Where can i look for quality ceiling air conditioner?
What brands would you recommend I look at? Does not need to be the best, but should be durable.The best has very reasonably priced.
I broke one of my 4 glass shades for my ceiling fan, how can I get a replacement?
Since, "Hampton Bay" is the house brand for Home Depot, your best bet is to start there. Getting an exact replacement will depend on how old your Hampton Bay Ceiling Fan is. Some glass shades and/or globes are discontinued after a few years, as the trends in shades change.
Hope this helped you.
Jun 28, 2011 | Hampton Bay Heating & Cooling
I am wanting to buy a ductless mini split from ac-world.com and was wondering which is a better quality brand AM versus Celiera?
They are both equal in regard to quality. If you want the best your going to have to go with Mitsubishi.
May 01, 2011 | Heating & Cooling
My Dometic Rv ac is not cooling but, the fan does run..
Can you give me the model number of your AC unit. There should be a sticker on the bottom of the upper (roof) unit, that you can see when you take the filter down from the ceiling inside. Also need to know if it's a wall thermostat and what brand/model, or are the controls at the ceiling.
Apr 24, 2010 | Dometic Rooftop RV Air Conditioner
What's the recommended height to install the Mr. Slim indoor unit?
6"-10" from the ceiling. You do not want it to blow on you while you are sitting and you will need to be able to open the front cover to clean the filter.
Mar 29, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Unit quit looking for same trouble free quallity
your not going to find it.
21 years ago these units were built with better quality in parts, design, and overall construction.
Nowadays, its all about speed and quantity. I would recommend you calling a local dealer and looking into the higher efficiency systems. Yeah is a large expense up front by will pay dividends in the long run.
And if there is an option for an extended warranty up to or exceeding ten years, don't leave home without it. Best investment you could make.
Jan 27, 2010 | Intertherm P3RA-048K Air Conditioner
Totaline thermostat buttons hard to operate
This is a common problem with a lot of thermostat brands and line-ups.
You can go to any local hardware store and purchase a new thermostat for yourself. This will allow you to choose the one that suits your needs best as well as one you like the most.
I would recommend a Honeywell thermostat. They are high quality thermostats but will not break the bank.
You can install these yourself or call your local contractor to come install it for you.
Jan 25, 2010 | Carrier Heating & Cooling
On my 28 foot Itasca motorhome the air conditioner is leaking water through the gasket on the roof. I pulled the inside cover off and took out the four big boltd holding the roof top section, but I can't...
You need to find where the drain is. The water should flow to a drain and not into the unit. Once you get the condensation draining properly you can use a good quality silicone to seat around the unit. You might check at a RV parts place and find a product they recommend for RV roofs. Hope this helps.
Nov 19, 2009 | Dometic Rooftop RV Air Conditioner
Looking for clips to secure Rev Cyc A/C ducts to ceiling
look up furnace suppliers in buffalo, new york. cant remember the name offhand.
Jul 31, 2009 | Heating & Cooling
Best height of inside unit of a split AC
which type of mounting is suggested wall or ceiling, if it is suggested that wall mount is nominal then the height is optional, mount it as high as possible. If ceiling mount is suggested then closet to outside wall as possible
Jul 26, 2009 | Friedrich QuietMaster RS10J10 Air...
I HAVE A ROOM 21X32 HIGH CEILING. WHAT IS THE BEST SPLIT HEATPUMP TO INSTALL.
I myself am a fan of ductless splits. I would recommend either Mitsubishi or Daikin
Jul 07, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Heating & Cooling Logo
194 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
