Question about Garmin Nuvi 50 US Car GPS with 5 Inch Display
In Mapsource/utilities/unit ID with my Nuvi50 connected by USB it reports "Some devices were found however none have the necessary capabilities" The GPS unit is switched on and connected via USB. USB
  • Bruce Ardern Dec 05, 2012
    Problem found to be faulty USB cable.cheers, Bruce
    Problem solved, faulty USB cable. cheers, Bruce
  • 242 Answers
Bruce has solved his own problem. Cheers to Bruce!
Posted on Dec 06, 2012
How do I upload Maps update for Streetpilot c330.
Installation Instructions
  1. Download the self-extracting archive file for your Streetpilot c330 onto your hard drive.
  2. Connect your Streetpilot c330 to a free USB port on your PC with the correct PC interface cable.
  3. Unzip the files in the archive by running the downloaded executable file.
  4. Follow the instructions provided by the launched update application on your computer.
Get the update here:
http://www8.garmin.com/software/StreetPilotc330_610.exe
Mar 19, 2009 | Garmin StreetPilot C330 GPS Receiver
How do I update the maps?
TO GET 2009 MAP IS NOT EASY! Software update is, from the site you can update software easily BUT THE MAP... you must purchase fro $69.99 OR if you're a technical person who knows the following instruction you can save some $$$
search
CNNANT2009-1 MapID 396
under torrent sites, you know what you're doing.
Use these instructions if you have downloaded it.
Download these first:
cgpsmapper.exe
gmaptool.exe
MapSetToolKit.exe
and MapSource where u can directly get from Garmin site
http://www8.garmin.com/support/download_details.jsp?id=209
Create these folders on the root drive: (I will choose one to make things easier, you can change)
C:/grmtmp
C:/grmtmp/extract
Connect your GPS to USB, and BACKUP then remove
X:/Garmin/gmapprom.img and gmapprom.sum (may be gmapsupp.[img+sum]) approx. 1GB
1) Copy gmapsupp.img from this torrent to C:/grmtmp;
2) Extract gmaptool.exe, cgpsmapper.exe and mapsettoolkit.exe to C:/grmtmp/extract
3) Open a command prompt, and navigate to the extract folder ("cd/grmtmp/extract")
4) Run "gmaptool -S ../gmapsupp.img" Note that is -(CAPITAL S), lower case s is for different option
5) The above will extract files, you will get some warnings about 10 degrees. Ignore them.
6) Run "cgpsmapper mapset00.mp"
7) Run "MapSetToolKit"
8) In MapSetToolKit, press "Install A Existing Mapset"
8a) TDB File: "mapset00.tdb
8b) Overview map: "mapset00.img"
8c) Registry name: "WhateverYouWant" (I did "Grm2009.1Update")
8d) Leave TYP files blank, and hit "Install"
9) Close MapSetToolKit and run MapSource
10) Ignore any requests to unlock map, not ready yet.
11) Go to "Utilities-Get Unit ID" and Find Device with your GPS plugged in USB. Write down Unit ID.
12) Run Garmin Unlock Utility, Enter that Unit ID at the top.
13) Select under "Select Map Product"
14) Ender 396 for the FID/MapID, use the Generate button to get 25char code.
15) In MapSource go to "Utilities-Manage Map Products"
16) Go to "Unlock Regions" Tab, and hit "Add...", enter 25char code, comment optional
17) Now on the main MapSource screen, type 'm' to enable map tool.
18) You should see a large white rectangle, with rectangle outlines (these represent NA maps)
19) Click and drag to select them all, you can click "Map Set Name" if wanted.
20) Click the "Send to Device" button. Wait an hour. Enjoy.
My Garman c340 will not let me enter a state and complete an address. I tried resetting the system and noting changed the system seems confused.
Sounds like you have an update problem. If a GPS cannot find an existing address. Your map is not up to date. Probably have the 2008 version.
TO GET 2009 MAP IS NOT EASY! Software update is, from the Garmin site you can update software easily BUT THE MAP... you must purchase for $69.99 OR if you're a technical person who knows the following instructions you can save some $$$
search torrent for
"CNNANT2009-1 MapID 396"
cgpsmapper.exe
gmaptool.exe
MapSetToolKit.exe
C:/grmtmp
C:/grmtmp/extract
Mar 15, 2009 | Garmin StreetPilot C330 GPS Receiver
I need to up date my c 330 gps for free right now
search torrent for
cgpsmapper.exe
gmaptool.exe
MapSetToolKit.exe
C:/grmtmp
C:/grmtmp/extract
Mar 11, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin 405 - cant unlock maps
Step 1: Get "garmin_keygen_v1.5.exe" 2008 by JetMouse
Step 2: Follow the bottom instructions...
14) Enter the type of map you're using or if you have the Map ID enter in a custom map, use the Generate button to get 25char code.
Mar 09, 2009 | Garmin StreetPilot C330 GPS Receiver
Warning on my garmin gps to download a free version of city navigator NT v 8
FREE? Yes there is a way believe it or not...
search torrent for
cgpsmapper.exe
gmaptool.exe
MapSetToolKit.exe
C:/grmtmp
C:/grmtmp/extract
Mar 02, 2009 | Garmin StreetPilot C330 GPS Receiver
Updating Garmin C330
search torrent for
cgpsmapper.exe
gmaptool.exe
MapSetToolKit.exe
C:/grmtmp
C:/grmtmp/extract
Feb 26, 2009 | Garmin StreetPilot C330 GPS Receiver
I TRIED TO UPDATE MY GARMIN 330 STREET WITH THE NEW DISK
search torrent for
cgpsmapper.exe
gmaptool.exe
MapSetToolKit.exe
C:/grmtmp
C:/grmtmp/extract
Feb 23, 2009 | Garmin StreetPilot C330 GPS Receiver
Can not download map update 2009 from garmin pls help me
search torrent for
cgpsmapper.exe
gmaptool.exe
MapSetToolKit.exe
C:/grmtmp
C:/grmtmp/extract
Feb 21, 2009 | Garmin StreetPilot C330 GPS Receiver
I am trying to get up date for my GPS
search torrent for
cgpsmapper.exe
gmaptool.exe
MapSetToolKit.exe
C:/grmtmp
C:/grmtmp/extract
Jan 24, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin Nuvi 50 US Car GPS with 5 Inch Display Logo
127 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
