Question about Refrigerators
GE (TPX24PRDAAA) Side by sdie refrigerator compressor works intermittently.
Replaced defrost timer, start relay, and defrost thermostat. Same symptoms.
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
First, check to be sure the condenser coils and the fan is clear of lint and dirt.
Posted on Dec 04, 2012
fridgetech
  • 473 Answers
SOURCE: My GE Refrigerator Clicks for hours but will not start.
Most likely it has bad relay on the compressor.  I would replace the relay and overload first and see what you get.  If the compressor won't start after replacing the relay and overload then the compressor is locked up and that is covered by a 5 yr sealed system warranty.  Would appreciate a solved rating for expert advice.
Posted on Oct 18, 2007
  • 184 Answers
SOURCE: GE side by side refrigerator defrost problem
CHECK THE DEFROST HEATER FOR CONTINUITY. IF IT IS O.K. CHECK THE ELECTRONIC CONTROL FOR A FAULTY SOLDER CONNECTION ON THE DEFROST RELAY. THE ELECTRONIC BOARD SHOULD BE LOCATED ON THE BACK WALL OF THE REFIGERATOR BEHIND AN ACCESS PANEL.
Posted on Apr 10, 2008
  • 163 Answers
SOURCE: GE refrigerator TDX11SNYAWH.
check your defrost timer and see if it is stuck in defrost.
Posted on Mar 07, 2009
Healeyman
  • 1198 Answers
SOURCE: Compressor and Compressor Fan Not Working
Rotate the dial on the defrost thermostat, a big click is when it goes into defrost, a little more and it should turn the compressor back on. By overload protector, do you mean the one under the compressor cover?
Posted on May 03, 2009
SOURCE: Where is the defrost timer located on GE
This model does not have a defrost timer. It has a motherboard. You must jump out the plug to the main board to test the defrost circuit. In order to do this take the cover off of the main board, find the three wire connector on the base of the main board, connecter is normally blue in color. On the board itself it will identify termials as line, defrost, and compressor. To test you must create a jumper wire.Install the jumper in the plug terminals identified as line and defrost.This will turn the defrost heater on. If the heater does not come on, look for a defective heater or a defrost thermostat(mounted on the top of the evaporator). If the heater does come on replace the thermister(located on top of evap, white in color and has two white wires part#WR55x10025)
Posted on Jun 05, 2009
Mzd2766geq
1-check your compressor if clicking is heard it may be your relay or compressor
2- it may be stuck in defrost mode advance defrost timer if starts replace timer
3-check thermostat jump connections if starts replace control
Dec 10, 2013 | Maytag MSD2756G Side by Side Refrigerator
GE Adora model #DSS25KSRASS side-by-side - the refrigerator side is not staying cold and periodically quits working
This is a very common problem that comes with your model refrigerator. I need you to pull the refrigerator away from the wall, unplug power, remove the panel covering the compressor and feel the top of the compressor. Is the compressor too hot to keep your hand on the top? What I believe is happening is the control board or the start components are defective causing the refrigerator to cool off and on or periodically as you said. The solution may require a new control board=> WR55X10942 Main Control Board
and new compressor start components=> WR62X79 Run Capacitor
and the=> WR07X10057 Start Relay
Should you choose to repair your refrigerator I will happy to answer your questions. This model GE refrigerator has caused many complaints because of the expense and frequency of this type of repair. Many home owners are better off with a refrigerator that does not have a motherboard and uses simple defrost timers or defrost control boards. Here nis a link to a=> DSS25KSRASS Service Manual
GE ARTICA PROFILE TECHNICAL INFORMATION If you have questions please let me know, Thanks Sea Breeze
Nov 29, 2012 | Refrigerators
My side-by-sdie has started to emit an intermittent rumbling noise on the freezer side. The noise continues for a few minutes at a time, goes off for another few, then resumes again. Is there a...
It's common problem. Freezer fan hitting over ice formation behind freezer. It is due to non defrost problem.
Keep thermostat temp must be 5 degree and check timer and thermostat are working properly. Unplug your fridge and after all defrost icing, start again. If still noise behind freezer, check fan leaves are broken. If so replace it.thanks.
Jan 31, 2011 | Kenmore 53642 / 53644 Side by Side...
Hello, my girlfriends 2002 kenmore refrigerator stops cooling after a few hours of being plugged in. Replaced the thermostat, replaced the fan, and replaced the computer board (which I thought was the...
The compressor feel hot to the touch after she quits? Could be a bad compressor relay. The ice box might have a fancy control but it still has relays just like the older ones. themobilian_256.jpgthemobilian_257.jpg
Nov 24, 2010 | GE GDS20KBS Bottom Freezer Refrigerator
Freezer auto defrost doesn't work
Turn timer to defrost position and wait for 25 min.,If refrigerator starts auto. and compressor works. Replace Defrost thermostat.
Nov 17, 2009 | GE Profile PSW26P Stainless Steel Side by...
Kenmore 52532101 side by side freezer and refrigerator not cooling - any suggestions? Doesn't appear to be frozen up.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 25, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ge sidebyside, made in May,'02. It is not keeping things cold on either side. I have a thermometer in the freezer side and it is reading45 degrees. I have cleaned out the back and vacummed out the dust and...
I could be the same thing but there are three components to the defrost system. And this is somthing you can probably do yourself.
How to check everything
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator was not cold, now freezer is not working either
You hear a fan running - but do you hear the compressor motor running too ? Common problems are defrost timers and refrigerator being stuck into defrost - or control board problems or faulty thermostats - Those defrost timers tend to go bad more frequently on newer refrigerators compared to the older refrigerators !
Aug 17, 2009 | GE Refrigerators
Freezer thawed. Replaced temperature control, replaced defrost timer, replaced defrost thermostat. Compressor relay is cycling. No cooling still. Help!
Why were those parts changed? Was the compressor cycling on overload at the time?
If so, you should have first replaced the relay/overload combination and the see what happened.
Apr 26, 2009 | Refrigerators
Not cooling
there is a three prong relay that runs to the compressor that may be bad or the compressor itself has gone bad.
Jan 12, 2009 | GE GSL25LGTBS 25.4 Cu. Ft. Side-By-Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
