Question about Ovens
Lg combi oven error code F2 - Ovens
  • 146 Answers
SOURCE: F2 code and consistent beeping with my Maytag Electric Wall Oven model CWE5800 or CWE4800
The F2 code indicates a stuck relay. You will have to replace the relay board. It may be a stand alone board or it may be part of the ERC Electronic Range Control. If you know how to check you won't have to call a tech.
Posted on Dec 21, 2007
vitg55
  • 70 Answers
SOURCE: dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
Posted on Dec 18, 2008
SOURCE: F2 E3 error code- Oven won't turn on now
I ended up calling a technician to come out and look at it. He said that the front panel where you push all the buttons went out and I would need to get a new panel.
Posted on Feb 18, 2009
  • 19 Answers
SOURCE: F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
Posted on May 09, 2009
  • 84 Answers
SOURCE: error code E6 F2
We repair these control boards frequently. The E6 F2 error is very common for whirlpool ovens and almost always is caused by the control board. It can be repaired quickly and reliably. www.fixyourboard.com
Posted on Dec 13, 2009
Why combi oven error code 32
If it is a Rational CM or CMP gas oven, then there is a problem with the ignition module.
Feb 03, 2017 | Combi Ovens
Hi I need a list of error codes for an Angelo Po Combi oven. Model number is FCV101EDS
F0 - No Alarm Signal
The main control board in your oven has failed to communicate with the alarm. This is most likely a fault with the control board itself, which may need replacing.
F1 - Door Not Locking
If there is an issue with the door lock in your appliance you may see this error code. Check the door lock and the wiring and connections to it to get to the cause of the fault
F2 - Door Not Unlocking
The opposite fault to the above, this fault indicates your oven door won't unlock. Once again you'll need to check the door lock mechanism and its wiring and connections. This fault could also be down to the oven thermostat as this could be giving an incorrect temperature reading, preventing the door lock from being released.
F3 - Self Test Error
Turn off your appliance, unplug it for five minutes or so and plug it back in again. Doing so should clear the F3 error code. Easy as that!. If it does not clear the problem you are likely to have a fault so see the links to our diagnosis videos below.
F4 - Temperature Sensor Fault
If you see this error code you'll need to check your temperature sensor and the wiring and connections between the sensor and the main control board. You may need to replace the sensor.
F5 - Control Board Error
This fault suggests a problem has developed with the main electronic control board in your AEG oven. It may need replacing to bring your machine back to full working order again.
F7 - Mains Supply Issue
You'll see this fault if your oven has detected a problem with the power coming into it. This could mean your appliance has been wired in incorrectly. You'll need to check the mains supply connection to your oven to get to the bottom of this error code.
F8 - Power Supply Issue to Control Board
The main control board is not receiving power as it should. Check the wiring and connections to it. If all the connections are fine, you'll possibly need to replace the control board.
F9 - Processor Auto Resetting
As with error F3, turning off and unplugging your appliance for five minutes before plugging it back should reset and fix this fault code.
Oct 24, 2016 | Combi Ovens
I replaced circuit board in whirlpool combo microwave / oven, shows fault code F2, error code E1.
Did you get the circuit board from a trustworthy place?
It is a circuit board error. Did you install it correctly - right wires to right connections?
Control displaying F2 E1:
There may be a problem with the User Interface (Touchpad), or the associated wire connectors.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation
Have to go the long way to bring up the link by first:
e1 f2 whirlpool oven Google Search
and then click on https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjprvf2_7nJAhXKVRoKHe7zAmMQFggdMAA&url=http%3A%2F%2Fwww.whirlpool.com%2Fproduct-help%2Ferror-code-oven-f2-error-code-f2-e1%2FPH7389%2F&usg=AFQjCNFoDK8E-zgNHF3Kp4EoihGu1tbyEw
Dec 01, 2015 | Whirlpool Ovens
I self cleaned the oven and over 12 hours later am getting a f2 error. How do I fix it?
The F2 error code means that the oven over heated by at least 100 degrees and the oven temp.sensor needs to be replaced.
On the self clean cycle the oven temp can easily reach over 600 dergees and therefore the sensor thinks it got too hot. If you have not already done so the F2 can be cleared by pushing the CLEAR/OFF button on the control...if the F2 error code reappears the sensor has became defective and it would need to be replaced.
GENE
Sep 05, 2011 | Jenn-Air WW30430P Stainless Steel Electric...
F2 error code
F2 E6 says this:
1. Check keypad connector for firm connection.
2. Press CANCEL. If error code returns after 60 sec., replace keypad.
3. Replace control
Nov 10, 2009 | Whirlpool GBD277PD Electric Double Oven
My RBS275 oven has E0 F2 error code
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!#!#
Aug 16, 2009 | Whirlpool RBS275PD Electric Single Oven
May 09, 2009 | GE JRP15 Electric Single Oven
Dacor single oven flashes an F2 error code and won't stop beeping!!!
Oct 26, 2008 | Dacor MCS130 Millennia Electric Single...
Kebc207 oven error code E1 F2
This is information from the Tech Sheet.
Fault Code F2 - Error Code E1: Code Explanation: Keypad keytail not connected. Recommended Repair Procedure: 1. Check keypad connector for firm connection. 2. Press CANCEL. If error code returns after 60 seconds, replace keypad. 3. Replace control.
Jul 15, 2008 | KitchenAid KEBC207 Electric Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
