Question about HEWLETT-PACKARD ELITEBOOK 2530P BUSINESS NOTEBOOK NN803UPABA PC Desktop
Hp elightbook caps lock and num lock one blink 5 times
    Habit-Forming:
  • 135 Answers
PROBLEM WITH BIOS
REMOVE CMOS BATTERY IF IT VISIBLE
AND REMOVE LAPTOP BATTERY ALSO
DONT CONNECT POWER
PRESS AND HOLD POWER BUTTON FOR 30 SEC
THE POWER IN BORD WILL ZERO
AND JUST CONNECT POWER WITHOUT BATTERY CHECK
IF NOT HAPPEN TRY 4-5 TIMES
Posted on Oct 30, 2013
What does it mean when your laptop's power lights flash ? Including the power button?
"The following table illustrates the meaning of blink codes used on some notebooks with EFI environment.
The blink or beep codes on your computer may have different meanings. When you contact HP for
support, the agent needs to know the model of your computer and may ask you about blinking LEDs
or beeping tones to help troubleshoot a startup problem.Meaning of Sample Blink Codes for some EFI Notebooks Number of Blinks or BeepsLocation of Blinking LEDsComponent Being CheckedError Condition
Continuous glowBattery power LEDBatteryThe AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.
1time---Caps Lock/Num Lock-----CPU------------------CPU not functional
2time---Caps Lock/Num Lock-----BIOS----------------BIOS corruption failure
3time---Caps Lock/Num Lock-----Memory-------------Module error not functional
4time---Caps Lock/Num Lock-----Graphics--------------Graphics controller not functional
5time---Caps Lock/Num Lock-----System board----------General system board failure
6time---Caps Lock/Num Lock-----BIOS-------------------BIOS authentication failure
Continuous blinkAC power adapter LEDPower adapter Insufficient power"
Nov 01, 2012 | Compaq Computers & Internet
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Dec 01, 2011 | HP Computers & Internet
On My Dv5-1125nr both the caps lock and num lock keeps blinking when i turn it on. It's wont boot at all. What kind of hardware problem is this?
First remove the battery and power cord for about a minute. Then plug back in and see if that helps. Otherwise please read the following:
Aug 03, 2011 | HP Pavilion dv5-1125nr Notebook
The capslock and the numlock leds r flashing continously. the screen is blank
How many blinks between pauses if there are pauses? Look at this chart.
Number of Blinks or Beeps Location of Blinking LEDs Component Being Checked Error Condition Continuous glow Battery power LED Battery The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook. 1 Caps Lock/Num Lock CPU CPU not functional 2 Caps Lock/Num Lock BIOS BIOS corruption failure 3 Caps Lock/Num Lock Memory Module error not functional 4 Caps Lock/Num Lock Graphics Graphics controller not functional 5 Caps Lock/Num Lock System board General system board failure 6 Caps Lock/Num Lock BIOS BIOS authentication failure Continuous blink AC power adapter LED Power adapter Insufficient power
Jun 30, 2011 | Compaq Presario Notebook
Laptop wont boot up to anything, just a black screen when you turn it on and the light at the cap locks flashes 5 times and thats all.
Number of Blinks or BeepsLocation of Blinking LEDsComponent Being CheckedError ConditionContinuous glowBattery power LEDBatteryThe AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.1Caps Lock/Num LockCPUCPU not functional2Caps Lock/Num LockBIOSBIOS corruption failure3Caps Lock/Num LockMemoryModule error not functional4Caps Lock/Num LockGraphicsGraphics controller not functional5Caps Lock/Num LockSystem boardGeneral system board failure6Caps Lock/Num LockBIOSBIOS authentication failureContinuous blinkAC power adapter LEDPower adapterInsufficient power
Oct 10, 2010 | HP Compaq 6735s Notebook
Power light comes on but not working
First you need to determine how many blinks you are getting when you try to power on the laptop. Check the blinking codes below and reason behind that for HP Compaq laptops Blinking battery power LED Battery Insufficient charge on the battery Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional Blink: 5 - Caps Lock/Num Lock - System board General system board failure Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure You need to first Remove the memory module (RAM)- Try to power on the laptop ? then again reset it and try to power on. Check whether it is coming on or not. try the same procedure with Hard drive. If laptop is getting power on after removing one of the device then we can be sure that that particular device is faulty and we can change that then? Let me know if you find any difficulties doing this.. I hope this will help you to get it work. Plz vote for me..Dreamkam
May 27, 2010 | Computers & Internet
Compaq 6735s notebook pc goes to HP screen, but wont boot
Plz get back so I can suggest you the steps to resolve the issue.
Dreamkam
May 24, 2010 | HP Compaq 6735s Notebook
Hp compaq powering and nog display what do i do to
First you need to determine how many blinks you are getting when you try to power on the laptop. Check the blinking codes below and reason behind that for HP Compaq laptops Blinking battery power LED Battery Insufficient charge on the battery Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional Blink: 5 - Caps Lock/Num Lock - System board General system board failure Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure Well Check for the below link it will provide you the steps which you need to perform to isolate the cause so that we can determine which hardware of the laptop is causing this issue. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&cc=us&lc=en&dlc=en You need to first Remove the memory module (RAM)- Try to power on the laptop ? then again reset it and try to power on. Check whether it is coming on or not. try the same procedure with Hard drive. If laptop is getting power on after removing one of the device then we can be sure that that particular device is faulty and we can change that then? Let me know if you find any difficulties doing this.. I hope this will help you to get it work. Plz vote for me..Dreamkam
May 21, 2010 | HP Pavilion dv6000z Notebook
My laptop does no more boot up. As soon as i start , the caps lock and the scroll lock lights keep flashing continuously and the fan even does not run.
Well hellonihar, As far as your issue is concerned it seems to be some hardware issue. LED
Component
Error Condition
Battery
CPU
CPU not functional
BIOS
Memory
Graphics
System board
BIOS
Apr 19, 2010 | HP Pavilion dv5-1000us Notebook PC
HP DV6110us: 4 beeps, no boot
besides the beeps which indicate a motherboard timing issue. There should be LED blinking codes given on the front LEDs. I will include the blink codes below, but lets try to at least get the system up and running. First, I would like you to remove the RAM sticks from the laptop and just reseat one stick back in the machine. Try to boot with that one stick, if it does not, try the other alone. There have been issues when reseating the ram or re-installing it have temp. fixed the issue. If it does reboot, go to the HP support site, put in your model number of your laptop and download and install an updated BIOS. Below are the blink codes that may narrow down the problem.....
HP DV6000 LED Blink Codes
LED Component Error Condition
Blink: 1 - Caps Lock/Num Lock CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock System board General system board failure
Blink: 6 - Caps Lock/Num Lock BIOS BIOS authentication failure
Oct 22, 2009 | HP Compaq Pavilion dv6110us Notebook
HEWLETT-PACKARD ELITEBOOK 2530P BUSINESS NOTEBOOK NN803UPABA PC Desktop Logo
150 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
