset is performed. (When the operation completes, the printer returns to the menu selection mode automatically.).
6. Press the power button to exit service mode.
Note: if you accidentally press the Resume/Cancel button more than 4 times in step 4 then just press the Resume/Cancel button at least 10 times and the printer will be returned to step 4 automatically
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 22, 2010 | Canon PIXMA iP3300 InkJet Photo Printer
Uhh....... the blender mafuntioned when i plug in it blens even when i dont turn it on
Sounds to be a switch is stuck or button . Tap each button vigorously and turn each one on and off. Pressing another speed should cancel what ever button is stuck. Good Luck, Ned
Sep 27, 2009 | Sunbeam 4192 Work Top Blender
Sony PCS-1 dont remember admin password
1. Access the Setup menu as follows:
Press and hold the MENU button on the remote commander.
2. Select Dial using the �� button on the remote commander.
3. Access the Service menu as follows:
Press 7 then 2 on the remote commander (without pressing the
PUSH ENTER button).
The Service menu appears. (See Figure 1.)
NOTE: To cancel Service mode and return to the Setup menu,
select Cancel using the arrow buttons, and press RETURN
Clear setup and FINISH
Bye Zamani Ali
azamani@iooc.co.ir
Nov 24, 2008 | Sony PCS-1 (PCS1) Video Conference
I have a Canon ip 1500 printer. Message has come up saying the waste ink reservoir is full and needs servicing.What canI do (Newcastle area)
There is a large sponge like container in the bottom of the IP1500 that holds the overflow of ink, Canon has built in a counter that will warn you when this needs to be replaced. You dont really have to replace this..just hose it out in the sink until the water runs clear, let the printer dry out real good for a week or so and then use the following to reset the counter. You don't HAVE to clean out the waste container, but, be prepared to have ink flowing out onto whatever your printer is setting on if you just reset this and keep printing. I really suggest you either clean it or replace it.
1) With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button. (DO NOT release the buttons. The LED light should be green to indicate that a function is selectable.).
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.).
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
4) When the LED light is green, press the Resume/Cancel button 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
5) Press the Power button. The LED lights in green, and the reset is performed. (When the operation completes, the printer returns to the menu selection mode automatically.).
6) Press the power button to exit service mode.
Note: if you accidentally press the Resume/Cancel button more than 4 times in step 4 then just press the Resume/Cancel button at least 10 times and the printer will be returned to step 4 automatically.
Oct 30, 2008 | Canon Office Equipment & Supplies
Beko tumble dryer not drying. drum goes round but it doesn't get hot. Model DRCS68
go into service mode and reset
to do this move to delicates turn on dryer and keep
pressed down cancel button for about ten seconds release
then all lights should flash when you press cancel again machine will go through test mode , then just turn machine off
it is now reset, this worked for min a drcs68w
Apr 23, 2008 | Dryers
Weekend alarm cancel function
hit the cancel button then the wake1 or wake2 button as you need to cancel them.
Oct 28, 2007 | GE 74801 DUAL ALARM CLOCK RADIO .9" LCD
Cell Phones Logo
13 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
