Question about Jandy Lite 2 Natural Gas Pilot Light Heater
Jandy lite 2 pilot wont light
Cant get my pilot to stay lit. Flame seems weak with i try to light it.
    Champion:
  • 305 Answers
Dirty pilot tubing or weak pilot generator
Posted on Mar 13, 2014
  • 22 Answers
SOURCE: Jandy, Lite 2 Pool heater wont kick in
3/4 pipe line will work and will keep heater from sooting up.
Posted on Feb 18, 2009
SOURCE: the pilot light on my pool heater is on but I am
My problem has been solved. A friend looked at it and discovered that I have a short in one of the wires. Thank you for your quick response in this matter.
Posted on Aug 22, 2009
  • 246 Answers
SOURCE: Jandy Lite 2 LG Model not firing up. Was working during day
ok 24 v at the transformer is yes than a safety swicth turn the heater off check fuses
Posted on Oct 15, 2009
  • 990 Answers
SOURCE: Model LG Lite 2 pilot is lit but the burners will not light
If this is a standing pilot you will want to check your voltage out put from the pilot. For this you will need a milivolt meter. The pilot should supply 500-700mv (1/2-3/4v) It only takes 200mv to open the pilot valve but needs another 300+ to open the main half of the gas valve. This would be the first thing I would check. If this is the problem you will need to replace the pilot assembly. If your getting the power you need from the pilot then it is probally your gas valve itself. Good luck.
Posted on Apr 25, 2010
Biggdex35
  • 333 Answers
SOURCE: I have a Jandy LITE2 LG325. Only two years old.
Does the pilot light stay light? Or light then go back out? If it is doing that then it is the thermocoupler. looks like a wire that is in the flame of the pilot light. Other than the sparker. That is what dectects that there is fire in the pilot light before it starts the gas. Safety thing. So if that isnt detecting fire, then it will never let the gasvalve open up, Try taking some steel wool or real fine sandpaper and clean up that sensor. The wire. It builds up a thin film on it from gas burning.
Posted on May 11, 2010
Ignites but wont stay lit
I started getting the FL2 ignition failure error code on my Jandy Lite2 Spa heater again this week. I seem to get some variation of this problem every few years, by which point I've forgotten some of the details like which screws not to take out.
So, in hopes of saving someone else, and possibly myself, some
time in diagnosing this, here are some notes and pictures re
how I fixed it.
One time it was a bad ignitor. That's the part w/ 2 white wires sticking out just above the burners in the first shot. It's easy
to order online and replace.
The harder problem which I've seen most often is when the burner lights, but shuts off after about 5 seconds because the flame sensor doesn't detect the flame. The flame sensor is the glowing red rod to the right of the flames in the first picture. I took this shot after
cleaning it and getting the heater working again.
The second picture shows where it's mounted below the burner w/ one black wire leading to it. Don't remove the screw on the flame mount as the nut behind it comes off and is a bear to get back on. Besides, there's another screw that's nearly impossible to get to that keeps you from removing the sensor w/o removing the burner assembly.
However, I've found I can reach up from below w/ some steel wool and clean the corrosion off the flame sensor rod and that has fixed it
at least 3 times as I recall.
You should also check the burner tubes to see if they've been blocked by spiders. That happened to me once on a gas grill. Be sure to keep your face back when testing w/ the door off so you don't get singed.
Hope this helps!
- Bruce
ignites-but-wont-stay-lit-zltpmto2tdzhf4nie1bxyhzb-5-0.gif ignites-but-wont-stay-lit-zltpmto2tdzhf4nie1bxyhzb-5-2.gif
May 17, 2014 | Jandy Lite 2 Natural Gas Pilot Light...
I have Laars Lite2 125k BTU Propane. pilot stay lit and after some time hear click sound in gas valve but it will not fired up and also pilot goes off right away.
It sounds like you need to replace the pilot generator. This is the metal cylinder that sets in the flame of the pilot and supplies voltage to the system. When it gets weak, it will support the pilot valve to remain open, but when the main valve tries to open the pilot generator cannot provide enough electricity, and everything shuts down. It's a prime suspect in your situation.
Oct 08, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
Pilot won't stay lit
needs new pilot generator if good flame just need new thermocoupler thats the piece that sticks up
Sep 04, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
Why won't the pilot light stay lit?
You have a "pilot generator" that sits in the flame of the pilot light. This generates a low voltage output from the flame of the pilot light. This voltage goes to the gas valve and tells the valve that the pilot is lit and to keep the pilot gas line open.
In almost all cases replacing the pilot generator will resolve the issue . They run about $60-$75.
Other causes may be the gas valve itself or a short in the safety loop, in either case should be looked at by a pool tech.
Jul 10, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy lite 2 pool heater will not stay lit.
I'm having the same issue as the above user with Jandy Lite 2 (which from what I can tell stands for the number of times that you can get this POS to work annually)!
The unit LIGHTS OFF, but WON'T STAY LIT! Igniter engages, gas valve opens, unit lights, burns for 10 seconds, and flames out. Error code FL 2, after third attempt, already replaced the flame sensor....
May 12, 2013 | Pool & Spa
What is the flame sensor
The flame sensor is attached to the pilot light. It's down on the right side of the burner tray and usually has an orange wire attached.
The flame sensor lets the heater know that the pilot light has been lit and it's okay to open the main valve.
images?q=tbn:and9gcs_-csiy0xlxc4vgn5fxb5i4km7zxxkzfpham9qknrvchqj1v19hq
Mar 06, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy LG250N pilot won't stay on after releasing switch on gas valve. Main switch on unit is off. I am able to keep pilot flame on for one minute by depressing switch but pilot always goes out after...
Thank you for posting your question here on Fixya.com.
No, the pilot generator or the pilot head itself is the issue. You need a good, solid blue flame across the generator to get enough power to hold the switch open when you let go of the knob. If the pilot flame is week or not aimed across the generator it will not stay lit.
If it is but the generator is old and weak, it will go out as well. If you can see the pilot flame and it is a nice blue color, replace the generator. If it is not, disassemble the pilot and either clean it out or replace it.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Aug 06, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
How to I start my heater
If it is this heater, then you must:
1- turn the toggle switch to the ON position.
2- Turn the gas valve dial to the PILOT position.
3- Depress the pilot button while pressing the ignitor until you see a flame. Continue to depress the pilot dial for about 30-60 seconds.
4- let go of the button, and the pilot flame should stay lit. If it does , then turn the gas valve dial to the ON position.
5- Set the temperature and your done.
Apr 27, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy Lite 2 Natural Gas Pilot Light Heater Logo
261 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
