Question about Apple iPhone 5
Garbled voicemail 3 voicemails that are garbled when they used to be fine
4 Suggested Answers
  • 30 Answers
SOURCE: Voicemail does not work
Had the same problemwith my iPhone 3G this is how I fixed it -
1) From the iPhone 3G, I called my own iPhone 3G number.
2) Went through the setup. After finishing the ssetup Hang off the iPhone 3G.
3) Then the voicemail button on the iPhone 3G worked - first time, there was a **** pause, it asked me to enter my voicemail password that I had set in step 2, and that's it.
Good luck.
Posted on Jul 14, 2008
Nova_1
  • 196 Answers
SOURCE: iphone can't receive calls
check in settings/phone to see if you have maybe turned on call forwarding and it is being forwarded automatic to your voicemail box number
Posted on Sep 07, 2008
RPFinney
  • 385 Answers
SOURCE: Problem setting up voicemail
Check the procedure is correct.
1 Tap Voicemail, tap Greeting, then tap Custom.
2 Tap Record when you’re ready to start.
3 When you finish, tap Stop. To review, tap Play.
To rerecord, repeat steps 2 and 3.
4 Tap Save.
Hope this helps
Regards
Posted on Apr 17, 2009
How do I set up voice mail
How to record a voicemail
    1)Call your Voicemail access number, or press its corresponding shortcut key (usually the number "1").
    2)Press the key corresponding to "set your voicemail greeting" or "Set up your voicemail."
    3)Decide whether you want to use an automated greeting, which usually gives out your number and advises callers that you're not available.
    4)Follow the prompts to record and save your greeting.
How to Record Voicemail Message on LG Phones
Nov 20, 2015 | LG Cell Phones
Need new voicemail within office
Depending on your voice mail system, It can be handled using a different table for the new companies phone line and use different greetings for the four time slots.
Apr 30, 2013 | NorStar M7324 Telephone
Voicemail icon will not go away after i delete my voicemail how can i get that to go away?
This happens to me A LOT. It seems to help to delete voicemail messages when I have more than 3 signal bars. To get rid of the Icon you have to leave a voicemail on your phone, use someone elses phone and just leave a message, it should vibrate like it has a new voicemail but the count shouldn't go up, then just delete the message when you have close to full bars.
May 21, 2010 | HTC Touch Pro2 Smartphone
Panasonic DECT 6.0 always says "New Voicemail"
Try pressing and holding the MUTE (CLEAR) button until the handset beeps. Then clear all incoming calls.
Nov 23, 2009 | Panasonic KX-TG1033S Cordless Phone
4 Tap Save.
Hope this helps
Regards
Apr 17, 2009 | Apple iPhone 3G
Access voicemail from Nortel T7208
Have you set up the voicemail before?
OK, from your set;
-> dial FEATURE 9 8 1 (this is the code to get you to the voicemail)
-> then your passcode, if you never set up the voicemail, the temporary password is 0 0 0 0 (four - zero's).
-> if this is a new installed voicemail, the telephone system will tell you al that you need to initiate the voicemail box.
Jul 29, 2008 | Nortel Business Series Terminal T7208 -...
Good luck.
Jul 14, 2008 | Apple iPhone 3G
Cannot receive voicemails
Is it distorted when you get a call also ?
May 12, 2008 | Motorola Mobility MOTORAZR2 V9 Cellular...
Voicemail reset
Norstar Common Voicemail Features To Check Your Voicemail:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
To Change Your Personal Greeting:
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
To Record Your Alternate Greeting (Used when on vacation or out of the office.:
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the ChOOSE softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting
took this from a guide i found, helped me out
Apr 30, 2008 | NorStar M7310 Corded Phone
Resetting company voicemail
4. Leave message
took this from a guide i have, might help you guys out
Jan 07, 2008 | NorStar M7310 Corded Phone
Apple iPhone 5 Logo
87 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
