Question about Samsung Galaxy GT-S5570
Galaxy mini wont connect to wifi
My phone wont connect to wifi, it keeps trying to but connects then disconnects straight away, tried reset to factory settings, tried the live battery pull, tried the code everyone says to type in but that makes it worse by saying im out of range, its not a router issue either as i have a laptop and an iphone which all connect fine, can someone please help with this issue
  • kerry warr Dec 04, 2012
    thanks guys, i tried darrent7 but wasnt exactly the same so selected share my phone as a hotspot and it connected by its self
    and then it stopped again
    New Friend:
Versions of Android that I use Will not connect to an AD HOC Network. My suggestion is to download and install Virtual Router Manger v0.9 Beta on your PC, TRUST ME, you will not regret it. Got my Samsung Mini Galaxy connected within minutes after installation.
On a side/bonus note: on your phone, download and install "AirDroid". Once installed and started, go to your PC and open an internet browser OTHER THAN Internet Explorer. i.e. Firefox... from there, connect to the address listed in AirDroid and you can manage/copy files/update contacts/create messages ALL through a web browser on your PC and it will send it to your phone, WIRELESS... GENIUS!!
Posted on Dec 06, 2012
  • 4 Answers
SOURCE: Why does my Samsung Jet say NO response from AP
What worked for me was to go into SETTINGS then NETWORK SETTINGS select CONNECTIONS then click your routers name then scroll down to NETWORK KEY type in your password and then SAVE then try connecting! hope it helps!
Posted on Feb 25, 2010
SOURCE: Samsung Galaxy GT-I9000 keeps trying
  • Go into settings
  • Wireless and settings
  • Wi-Fi settings
  • Click on the menu botton and select advanced
  • Select use static IP
  • IP address would be a random IP address from your wireless router
  • Gateway would be the gateway address from your wireless router
  • The netmask is your subnet mask address
  • The 2 DNS addresses are your Default Ip address from your own router and wireless switch
  • If you have issues copy the details from the Ipconfig /all command from Dos
Posted on Jan 02, 2011
asber
  • 291 Answers
SOURCE: I have a Samsung Jet S8000 which say
check your wifi settings by turning on your wifi, instead of selecting wpa or wpe, select infrastructure and select none for password. try also dragging your wifi home network to your phone wifi icon. and check.
Posted on Jun 11, 2010
SOURCE: My Samsung Tocco wont connect to my laptop with the software on
I think u would not had installed the drivers software properly. Uninstall the drivers for ur phone in ur laptop . then without connecting the phone to the laptop install the drivers . now restart and connect the phone to ur laptop . go to add hardware option and add the phone. now it'll ask for the location of software. select the option as cd. it'll ask for the port no. and all other details.. give them correctly ... select ur phone from the list and install it. now ur phone is ready to work with ur lap top
Posted on Mar 08, 2009
  • 4 Answers
SOURCE: cant connect my samsung jet wifi to my home router
Well if you cant connect, you may need to go to your hub setting and check the WEB KEY you can then put this is manually and that should do it, i have a samsung jet and i did it this way and now i can connect every time, hope this helps :D
Posted on Aug 13, 2009
My wifi keeps disconnecting and have to restart phone to reconnect, but only lasts for maybe an hour
Samsung Galaxy S 4G Smartphone: WiFi disconnects (have to restart phone to reconnect, does not scan for WiFi connections):
Hello. It could be that your "Auto Network Switch" setting is on..
What Auto Network Switch does: when the WiFi gets too low the phone automatically switches to cellular, and when cellular connection gets too low, the phone will switch to WiFi
All Samsung Galaxy's are not alike for it's menu settings.. but you can try:
for S4 and up:
Settings>hold down on WiFi settings for a second then let go > un-check box at top for "Smart Network Switch"
for other Samsung Smartphones see the attached video below:
If your device is having issues trying to scan for your router.. try turning off your router for 2 minutes, then turn it back on.. make sure you wait a few minutes for your router to properly boot back up before you try scanning for your WiFi network again
Jan 31, 2016 | Samsung Galaxy S 4G Cell Phone
On my galaxy s 5 phone it started today dropping the WiFi signal every 2-4 seconds and I can't do anything that is done through the WiFi
You should test the connection with another phone, tablet or wireless computer, to exclude the router. If the other device also suffers from the connection, you know it must be the router. Only when you 100% certain (Don't make assumptions, always test) it is not the router, you could start with the phone, like to reset it or setup the complete connection again.
B.t.w. when your phone does connect to another router and works fine, agin that would be prove your router needs all the attention.
Feb 06, 2015 | Samsung Galaxy S
Why does my Samsung S3 galaxy tab keeps disconnecting from wifi?
I encountered the same problem when streamed something through wifi. The solution was in wifi (on the transmitter side) settings. Having no idea what wifi point you're using have no suggestions
Sep 02, 2014 | Cell Phones
Wifi mac aderss
My best advice is to do a Factory Reset!!>>Settings>Privacy>Factory data reset. A good idea is to be near WiFi hotspot, best of luck.
Apr 12, 2014 | Samsung Galaxy S GTI9000 Smartphone
Wifi problem in Samsung Galaxy Grand GT i9082
give me the wi-fi solution when i connect to wi-fi modem always shows authentically error occurred.........
Jul 11, 2013 | Cell Phones
Samsung Galaxy GT-S5570 Logo
1,496 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
