Question about Health & Beauty
How to fix SilverCrest kitchen scales reading wrong weights,
  • fb62685
    fb62685 Dec 04, 2012
    I had already solved this after a lot of playing and research, put I thought I;d post it on here for others as the answer was different for other scales listed here. What I did was press the 'Button 1' and 'Button 2' together for 5 seconds. This powered it up and then the display showed 'Cal' with a number on the screen. I pressed 'Button 1' again and it said 'Zero' and then displayed the numbers '0000'. Then I added 1kg of weight and it said 'Cal1'. Then I added 3kg of weight. It said 'Cal2'. Then I added 5kg of weight. It said 'Cal3', then 'Pass'. It then returned to normal mode and now started weighing correctly. I calibrated the weights (Flour and Sugar packs) on another set of scales first, but they were only a few grammes wrong so would be close enough anyway. I hope that helps!
SOURCE: Tanita 2204 Scale weight reading problems
Try the following steps:
1) press both the "set" and the triangle button
2) press the triangle button until you get the desired unit of measurement: a) Kilogram, b) stone lbs or c) lbs; and
3) press the "set" button.
Posted on Nov 20, 2008
ButtFuzz
  • 463 Answers
SOURCE: My Scale stoped weighing me, now it reads 1-ld .
The sensor has been worn out or has been pushed past it's weight limit. When you get on it, it pushed the sensor past the point of working... When she gets on it, no problemo...
Posted on Mar 16, 2009
evista_win
  • 10 Answers
SOURCE: my salter 1004SSDR kitchen scale won't show any
Your salter scale has a 15 year warranty. I would call the customer service number 1-866-843-3905 and ask them why it won't zero to weigh anything. They may replace your product.
Posted on Sep 10, 2009
SOURCE: Conair #WW78 scale doesn't reweigh
;i have a problem with the conair ww78. It does not reweigh. It shows the same weight each and every day. What is the problem and how can it be fixed?
Posted on Mar 22, 2010
SOURCE: Conair thinner scale model TH402 displaying incorrect weight?
Conair TH402 displayes incorrect weight
Posted on Nov 15, 2010
My ProScale XX 250 shows out2
I had this problem with my Silvercrest kitchen scales model z30170. Being wall mounted the weighing platform was on a fold-down flap . It turned out to be a broken wire in the hinge joint.
Dec 28, 2012 | Tanita 1479V - Digital Pocket Scale /...
Where can I get a operating manual for silvercrest digital kitchen scales num: Z30170. in english
http://www.lidl-service.com/cps/rde/xchg/SID-EE4A0FEC-2E826FB3/lsp/hs.xsl/product.html?id=8346817&title=Digital+Kitchen+Scale&count=1
Aug 04, 2011 | Microwave Ovens
This is a new scale. Every time you get on it a new reading?
See if this helps.
Step on gently and stand very still. Step off and press/tap with your foot the center of the scale to reset to 0.0 and step up again and be very still while it reads your weight.
Mine gave a little different weight but after I tried again I had two readings the same and the readings were what I expected. So if in doubt I read twice. If I am very still when I step up mine give same reading.
I hope there is nothing wrong with your new scales.
Happy weighing.
Aug 15, 2010 | Conair Large Digital Display Memory...
E appears on Salter scale, even with new batteries
Hallo I have problem witch kitchen scale Salter.E appear when I pushed on and it takes 3 sec
How can I fix this problem
Than You
Sep 18, 2009 | Salter 2001 electronic kitchen scale
Negative weight on Salter Stainless Steel Kitchen Scale
make sure the battery your getting is a good one longlastig and if that doesnt work then how nout the motor
Aug 21, 2009 | Salter 2001 electronic kitchen scale
Wrong weight
Finding replacement parts for store bought scales can be a fun experience to say the least. I would purchase a product from Seca or Health o Meter instead. Their parts and service centers are right here in the states and are genuine about their product accuracy and costomer service.
May 08, 2009 | Conair Weight Scale "Thinner" with Body...
Weight watcher scale not calibrating weight correctly
Press the scale once with your foot. All screen options should display to initialize and then go to 0.0. Now step on the scale. It should read out your correct weight. If not, first remove and replace the battery for reset. If still not, replace the battery. If still not it's ready for return or replacement. Hope it works! Dave - CA
Aug 12, 2008 | Irons
Health & Beauty Logo
511 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
