Question about Microwave Ovens
Panasonic microwave grill not working
The grill has stopped working the elements are not heating up and no convection oven.th micro wave works on micro
    Top Expert:
  • Microwave Ovens Master
  • 14,553 Answers
I would call customer service with the model number to see if this is a known issue. You might also call a authorized Panasonic repair center and chat with them to get some idea of what a possible repair might cost.
Posted on Dec 04, 2012
SOURCE: Panasonic Microwave Combi Oven - convection heating not working on timer
fu*k u
Posted on May 27, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: panasonic inverter dimension 4 microwave
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Sep 06, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: I have a panasonic NNA883w
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these inverter-based models.
You can find an authorized Panasonic servicer here.
Posted on Sep 25, 2008
  • 8909 Answers
SOURCE: Panasonic dimension 4 microwave/convection oven
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Posted on Dec 31, 2010
heatman101
  • 43501 Answers
SOURCE: My LG MICROWAVE OVEN IS MODEL
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Posted on Feb 25, 2011
My panasonic NN-8500 microwave/convection oven the microwave part is working fine but,the convection grill defrost is not
Possibly the defrost heater element has failed. You will need to strip the cabinet off and use a multimeter to test the element. May also be the overtemp safety thermostat may have failed.
Nov 19, 2016 | Panasonic Microwave Ovens
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
I have a panasonic NNA720 it only works for about 20 seconds on microwave then stops, oven and grill seem ok
hello,
what this indicate is that the element of the oven is weak or gone bad it is the heat provider it is silver in color
what you are to do to fix up this problem is to unscrew the wave from the stroll then trace the wire down to the element disconnect the wire connected to the element remove the element with care then take it to the store to get the same make of it then replace it carefully the problem will solve
thank you .
Jul 05, 2010 | Microwave Ovens
Amana aco 1840 over stove micro wave. heating not working .
FIK IT THE HEATING ELEMENT IS STRIGHT FORWORD AND COST IS CHEAP, GO FOR IT .
Oct 24, 2009 | Amana ACM1580 Convection Microwave Oven
Where is the 10 amp fuse on my delonghi micro/combo/grill please
Hi, I take it that this is a combi microwave? Some of these have settings on the front to microwave/grill/etc... so make sure its on the right one first!!
If you have selected the correct one then the m/wave does not work it could be several things!
Microwaves run to earth and need diodes to do this if these break down it will not m/wave! It could also be a internal fuse? ( but very unlikley if everything else works) Then you have the Mag or transformer which could be down to! M/waves run on a high power side and a low power side. The low power will not hurt you to much but the high power side will. My advice to uou is not to touch as it could be fatal as these things carry a high charge even when they are unplugged!
Dec 28, 2008 | DeLonghi MW 605 Convection/Microwave Oven
Instructions for Sharp R953 900wt jet convection grill microwave
i have need instruction book how i can use sharp micro wave oven r953
Dec 27, 2008 | Microwave Ovens
Does this unit have a turntable? If so does it turn when on?
Sep 24, 2008 | Panasonic NN-C980 Convection/Microwave...
Panasonic inverter dimension 4 microwave oven runs for 27 secs in micro mode then cuts out no heat either convection oven grill work fine ????
Sep 03, 2008 | Panasonic Microwave Ovens
Microwave Ovens Logo
65 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
