Question about Dewalt DW715 Heavy Duty 12" Single - Bevel Compound Miter Saw
Dewalt DW 705 Type 1 Hard to pull down to cut material
I have a dewalt dw705 type 1 miter saw. With the saw in the most upright position its hanging up some when you pull it down to cut your material. Hangs up to the point that when you pull it down the gaurd linkage is bending some. Also if you lift the gaurd with your hand to try and rotate it up and out the way it will catch the blade but once you get the saw coming down as if your going to cut something, the gaurd doesnt catch the blade, only does it if your manualy moving the gaurd with your hand. gotta be some type of adjustment to fix this. Sure could use a manual for it as well but cant find one. Any help would be greatly apprecaited.
    Champion:
  • 304 Answers
Go to www.2helpu.com that is the dewalt site. You might have to change the link arm that moves the guard up. They get bent over time. Check other parts on the raise and lower assy for wear at the same time.
Posted on Dec 14, 2012
5 Suggested Answers
  • 33 Answers
SOURCE: dewalt miter saw .
Either the blade or the guard is out of alignment. You will have to check and find out which one is the culprit.
Posted on Feb 13, 2009
  • 25 Answers
SOURCE: dewalt power saw wiring diagram for trigger switch
The Switching should go like this
(single letters denote wire color)
Y---o o---R
B---o o---B
The contacts where the black wires attach are the points on the switch that break when continuity is checked.
Posted on Apr 18, 2009
rowdy45176
  • 2176 Answers
SOURCE: DEWALT DW705 MITER SAW BRAKE DOES NOT WORK
Could be worn brushes, dirty commutator or a combination of both. Unplug the tool and remove one brush at a time noting the condition and length. Use a flashlight look into brush tube and also not condition of commutator. I would blow is out with compressed air and you can try turning the brushes 180 deg and retry. That is usually the problem
Posted on Jun 27, 2009
rowdy45176
  • 2176 Answers
SOURCE: the saw do not stop when i off the trigger
the commutator might be dirty, try and turning the brushes 180 degrees and you might have to clean the commutator with a stone for that purpose to seat the brushes.
Posted on Jan 14, 2010
Where can I order a replacement trigger switch
How to Install a Switch Kit on a DeWALT DW705 Miter Saw ...
? 12:35
https://www.youtube.com/watch?v=FJ1Wo2xufzI
May 15, 2013 - Uploaded by eReplacementParts.com
Get a replacement switch kit for your DeWALT DW705 miter saw ... kit on a DeWALT DW705 miter saw which replaces thetrigger switch (part ...
Miter Saw Parts ' Tool Parts Direct
www.toolpartsdirect.com/saw/miter-saw.html
Shop the Tool Parts Direct inventory of miter saw replacement parts. A miter saw is designed to quickly make cuts at a variety of angles. Featuring a pivoting ..
Oct 23, 2015 | Saws
How to replace arm locking pin on a dw705 Type 4 miter saw
Can't remember how much access there is at the back on that model, on some you have to take the main hinge pin out to get to it and move the top arm assembly out of the way. Not always the easiest of jobs.
Dec 09, 2012 | Dewalt DW715 Heavy Duty 12" Single -...
Dewalt DW 705 wont run
Having the same problem. removed the switch and had it tested. They said it's good. Checked continuity through the cord. Good. Going to replace brushes...but then while taking resistance readings I notice the yeloo wire on the left side of switch was shorted to the white. Is that just a ground and neutral? SHoud it read that way?
Sep 10, 2012 | Dewalt DW715 Heavy Duty 12" Single -...
How do I remove 12" blade from from dw705 miter
loosen the guard screw, UNPLUG tool first, move the guard out of the way, there is a spindle lockon the backside of the gearcase push it and slowly turn the blade until it engages and then remove the bolt, it is a left hand thread. DO NOT disassemble the guard, just loosen bolt and move out away from blade also you need to have the head in the raised position.
Oct 28, 2010 | Dewalt DW715 Heavy Duty 12" Single -...
Need to get owners / instruction manual for my Dewalt DW705 type 3 12" miter saw. Do you know where I can get one quickly?
Hello. DeWalt has 13 types of this saw on file. Here is the link to all:
http://servicenet.dewalt.com/Parts/Search?searchedNumber=DW705&searchType=1
Click on the "more details" arrow of the one that meets your needs, then click the PDF symbol in the top right of the "product information" tab.
If this helps, please rate a four-thumbs up. Thank You.
Sep 12, 2010 | Hitachi C10FCE2 10" Compound Miter Saw
Dewalt dw705 miter trigger won't pull/depress
DeWALT DW705 TYPE 8 12 Inch Miter Saw Parts Sounds like a bad switch, Since you don't have any money it go ahead a replce it. Good Luck
Sep 07, 2017 | Dewalt Saws
The saw do not stop when i off the trigger
Jan 13, 2010 | Dewalt DW715 Heavy Duty 12" Single -...
DW705 Miter saw Spark in motor Compartment
Yes spark in motor compartment is normal. You only need to worry if you see a lot of sparks flying out of the motor compartment! Most power tools will spark inside the motor compartment (particularly if carbon brushes are used).
Bevel and miter could be off... Consult your manual for how to adjust these correctly, but usually the bevel has a 0-degree setting screw or adjustment, and the miter adjustment on the saw is usually done by altering the fence position... Again check your manual for specifics on your saw.
Mar 19, 2009 | Dewalt Saws
Dewalt DW715 Heavy Duty 12"  Single - Bevel Compound Miter Saw Logo
169 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
