Question about HP Pavilion dv4000 Notebook
My HP DV4000 beeps when I press the power button and the screen will stay black.
It's making 3 beeps, one long, then 2 short, like beeeeeeeep, beep beep. It will stay on with a black screen (no backlight, no image even looking at it with a flashlight, so not a backlight issue).
  • HP Master
  • 32,281 Answers
This POST error code maybe -
one long, two short beeps
  • System board failure
  • Video adapter problem
  • LCD assembly failure
Posted on Dec 04, 2012
Testimonial: "I had already thought of that, but since I couldn't find any notebook beep code charts (there are plenty for desktops, instead) I asked for confirmation. This seems to be video card related. I think I'll just ditch this old notebook and get a new one. Thanks anyway."
    Habit-Forming:
  • 32 Answers
These are the problems that occurring no display.
1. Defective memory
2. Defective Video graphic card
3. Defective processor
4. Defective motherboard
Replace the defective parts for it to resolve the issue of your unit. Purchase your defective parts to HPParts us Computer Parts Power Supplies Electronics Hard Drives... Buy now!!!
Posted on Apr 04, 2014
SOURCE: 3 beeps at start
i had the same problem with the beeping, i changed the rams and now its working fine. works for me, good luck
Posted on Jun 17, 2008
SOURCE: one long beep, two shorter beeps - HP laptop will not start up
Hi...
I had the same problem...
The solution is only temporary and you will have to reapply it after around 5 to 6 boots cuz it'll just happen again (the beep syndrome).
Just heat up the laptop by turning it on and covering its air vents with your hands.
Then after you hear the beeps turn it off.
Turn the laptop on again and immediately turn it over upside down with the lid closed ofcoarse (simply put it on its back).Hopefully you wont hear the beeps and when you open up the laptop lcd...voila display.
Posted on Apr 13, 2009
frankzjm
  • 191 Answers
SOURCE: HP Pavillion dv5 startup problems, no screen 3 beeps in loop
Hi, you need do follow things:
1) check RAM in the back small cover of laptop, clean RAM pins and slots set back or change RAM position each other ,or replace other RAM(same model) if old RAM not works.
2) take out the wireless card in the back small cover that is MINI PCI slot, then turn on. sometimes it cancause this trouble.
help you fix it, and any question keep in touch please.
Posted on May 14, 2009
dilum_wonder
  • 59 Answers
SOURCE: Beep Codes for Troubleshooting HP Pavilion ze4125
remove and clean your RAM cards. use some contact cleaner with cotton wool to clean it. reinstall and try it.
Posted on Jul 20, 2009
SOURCE: hp dv6000 laptop beeps 4 times n won't display on start up
I had the same problem, i found it was because my RAM stick was installed loose. I removed and fixed it again properly.
Issue was sorted.
Posted on Mar 29, 2010
Tip
Fix the 80010514 error on your PS3
If your Play Station 3 (PS3) gets the 80010514 error somewhere, you can try this to resolve the problem:
1. Make sure that the power indicator on the Play Station 3 system is solid red. To do this, press and hold the power button until the PS3 beeps and the light blinks. Once the light has turned solid red, turn the power switch in the back off.
2. Turn the switch back on, then press and hold the power button.
3. Keep holding the power button even after you hear a short beep after 5 seconds.
4. After 10 seconds, you will hear another short beep and the system will shut down (release the button at this point).
5. Press and hold the power button again.
6. Continue holding the power button even after you hear a short beep after 5 seconds.
7. Release the button when two short beeps are emitted after 7 seconds.
8. As instructed by the on-screen message, plug in the controller and press the PS button
9. Select restore Play Station 3 system.
This should not affect any of your save games, demos, etc. but just to be safe you might want to back up to an external USB hard drive.
To backup saves, go to the Play Station 3 Save Data Utility, select the save you wish to copy and hit the Triangle button. Copy should come up as one of the options. If it does not then the save game is copyright protected and can’t be copied. If you can copy it, make sure you have a USB drive attached and copy it to that.
on Feb 02, 2010 | Video Game Consoles & Games
Hi my hp pavilion laptop DV5000 on start up has black screen and one long beep then 3 shot beeps then one long beep and another 3 short beeps. The lights stay on but nothing happens. The pc has been...
first remove the cover of your computer after switching off the system and removing the power plug the power the system and see whether the processor fan is working if not power off the system and remove the 24 pin connector from the smps to the motherboard and short the green and black pin of the conector from the smps and see the smps fan is working if not replace the smps if working then remove the memory from the slot and clean them or change the memory to which match the dimm slot an connect the connector and switch on the computer
Feb 26, 2011 | HP Pavilion M9040N Elite Desktop PC
I have a hp dv6208nr laptop . after pressing the power button the pc starts up the screen is black after a few seconds there are one long beep and two short beeps screen is still black pc acts as if it is...
Graphics card failure. There is no cure for the problem at HP but see if your model is on recall (as some are) or phone HP to find out if you can get a free repair for their poor quality cards
Sep 11, 2010 | HP NB199UA Pavilion Notebook
Blank screen, not reading dsc
try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 26, 2009 | Sony Playstation 3 (PS3) Console
Hp Have black screen & 2 beep sound
Motherboard/fans/loose wiring
Oct 01, 2009 | Computers & Internet
Screen goes black on my hp pavilion dv4000 notebook
Try connecting an external monitor to the laptop, power up the monitor first then boot up the laptop. The video data will switch to the monitor automatically, check if the monitor dislays a normal image and see if the image stays on the monitor.
Also press and hold the Fn key and press the F4 key, these keys toggle the video output between the LCD screen and the video port.
Test to see if this functions correctly.
Get back to me with the results of the tests.
Jun 03, 2009 | HP Pavilion dv4000 Notebook
HP Pavilion dv4000 does not power up.
I have had this happen a couple of times but not sure if its the same for you. There is a small button on the upper right that engages whenever the laptop screen is closed. I was experiencing the same thing when I accidentally brushed the button. I didn't notice anything happen but, I next pressed the power button and it came on???? I guess there is some dohicky in there that triggers the off feature. I haven't decided to ignore this with software yet.
I saw this while researching charging issues where a new battery is installed, calibrated and now will not charge?? any ideas?
Dec 13, 2008 | HP Pavilion dv4000 Notebook
Computer turns on, but won't work afterwords
Nev, the two loud beeping sound of the system when turning it on could be a problem with the memory or the system board.
Try disconnecting the power and take out the battery, then press and hold the power button for 5 seconds then look for the memory comparment and reseat it.
Keep me posted.
Thanks.
Nov 16, 2008 | HP Compaq Presario V2000 Notebook
HP Pavilion dv4000 Notebook Logo
154 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
