SOURCE: manual
Here goes,
http://rapidshare.com/files/84607055/UM_ML100.pdf.html
Click the Free account in rapidshare.
FixYa!
SOURCE: Correction Tape
Two possibilities, one the correction tape is twisted and the wrong side is .facing the paper. The shinny side should be facing you, the dull side facing the paper. Second possibility you must make sure the ribbon is compatible with the correction tape. There are 2 types of ribbons. A correctable one (orange or yellow knob) and a multi strike (blue or purple knob on ribbon cartridge). The lift off correction tape (orange or yellow spools) only works with the correctable ribbon and the cover up correction tape (blue) works with the multistrike ribbon.
SOURCE: HAVING TROUBLE PUTING IN THE CORRECTION TAPE
Make sure you are installing the tape with the sticky side facing the paper. I
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
SOURCE: Left and right margins of typewriter on Brother ML 500 Memory
Hi:
First find the margin release key and press it once. Then use the spacebar to move the carrier forward and reset the right margin. Or again use the margin release key by pressing it once and then press and hold the backspace key to move through where the left margin was and reset it at the point where you want it.
Andrew
SOURCE: how i replace the correction tape for the Brother
Go to brother.com click on support you will find a manual there with pictures.
DickyO
