Question about Home
How to reset neptune exotic electric shower - Home
I need to know why i have no power light on my triton shower unit ?
check the circuit breaker is on & reset the thermal cutout on the unit
Nov 26, 2014 | Home
Keeps going from boiling hot to cold
At a guess either the shower head has become clogged/calcified or the piping inside the shower has become so.
This means that water stays in the system too long, becomes over heated and the failsafe cut off activates.
Try cleaning or replacing the shower head.
Jan 30, 2012 | Neptune Home
I have a neptune shower. Solo. when I put the shower on it runs for about 2 mins then just switches of if I then wait for about 5 minutes it comes back on but still does the same thing
remove the low flow guts (if possible) in it and give it a try, these low flow filters have created issues like this many times..
Best regards
Ck
Jul 28, 2011 | Home
I have a neptune exoctic 9.5KW the temperature will not adjust it stays hot any advise please
This sounds more like a problem with a mixing valve however, I cannot find your model number. With more info I will continue to look but, what I would need to know is, is this used with a single or double faucet and does it heat it's own water or use existing hot water supply. I am giving you Neptune's site with contact info if that helps. They have Canadian and US toll free numbers, but recheck that model number.
http://www.produitsneptune.com/en/a_propos/nous_joindre.php
May 13, 2011 | Neptune C2002 Nirvana 9in. 2 Function...
Grohe wireless HP electric shower has service code 01 on main switch in shower, and no flow of water.
I had the same Service Code 01. The solution is simple. Switch off the power for the shower for a minute or so usually located outside of the bathroom. Switch it back on and you should hear the unit (if it's close by) resetting itself. Switch on the shower and it will tell you to wait, then with a bit of luck it should wizz into action.
Sep 14, 2010 | Home
Is there a reset button?
No reset button.
Probably a bad thermal fuse located on the blower housing.
Jul 07, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Neptune shower 9.5kw suddenly stoped working.
I had the same problem and when i researched the problem on the internet it was suggested I buy a new Solenoid, which can be bought from the net for about £17.00. I fitted it myself and the shower has carried on working for about 4mths but has now stopped working again so now looking at getting a new shower instead. IT was a good stop gap though and for that price worth giving it a go
Apr 04, 2009 | Neptune C2002 Nirvana 9in. 2 Function...
Neptune dryer won't come on after power failture
repl/ thermal fuse // is it gas or electric,, plz check on back
Nov 24, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Home Logo
503 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
