Where are the brushes on a hotpoint aquarius wmf740
When washer is onto spin rinse i keep getting door flashing on display clothes are not spun and tried on just spin machine spins very slow trying to locate the brushes on the motor but cant find them anyone help tell me were these are
  • 209 Answers
SOURCE: HOTPOINT AQUARIUS WF250 1500 SPIN
check the cold water supply, either from the mains pipe, there is no water getting into the machine, if water is there up to the machine check the solenoid for circuit, to do this unplug from electric, remove lid, and test the two wires on relevant solenoid, no circuit means faulty solenoid, (test with the 2 wires removed from solenoid) take care note position of wires to put back properly answer above based on info given
Posted on Sep 27, 2007
SOURCE: 'test' displayed on washing machine
After pressing different buttons and waiting 10 to 15 seconds after turning the power off, I have finally found the solution.
When you have pressed the "Start/Cancel" button to start your wash programme the LCD shows "test".
You must then press the "Start/Cancel" button which will give you the normal temperature and washing time and then importantly you must depress both the "Start/Cancel" button with the "On/Off" button which will give you a different LCD message and then it will automatically resets itself.
ALL THE BEST!
Posted on Feb 23, 2009
SOURCE: Hotpoint Aquarius WD440 Error
Remove the white plastic cover on the back near the bottom. To the right as you look at it their will be a black concertina pipe with a hose clip on its top edge. Undo this and pull the pipe downwards to reveal the filter. There will be a plastic ball inside (which is supposed to be there) remove this and clear out the cr*p.
Re-assemble as removal.
That should fix it
Posted on Apr 27, 2009
SOURCE: my hotpoint aquarius wd440 has flashing lights
First of all try cleaning the filter inside the back as described by others if this does not work there is a filter in the top. how you clean this is quite easy. all you do is remove the top of the machine by undoing the 2 screws at the back then pull top top backwards when you have removed the top you well see a large metal casing on the left if you are looking from the the back of the machine the filter is in there to remove the casing you pull the small pipe off then undo 5 star headed screws then gently pull the casing off noteing that there is a large pipe at the front when you have remover the casing you will see the filter (the small pipe you removed at the start fits on this filter) clean the filter then put it all back together.
Posted on May 17, 2009
  • 15 Answers
SOURCE: Hotpoint WF860 Cycle does not end
could b presure system blocked up find this on side of filter long plastic *****
Posted on Nov 29, 2009
Nov 29, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WD63 not spinning correctly
Two things to check.
Remove rear cover.
Remove large black hose onto drum
Remove and clean filter inside hose.
Next--remove top cover and check the brushes in the motor, if they are less than 3 or 4 mm long, then replace them.
Please rate my solution.
Thanks.
Nov 24, 2009 | Hotpoint Aquarius WD63 Front Load...
My machine is a hotpoint aquarius and after a wash the clothes come out of the machine smelley. I also have a grime on the rubber seal around the door
A couple of possibilities her:
  1. Washer not rinsing and draining properly
  2. You are doing too many low temperature washes
Solution to 1 is to check and clean pump filter.
Solution to 2 is, do more high temp washes, even if you do not put clothes in, do a 90 degree wash with powder in, this will help keep the smell from reocurring, and help keep the seal clean.
Thanks.
Nov 11, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius Wf740 F-08 just before rinse and spin.
Hi my Hotpoint WF740 keeps flashin H20. Does anyone know why please?
Jan 15, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Why do the lights just keep flashing?
Try unplugging it and rubbing the plug on a soft dry cloth, static electricity can cause problems.
Try opening and closing door acouple of times, if still no luck , suggest you call engineer
Dec 09, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wd440 flashing dryer heat button and onoff button !
I had to have a tech come out for the same problem two weeks ago. They had to clean the lint collector which you cannot get to on your own. He said now that this has been done everytime I use the machine, take the clothes out and then run a rinse spin cycle.
Aug 04, 2008 | Hotpoint Aquarius WD63 Front Load...
Does not spin and rinse properly
Sounds like motor is not coming up to spin speed. May be overheating, in which case you would need a new motor.
Feb 16, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WMA56 wont drain properly water leaking onto floor
pump is working water is only a trickle coming out so wont final spin
Nov 07, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Washing Machines Logo
167 people viewed this question
Top Washing Machines Experts
