Question about Samsung SyncMaster 913V 19" LCD Monitor
I accidentally unplugged my screen without turning it off first and now I get a black screen that becomes white with different colour lines.
noone
  • 105 Answers
SOURCE: two vertical lines across screen
This is a common problem when LCDs are subjected to strong shock. Your internal circuits are damaged The panel itself may not be cracked but there is internal damage. I know of no cure or repair possible other than to replace the panel assembly.
Posted on Sep 24, 2006
  • 192 Answers
SOURCE: Screen flicks from colour to black and white
If it does it only on HDMI, then, the problem is the Main PCB. The HDMI cables are to heavy for flat panel sets. If the problem happens on just one input such as component and analog, then the problem is more than likely the source. Does the problem appear on DVD, but not the cable/satelite? If the problem appears on every input, then the problem is the main PCB. Hope this helps.
Posted on Apr 29, 2007
mail2pvs
  • 390 Answers
SOURCE: white screen on my camera and can take picture picture is black colour
hi
i think the LCD has been set to a very high brightness set the LCD brihtnes lower from the settings..
better more is to reset the camera to the default settings this would set the aperture, shutter, Exposure, LCD brightness and other settings to defaults and this would save from any unwanted changes than required
cheers
pls rate if it was any help
Posted on Jul 05, 2009
  • 144 Answers
SOURCE: samsung u600 different coloured lines on screen??
sounds like your ribbon is broken,it happens to sasungs often,get it replaced
Posted on Jul 15, 2009
  • 104 Answers
SOURCE: why does my samsung projection screen go black and
Did it make noise? The only moving part is the color wheel which is the only other part of the TV besides the lamp that is reasonably serviceable in my opinion.
Budget $200 to fix the problem in parts since you should replace the lamp or have a spare nearby.
Posted on Mar 28, 2010
Top half of tv is white it started with just a line from side to side and has become worst
half the picture on my tv screen turned completely white. ' IGN ...
www.ign.com > Boards > Community Central > The Vestibule
IGN
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET
www.cnet.com > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from www.cnet.com
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
https://www.youtube.com/watch?v=SawMHKpsYOA
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
https://www.youtube.com/watch?v=ue9IQwj7CVM
Feb 03, 2016 | Televison & Video
I have an Epson XP-202 printer which I use solely as a black and white copier. Accidentally I pressed the colour button for a copy which ( as the original colour cartridges are still in the machine) has...
Not sure about Epson but I had the same problem and the store where I buy my ink said that a lot of the printer companies require all the color cartridges with ink in them to work. My color use to disappear even if I just pushed black and they said that was the way they were made . They sell printers quite cheap but make their money on the ink. I got rid of mine and purchased a black only ink jet and it hardly uses any ink at all. Its a powder. You can copy many copies on eighty dollars worth of ink where the cartridges I went through several hundred dollars a year.
Jun 14, 2017 | Epson Office Equipment & Supplies
Black screen from downloaded xbox classic game
DO ANY OTHER GAMES YOU HAVE DO THE SAME THING ?
Jan 14, 2010 | Microsoft Xbox 360 Console
TV suddenly lost colour - gone black and white Virgin Media.
most likely the problem is due to a "lock up" you need to reset the system, unplug the set, and look in the back panel (I am assuming it is a digital (flat screen tv?) for a small (usuall) red nipple, again making sure the power is unplugged, depress the nipple with a bll point pen for about 5 seconds, wait a few minuets, and plug the set back in, you will most likely need to go to your menu for set up again, but you will be starting with a clean slate (so to sleak) and the tuner should then correctly pass the signal though
Sep 15, 2009 | Televison & Video
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
Black colour displaying become greenish and narrow vertical lines
Most LCD monitors have a default refresh rate of 60 Hz. Older monitors also have limited resolution. Please check your display settings and ensure you're not using a refresh rate higher than 60, or a resolution higher than what it supports. If either one is the case, you're lucky the LCD still works.
Aug 12, 2009 | Computers & Internet
Wii plays in black and white.
Check if the tv has different types of AV settings, as this affects whether the wii plays in black and white or colour.
Aug 04, 2009 | Nintendo Wii Console
Hp dv9000 switches on to show coloured lines on screen.
Hello
My first guess is that the screen circuitry has gone bad - although fixable. Use an external monitor to verify this. If the external monitor is fine then the screen circuitry is bad, if the external screen shows the same problem then the video chip or associated circuitry has gone bad. My company fixes these all the time.
Jul 28, 2009 | HP L1702 17" LCD Monitor
XB360 Screen colour changes and then disappears
Could possible be your television.
Or maybe your Xbox is overheating.
Try placing your Xbox in a cool spot, direct a fan at it, etc.
Or try getting a new TV or Xbox.
Jun 29, 2008 | Microsoft Xbox 360 Console
Samsung SyncMaster 913V 19" LCD Monitor Logo
29 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
