Question about Sony 2GB Memory Stick PRO Duo Memory Card
Pls my sony memory card shows me formatting error
I cant access my pictures it shows formatting error
    Genius:
  • 1,234 Answers
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Posted on Aug 27, 2010
ERROR IOCTL CALL..CAN'T FORMAT MY 2GB MICROMAX FLASH MEMORY..
i have 500gb removable hard disk i cant access it and i cant format it it shows IOCTL error help help
yhabtea@yahoo.com
Apr 05, 2011 | Electronics - Others
My sony dsc-w100 digital camera says format error and hangs on. what shall i do??
Take out memory card from camera, turn it On and check does it show format error?
If yes, press Home, Memory option and format internal memory.
If camera does not show format error then put back memory card in and press Home, Memory card option and format it.
This will delete all files/ data and will refresh memory card, take some pictures and check.
If after formatting, still format error exist, put new memory card.
Nov 23, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
INSERT ANY NEW MEMORY STICK SHOWING FORMAT ERROR
Please format memory stick by camera Menu >> Format option.
If problem still exist, try another memory stick and check camera again.
Apr 25, 2009 | Sony Cyber-shot DSC-S650 Digital Camera
Sandisk microSD 2GB : well formatted on cellphone but...
its not the adaptor its the card hence it gives you the error means it can access it. is the card working 100% when you plug it back to the phone?
Mar 09, 2009 | SanDisk 2GB microSD Memory Card
SONY DCS T1 FORMAT ERROR C:13:01
Hi.. I think you have solved the problem yourself... replace the adapter with a memory stick... You have eliminated the micro sd card as bad... now try a new known good memory stick..
Thanks
jim
Feb 18, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Sony memory stick pro
r u havin card reader.....
if u hv....then
first take it out urs memory stick n fit it in to card reader n copy all pics frm ur memory card....
after copying it u should format d card frm computer.....
when u r joinning card reader wid to compter a new drive autoatically made on ur pc frm dat drive right click on it and chosse option format..........
den ur memory stick totally ger formated n free frm errors....
if u still hvin problem ask me for more soln. .......
Jun 16, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Format Error in Sony Cybershot
it could be a faulty memory card, but a more likely cause is that this stick isn't formatted yet. you can format it usually by bringing up the camera menu, then going to tools and format. you can also format it by using windows and a cardreader or your camera.
Mar 04, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
File Error
Hi, It might be time for a new memory card. A last effort you can try is to remove the memory card and insert it into a memory card reader connected to a PC. There are diagnostics and utilities that can be performed on your memory card since it will be treated by your PC as a removable storage. You can format the memory card, run diagnostics like Norton Disc Doctor or similar. If in any test an error shows, then you have just confirmed that is due for replacement. If after formating, scanning and checking it shows good, then you can try using it again. You can also try cleaning the little gold tips at the end of one side of the memory. Hope this be of some help/idea. Post back how things turned up or should you need further information. Good luck and kind regards.
Sep 30, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Format Error in Sony DSC-650
Please try with new memory stick. If it does not help please claim for an in warranty repair. If you need more info please advice.
Apr 12, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Sony 2GB Memory Stick PRO Duo Memory Card Logo
120 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
