I don't know what I did but when I "logoff", the next screen the comes up does not have "shutdown" highlighed for me to use. I have to log back in and then go to task manager to shutdown. How do I get the original "shutdown" feature working again?
Try this. If this doesn't work,please respond with windows version.
To resolve the issue, perform the following:
Click Start, Run.
Type gpedit.msc and click OK.
Navigate to the following path:
User Configuration\Administrative Templates\Start Menu and Taskbar
Double-click "Remove and Prevent Access to the Shut Down command"
Select "Not configured" or "Disabled"
Close Group Policy window.
When you click start button,Is the shut down option there?
You can download these 3 file to fix the problem.Save all to your desktop,extract the zip file,then save all to one folder,Restart in safe mode,go to the folder and run the progams,Use them in this order.Once you have ran them and they are finished,restart normally and all should be back to normal.
http://www.trendmicro.com/ftp/products/t...
http://www.trendmicro.com/ftp/products/p...
http://www.trendmicro.com/download/spywa...
Windows XP, service pak 3
