Question about Maytag Neptune MAH6700A Front Load Washer
Drive belt needed
Hsa acode lr probllem with motor i think its the belt but need to look at the motor
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Remove the top to look at the belt. Here is the belt to order in case you need it.
Posted on Dec 04, 2012
Why is my Maytag washer showing lr code again?
If you live in North Hollywood, CA and need washer repair service call us at (626) 460-0903 or visit our website Washer Repair North Hollywood CA 747 248 4544 Samsung
Sep 03, 2017 | Washing Machines
I got a 97 cavalier the comprssor is shot and i weant to take out the compressor and find a shorter belt what size belt do i need
I would just leave things the way they are
Why spend time & money when you don't
have to
You don't just change the belt,thus the added expense
You need a bypass kit to replace the compressor
Check online or at parts store to research that
The car is 16 years old ,save your money & buy a
code reader for OBD2 or some tools to work on
your car,they always need updating
Oct 02, 2012 | Cars & Trucks
My Maytag Neptune washer is not spinning and I tried only Spin cycle for 12 minutes and gave LR error message. Pl help?
Hi, the Maytag Neptune front load washer LR or Locked Rotor error indicates and issue with the motor drive system. The motor control board is located near the floor on the right side. See Neptune Disassembly help to remove the door and front panel to get access, if needed.
I would unplug machine, remove all connectors and reinstall a few times and retry machine in case of any oxidation on the connectors. Also, check the belt and make sure it has not popped off. There is a rear access cover you can remove to take a peek.
In addition, there is a motor drive test you can perform to see if the inner tub will rotate at 50 rpms. You should have a document with your machine that instructs how to perform this simple test and it could be located in the top console.
Depending on which machine you have... If the motor control board has failed then you may have to replace the motor and motor control board since Maytag redesigned them because they were having reliability issues with them and they decided to change the motor technology they were using. See maytag maytag Neptune motor conversion kit for more info.
I hope this helps...
Apr 28, 2011 | Maytag Neptune MAH5500B Front Load Washer
When and how to apply HSA
hsa means HILL START AID. hsa is standard on isuzu's npr and nqr models fitted with manual transmission. hsa maintain truck-brake pressure until the clutch is engaged and limit vehicle roll-back. it is very effective for take-off on hills under load condition.
Feb 02, 2011 | Isuzu i-370 Cars & Trucks
My nordic track treadmill's walking belt stops when I start walking on it but the motor is still running although the front roller is not moving when I start walking on the walking belt. Do you think the...
Unplug the unit remove the motor shroud inspect the drive belt if the rubber feel slick then my recommendation is to replace the drive belt. Adjusting the drive belt may take care of the problem if you do not need to adjust it too tight. If you choose to do the adjusting and feel you have adjusted the running belt thinking it would resolve the slipping, then back the tension down until it the running belt is slipping then adjust until the slippage is resolved.
May 17, 2010 | Nordic Track Exercise & Fitness
Motor won't engage. Error code LR comes up, but the drum, belt, and pin coming out of motor spins freely. May I get possible ideas for troubleshooting PLZ ?
code LR is a Locked Rotor on the motor,but you say the motor runs,then you need to open the top cover by removing the screws inside the detergent cover after unplugging the unit,inside ther should be a tech diagnosis sheet to help you diagnose your problem,just from this its either a bad tach sensor or pick-up coil on the motor that senses the motor speed during all washing cycles,if this sensor is bad it will show up as if the motor isn;t running or a LR code
Apr 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune error code lr
i think this one is the one with the clutch. if it does it b4 it spins. put it on a spin. if it doesnt spin, u need a clutch. under the unit the belt is whapped on it
Feb 12, 2010 | Maytag Neptune MAH6500A Front Load Washer
MAYTAG NEPTUNE LR CODE
LR usually means that the the signal from the board is not getting to the motor either because of a bad connection at either the motor or the board or the motor itself is no good. Need to check the connections first.
May 13, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Getting error code#06 Lr Locked Rotor
I too had the Lr problem on my Maytag MAH5500B. We had it fixed once when it was still under warranty but when it appeared again this summer, I was told that it would cost at least $500 to repair -- in other words, get a new one.
With nothing to lose, I simply unplugged the unit, opened the front and reset (as in pull out and re-insert) the jumpers to the control unit on the bottom right. It's been working fine since and I run it at least twice a week. I noticed that the Lr error would appear when I interrupt the wash cycle once it begins. When the error message appears, I simply unplug it, wait a few minutes and start it up again.
It is after all, a computer...and all computer could use a reset once in a while.
Feb 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH6700A Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
