Question about Dryers
Dryer starts when I close the door with out hitting the start button
    Top Expert:
  • Dryers Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 04, 2012
catriver
  • 878 Answers
SOURCE: My Dryer will only work if I hold start button, when I release start button the dryer stops.
Anra, this is a classic symptom of a failed even heat board. I've seen a lot of these failures out there. Easy to change out. Check out this link. Catriver..post back http://www.repairclinic.com/0080.asp
Posted on Mar 26, 2007
catriver
  • 878 Answers
SOURCE: My Dryer will only work if I hold start button, when start button is released the dryer stops working.
Anra, the problem is in the even heat board under the consol. This is a very easy job. Check out this link. Catriver, post back http://www.repairclinic.com/0080.asp
  • 1028 Answers
SOURCE: Dryer door pops open after
door strike is bad also door may be warped make sure door is not warped if it is just twist in opposite direction if strike needed part #279570
Posted on Jun 14, 2008
  • 1028 Answers
SOURCE: Start Button will start dryer but won't stay on!
pull end caps off just grab at top of plastic and pull towards you remove the 2 screws underneath lift console up and roll back next to timer is a small control bd to right of that are 2 relays 1 with red wires for element and 1 with blue wires for motor first try switching the relays they are identical and will work for either 1 ..try if works replace relay ..if still not working suspect control bd
Posted on Jul 01, 2008
Maytag317
  • 1136 Answers
SOURCE: dryer wont react when hit start button
HI, Sounds like Normal 0 , UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
Please let me know if this help or if I can assist you further.
Thanks
Vic
a fuse. Try this,
Posted on May 30, 2009
There is power to the dryer, but when i hit start, the door doesnt lock and then start? What could be wrong?
That's a great question, friend!
From what you have described your Electrolux dryer is not locking or starting when you hit the start button. It sounds like a potential issue with your door latch or main control panel. If your door latch is not sensing the door is closed and locked it will not start your washer cycle. Also, if your control panel is not registering the door is closed it will not lock and start the cycle. I suggest you reach out to a professional for proper repairs to be completed. If you do not have a professional contact you can visit your manufacturer's website for additional assistance. I hope this is helpful information to you. -Matt
Mar 23, 2015 | Electrolux Dryers
Bosch Dryer WTL 5410 UC do nothing after selecting a program and hitting the start button. The only thing that happens is that the Drying light lits and nothing else happens. I have tried to hit start...
Door switch may still be your problem. Mine showed lights as if working when closed but I decided to use a screwdriver and push in switch all the way in. It worked then without door closed. It will stay stuck until you pull it own a bit to release it. Give it a try. The door switch appears to have two switches in it requiring it to be all the way in.
Aug 12, 2011 | Bosch Axxis WTL 5400 Dryer
My dryer light will not shut off even when door closed and it will not start up when in push start button it does a rapid beep
is the door switch broke?first what kind of dryer and send the model number,when the door closes it hits the door switch and shuts the light off,the dryer will not run if the switch is broke,it's like trying to start the dryer with the door open if the switch broke.
Apr 25, 2011 | Dryers
When hitting start button, it sometimes buzzes, but fails to start. Can sometimes wait for a little while and try again, and it starts. When it buzzes, it will only buzz for a few seconds and then nothing.
it is either the door switch or start switch, this website will show you how to test both, Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Apr 16, 2011 | Whirlpool LER4634J Electric Dryer
Kenmore 64112 dryer wont start when I hit the start button
Check house fuses or circuit breaker.
Pull 220V cord from wall outlet and inspect the gold prongs.
If you see any burnt areas on the prongs the outlet is bad.
If the unit makes no noise when you press the start button check the dryer door switch and make sure it clicks when depressed.
Sometimes the door switch arm can break off so when the door closes
the door switch cannot be activated.
If you hear a growl noise when you press the start button 2 things...
1. The motor is bad and needs replacing.
2. An object fell down the lint trap and is preventing the motor from turning.
Also if the dryer vent has been plugged causing the dryer to over heat a saftey fuse may have blown and needs replacement.
Jan 16, 2010 | Kenmore 64112 Electric Dryer
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
HE5 Dryer not working
Hello dram65,
Check the door interlock switch, if that's malfunctioning or not sensing the door is closed.. it will disable the drying function,
Regards,
Rick
Dec 13, 2008 | Kenmore 82822 Electric Dryer
Problem with top dryer on stackable frigidaire
The switch may be bad or just not engaging when the door is closed. To test it you could tape something to the inside of the door right where the door meets the switch and see if it comes on. I did that and it worked. I use it as a temp. fix.
Jun 17, 2008 | Frigidaire FEX831CS Top Load Stacked...
Dryer won't stop running
the dryer wont stop running only when open door will it start a fire?
Sep 14, 2007 | Kenmore 62802 Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
