Sony viao pcvd-17sm2 (perfect screen) cut cable due to my *ucking dog,,
Can some one help me to solve this problem! because i dont no how to connect the 13 pins in to a 15 pins standard vga cable, i try to follow the other instruction by connecting a color coding wires, but it's not worked,. Thanks people,, ^_^
  • jhanmhaykhel
    jhanmhaykhel Dec 08, 2012
    here saome picture,,,
Buenas, no puedo conectar el volumen de mi monitor VAIO modelo : PCVD-17SM2A . Me podr?an ayudar por favor
google translate spanish
Good, I can not connect my VAIO volume monitor model PCVD-17SM2A. I could? An help please
?nico v?nculo que pude encontrar
User Guide - Manuals, Specs & Warranty - Sony
https://docs.sony.com/release/vgns400-t300series.pdfUser Guide .... Using Your VAIO Computer . .... Using the Multiple Monitors ...... Wireless LAN and Bluetooth functionalities are available on selected models only. ..... To increase volume, press Fn+F4 and then M or ,, or keep pressing Fn+F4.
Sep 17, 2016 | Sony VAIO Computers & Internet
Sony pcvd-17sm2 cable cut
You can't really repair it. If you could, you would already know how to do that sort of wiring.
You're much better off replacing it.
Dec 04, 2012 | Televison & Video
I have a sony viao pcg-k23, when i open and power it on it has white displayed on screen white horizontal lines. what must be the problem? thanks
This is most likely an LCD screen fault. You could check the LVDS cable that connects the motherboard to the screen also.
Jan 21, 2011 | Sony VAIO PCG-K23 Notebook
We have a Sony Bravia and we cannot figure out how
check your connections first, dont use these connections with many pins, make sure use of those coaxial cable connections. if you dont have an indication on tv. check your cable for cuttings between main conductor and outer screen. using a avo meter.
Jan 11, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Screen shuts off
this happens when the processor gets over heated.--- normally the speed of the fan that cools the processor decreases due to dust in it.just clean the processor fan and apply a air blower with full pressure on it to remove all the dust.this will help.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Dec 21, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
How do I connect my Sony viao to my philips LCD
If your PC has a DVI port( ihope u have one) purchase a DVI cable and connect it to your TVs DVI port
DVI port
dvi cable
If your tv has no DVI port and only VGA port buy a vga cable and dvi to vga converter and connect to pc and use it
vga cable
you can also get a svideo to avi converter cable and use it to connect to your tv
svideo converter
Nov 27, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
My computer keeps crashing and a blue screen pop up about "check to be sure you have adequate disk space. Disable Driver" what should I do?
uninstall newly installed drivers for your hardware. The problem is due to the wrong installation of the drivers.Hope this solves.
Aug 31, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Sony Viao Display Problem
LCD driver IC or display IC is beginning to malfunction, it COULD be a diode, resistor, capacitor or the IC itself. It will require professional service to diagnose this issue.
Nov 26, 2007 | Computers & Internet
No power
I think this is not a very big problem check your charger adaptor and try to replace with another one i think it will solve the problem.
Sep 09, 2007 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Computers & Internet Logo
David Payne
David Payne
